A/D Voltage Question
9 posts / 0 new
I am working on an application that requires the use of a 3.3v regulated power supply, but I am also using an analog remote that I have set up for 5v. Is it possible to set the VCC to 3.3 volts and set the AVCC and AREF to 5V or will the chip limit this? I am using an atmega8L. Thanks.
Well, neither. Check the datasheets on AREF range and AVcc range and Absolute Maximum Ratings and note that Mega8 has Vcc and AVcc tied together internally, and I think the answer becomes apparent.
Lee
If it's possible you can use:
http://focus.ti.com/lit/ds/symli...
IC that can connect 3,3V and 5V systems
Use a voltage divider made of two resistors to take down ADC-input to max 3.3 V. And connect AREF and AVcc to Vcc (3.3 V).
I don´t recommend a hardware connection.
I think it´s more flexible and more safe to do the connection internally by selecting AVCC as the ADCRef.
Just connect the recommended cap to ARef.
Klaus
Look at: www.megausb.de (German)
Wouldn't using the voltage divider change the values that are stored for the a/d conversion? That is what I was trying to avoid, but doesn't sound like I will be able to.
??? What do you mean???
Klaus
when the a/d stores the value into the ADCH and ADCL registers, won't it be different for 3.3v than it would be for 5v
surely!
the value allways follows the formula:
ADCValue = 1024 * V_IN/VRef. (for a 10 bit unipolar input ADC like in AVRs)
Therefore:
If you change ARef you surely change the ADCValue.
But:
if you use
* 3.3V as VREF and use a voltage devider with 5:3.3 ratio
you get the same results as
* when using 5V as VRef and no voltage devider.
Klaus
