ATtiny202 - Oregon Scientific temperature sensor replacement
39 posts / 0 new
My THN132N wireless temperature sensor is dead so I have decided to replace it by ATtiny202 with built in temperature measurement and send data to the Oregon Scientific base station.
I was inspired by the project "Make Your Own Remote Temperature/Humidity Sensor" and I would like to adopt Arduino code to ATtiny202. Unfortunately MPLAB X IDE and XC8 compiler reports some errors. Is there any way how to use Arduino constructor function class in XC8 or how to modify it e.g.
OregonSensor::OregonSensor(uint8_t txPin, uint8_t channel, uint8_t sensorID, bool Humidity)
See WlessOregonV2.cpp code.
C++ code in a C only compiler. Nope I don't think so.
You'll have to port the code to C (or use GCC which includes the av-g++ C++ compiler that Arduino uses).
On the whole a C++ constructor is usually little more than a FOO_begin() or FOO_init() kind of function anyway.
Of course another option is to see if there is a "202 compatible core" for Arduino and just stick with Arduino anyway.
EDIT: looking at that code it is very "C like" and only touches on C++ usage so should be fairly easy to convert to C but one bit that may take a bit more effort is:
void DecodeOOK::interuptHandler(void) {
    static int16_t last;
    // determine the pulse length in microseconds, for either polarity
    wl_pulse = micros() - last;
    last += wl_pulse;
so you would need to implement an equivalent of Arduino's timer interrupt stuff to provide an equivalent for this.
Really GCC or Arduino look like the better options.
Implementing of pulses is pretty easy with ATtiny202. I don't need to use micros() but I will use TCB in Periodic or Single Shot mode (e.g. 80µs for Triac control).
Atmel Microchip Studio can import Arduino "sketches" - have you tried that ... ?
https://www.avrfreaks.net/forum/microchip-trying-wean-people-arduino-atmel-studio
Built-in temperature measurement?  And a triac mention?
Are you planning to use an on-chip temperature sensor?  Remember that [assuming resolution and accuracy are suitable; are they?] you will be measuring the temperature inside the chip.  And the chip is mounted to your circuit board.  And all may be inside an enclosure.  So given all the sources of heat dissipation, it might be a very poor measure of e.g. ambient air temperature.
Thank you. I will try Atmel Studio but first I will verify the Arduino sketch on Arduino.
Kevil wrote:
Atmel Studio
note that it's called "Microchip Studio" now
Yes, I have tried it already and it's working fine. Note that the original Oregon Scientific temperature sensor (thermistor) is soldered by a short wire to the PCB inside of the plastic case. I will just replace the original PCB with my PCB (ATiny202 + 433 MHz transmitter).
And you tried it under full load, in warm conditions, and enclosed?  And there was no difference from ambient?  Wow; remember the movie "Cool Runnings"...
Note MCS7 is the same compiler as Arduino, no real advantage if it works in Arduino, unless you need to debug and have the required DB hardware/interface.
Keys to wealth:
Lets go Brandon!
No arduino needed, but still uses c++
https://godbolt.org/z/Pz9szz
not much there and could easily be done in C.
without division-
https://godbolt.org/z/d5jGq8
You can add other compilers to MPLABX, and are not stuck just using XC8. If you don't already have arduino, you can get its compiler and in either case can point mplabx to the avr/bin folder and you now have c++. The above example is for a mega4809, but will work just the same for a tiny0/1.
I have some temp sensors on an nRF52 board, and the internal temp sensor is 'close' to the more accurate temp sensors but I wouldn't use it for anything more than 'close enough'-
[0952.000000][../Temperature.hpp:79 ::read]
  internal raw: 105  F: 79.2
[0952.125965][../Temperature.hpp:123 ::read]
  Tmp117 raw: 3524  F: 81.5
[0952.148901][../Temperature.hpp:176 ::read]
  Si7051 raw: 27716  F: 81.4
I also have a mega4809 board 3ft from the nRF52 board, and its internal temp also reads 'close' to all the other readings. Still don't have much trust in the internal, though. I don't have a great deal of confidence in the better temp sensors either, although they will be 'more' close enough for my use.
Gotta laugh, at least a little bit.
In the original article referenced in the original post the author stated that he had to redo some of the data trasmission library because the micro wasn't fast enough.
Perhaps it would have been easier to run the micro at 20 MHz, instead of 1 MHz, and instantly gained a 20x performance increase!
For a episodic temperature data packet transmission, running the micro at 20 MHz,and then sleeping between transmissions, might have been an easier approach to solving this issue while maintaininig energy effiency.
I have decided to start from scratch with ATtiny202 and follow the Manchester Encoder Using USART and CCL on ATtiny817. It is running well on standard ATtiny202 frequency 20 MHz / 6 = 3.333 MHz and 9600 bits/s.
ATtiny202 same result as in the AN2371 example above:
Although I found the OregonScientific-RF-Protocols (need version 2.1) I do not fully understand how to generate the "sauce" around Manchester encoded temperature data.
What ‘sauce’ are you missing? I decoded the protocol years ago.
It is pretty easy just using a timer with compare to generate the bits. No need for clock and logic to generate the manchester.
Indeed, that is often the case: run fast to finish quickly, then maximise sleep.
I am almost done with the program for synchronous USART and logic, just need to buy the 433 MHz transmitter and test it on real Oregon Scientific station.
Preamble v2.1 sequence start, magenta (USART cyan & CCL):
Sync pattern 10 11 10 11 i.e. 0101 = 'A' with LSB first
Part of the code:
        USART_0_write(0x15);    // Two short bursts to alert Oregon receiver
        for (int i = 3; i > 0; i--) {
            USART_0_write(0x55); // 0x10101010 Preamble
        USART_0_write(0x66);    // Sync 10 11 10 11 i.e. 0 1 0 1 'A' LSB first
        USART_0_write(0x40);    // Finish Sync
I’ll have to dig out my code to recall the finer details, but why 9600? Its more like 1024 bits/second if i remember correctly. 9600 is pushing it a bit for 433MHz OOK. I also seemto recall the preamble is a series of ‘1’s then the sync. I’ll see if i can dig up my old code tomorrow and refresh my memory.
You are right, I need to change the speed to  1024 wink.
I had a quick look at the code I wrote many years ago.
The start is 24 Manchester '1' bits followed by 0101, again Manchester encoded. This is followed by a number of nibbles with the required data.
If in doubt, capture a real transmission to compare with yours.
I captured real V2.1 data. Everything is clear just I don't know the meaning of last two nibbles after checksum (2 nibbles) at the end called Post-amble.
Sync Preamble 0xA, bits 1, 2, 4, 8 starting from LSB:
Over-peaked scope probe. Those tops and bottoms should be flat.
True dat.
Did we really need a moob picture? I can't un-see that now.
Not sure of the exact reason for the post-amble apart from being a specific end-of-message sequence. Might be something to do with anti-collision detection (or collision for that matter) as the Oregon devices transmit asynchronously - i assume they rely on being started at much the same time for timing. I do find they clash every so often. I dare say the cost of Bluetooth has dropped to a point where it might be a better  and more reliable choice than 433MHz OOK.
Finally I succeeded. I can now transmit temperature data from the ATtiny202 through 433 MHz transmitter to the Oregon Scientifics base station.
I am going to make a final version of the program with sleep mode to transmit data each 30 seconds. The ATtiny202 clock 20 MHz is devided by 24 to 833333 Hz to save the power consumption and to get the 1 024 Hz bit rate. I am using synchronous USART and  Configurable Custom Logic (CCL) to generate Manchester code.
The program uses 103 out of 128 bytes of RAM and 932 out of 2 048 bytes of Program Flash.
Good news.
Would you care to share the secret - for the benefit of future readers who may com along with the same question.
Then mark the solution.
Attached you can find my MPLAB X IDE working test project which sends temperature 12.3°C each 30 seconds to the Oregon Scientific base station 259981. The ATtiny202 is simulating the Oregon Scientific THN132N Wireless Temperature Sensor.
The THN132N is using Oregon Scientific protocol 2.1 and 1024 Hz bit rate. 1024 BAUD doesn't work but 1028 BAUD Yes.
The ATtiny202 clock 20 MHz is divided by 24 which is 833333 Hz. Synchronous IRQ USART routines generated at start.atmel.com
ATtiny202 pins PA3 (SOIC 7) CLK, PA1 (SOIC 4) TX and PA6 (SOIC 2) is the Manchester code output to 433 MHz transmitter.
Message structure (send twice with pause 6.42 ms between these two messages and then long pause 30 seconds):
After test while (USART_0_tx_elements != 0) there ares s till two USART registers shifting data out (USART buffer ~ 19.64 ms)
So you need actually set delay to 29 ms to get 6.42 ms pause (29 -  19.64 = 9.36 ms)
_delay_ms(29); // ~6.42 ms; USART buffer ~ 19.64 ms
Preamble 16 pulses (i.e. send 4x 0xAA)
Sync, send 1x 0x99 which is in Manchester 0xA
Actual Data Test Data
Nibble:
  0  0xE  Sensor Id: 0xEC40 (THN132N)
  1  0xC
  2  0x4
  3  0x0
  4  0x4  Channel No. = 3  (1<<(ch-1))
  5  0x6  Rolling Code, Value changes randomly every time the sensor is reset (it's up to you)
  6  0x8
  7  0x0  Battery voltage 0 = OK (Bit value 0x4 is the battery low flag)
  8  0x3  Temperature, tenth of a degree (BCD temperature in degrees Centigrade i.e 12.3°C)
  9  0x2  Temperature, units of degrees
10  0x1  Temperature, tens of degrees
11  0x0  Temperature sign, 0 = positive temperature (Non-zero for negative values)
12  0x6  Checksum (of nibbles 0 to 11) i.e. 0x36
13  0x3
14  0xD  CRC* nibbles 0 to 11 excluding Rolling Code (Nibbles 5 and 6), start CRC value = 0x43, polynomial = 0x07
15  0x7
CRC calculation is not part of the test program yet. I calculated it in Visual Studio C++:
#include <stdio.h>
#include <stdlib.h>
#define CRC8INIT  0x43
#define CRC8POLY  0x07
char msglen = 5;
unsigned char msg[] = { 0xEC, 0x40, 0x40, 0x32, 0x10 };	// CRC 0x7D, for my test program
unsigned char crc8(unsigned char* data_in, char number_of_bytes_to_read) {
	unsigned char  crc, loop_count, bit_counter;
	crc = CRC8INIT;
	for (loop_count = 0; loop_count != number_of_bytes_to_read; loop_count++)
		crc = crc ^ data_in[loop_count];
		bit_counter = 8;
		do {
			if ((crc & 0x80) != 0) {
				crc <<= 1;
				crc = crc ^ CRC8POLY;
			else crc <<= 1;
			bit_counter--;
		} while (bit_counter > 0);
	return crc;
int main()
	unsigned char crc;
	crc = crc8(msg, msglen);
	printf("\r\n crc %2x", crc);
	return (0);
fyi
'loss of sign on assignment' from a linter.
		crc = (unsigned int) crc ^ data_in[loop_count];
crc promoted to int
	printf("\r\n crc %2x", (unsigned int) crc);
PC-lint Plus Online Demo - Gimpel Software - The Leader in Static Analysis for C and C++ with PC-lint Plus
Just to let make the PCB. U1 is the Microchip MCP16251 (high-efficiency, fixed frequency, synchronous step-up DC-DC converter 1.5 to 3.3V), U2 ATtiny202 and U3 is the 433 MHz transmitter.
The layout needs to be improved -especially around U1 otherwise it will make a better transmitter than the actual tx module!
What's wrong ?
Tracks are too thin, too long and bad placement. The dc/dc converter switches at high frequency and needs proper attention paid to layout - refer to the datasheet. It gives you the recommended layout. The inductor and capacitors are critical as well. Whilst it might be ‘working’, it could be inefficient and radiating..
I can't do much more because of the constraints (AA battery next to "+" sign, two holes) of the PCB layout to fit into the Oregon temperature sensor casing. I can only move R2 & C2 closer to the U1 voltage converter chip. Tracks are 0.3 mm (11.811 mils).
See the design of the Microchip Evaluation Board:
If it works for you, then i’d say you’re lucky as you’ve violated a few design rules. 11thou tracks are ok for interconnects, but you want thicker for the power traces to minimise inductance.
indeed - look at the thickness of the power interconnects on that!
PCB in production, waiting for delivery smiley.
If it doesn’t work, then you’ll know where to look. For one, L1 doesn’t look to be the right size. Pcbs are cheap, so just spin another if required.
Working PCB as expected wink. R1 label should be more to the right below U1. I forget to move it there below resistor.
Temperature measured by ATtiny202 at the Base Station.
