Porting Atmel ASF code to Atmel start
6 posts / 0 new
   I am Trying to port code generated using Atmel ASF to Atmel Start of UART communication please help to port it. which points I have to consider most.
I don't think it's really a question of "porting" is it. The advantage Start (ASF4) has over ASF3 (apart from also being online) is that it is much more streamlined code. So I would just identify the boundaries where your own code crosses over to ASF3 APIs then create a whole new project from scratch using your own code then try to find ASF4 matches for the ASF3 functionality to connect to.
Hello
     I have one big project which is created using ASF and now my task is to port it into Atmel studio. I want to know at which point I have to give more attention. The APIs used in ASF is completely different from Using ATmel start. In ASF driver files created are also different.
Surely, if it uses ASF it must already be in Atmel Studio?
The Key (as clawson suggested)  is to isolate your code from those APIs - then you don't have to change your code between ASF and START or anything else.
If you don't already have a "clean break" between your "application" code and the ASF stuff, the first step is probably to make that so ...
EDIT
|             Application               |
|           interface layer             |
|          ASF  -or-  START             |
|             Hardware                  |
Atmel ASF code is for board SAMR34J and I am using SAME54. Atmel ASF is not supported for my board so I want to port it
Poojashete1 wrote:
Atmel ASF is not supported for my board (sic?)
You mean not supported for the  SAME54 chip?
Adding board support is easy.
So #2 and #4 cover that.
