Posted by Brian Fairchild:
Sun. Apr 4, 2021 - 07:44 AM
No-one ever got fired for using a chip from FTDI, but there are not cheap. Does anyone have experience, preferably in commercial products, of the following...
CH3xx series
PL series chips from Prolific
MCP22xx series from Microchip
CP2xxx series from Silicon Labs
GL8xx from Genesys
Chips that are as plug-and-play with modern PCs as possible are to be preferred.
#1 Hardware Problem? https://www.avrfreaks.net/forum/...
#5 "If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand."
Tags:
