ATtiny202 - How to start TCB in Single-Shot Mode repeatedly ?
7 posts / 0 new
I don't fully understand how to repatedly start TCB in Single-Shot Mode to generate exact pause each 500 ms.
The test program generate 29 us pulses instead of 78.64 ms (1/833000*65535):
#define F_CPU 833333
#include <atmel_start.h>
#include <util/delay.h>
int main(void) {
    /* Initializes MCU, drivers and middleware */
    atmel_start_init();
    PORTA.DIR |= PIN1_bm;
    PORTA.OUTCLR |= PIN1_bm;
    while (1) {
        PORTA.OUTSET |= PIN1_bm;
        TCB0.CTRLA |= TCB_ENABLE_bm;
        while ((TCB0.STATUS & TCB_RUN_bm))
        TCB0.CTRLA &= ~TCB_ENABLE_bm;
        _delay_ms(500);
TCB init:
int8_t TIMER_0_init()
	TCB0.CCMP = 0xffff; /* Compare or Capture: 0xffff */
	// TCB0.CNT = 0x0; /* Count: 0x0 */
	TCB0.CTRLB = 0 << TCB_ASYNC_bp        /* Asynchronous Enable: disabled */
	             | 0 << TCB_CCMPEN_bp     /* Pin Output Enable: disabled */
	             | 0 << TCB_CCMPINIT_bp   /* Pin Initial State: disabled */
	             | TCB_CNTMODE_SINGLE_gc; /* Single Shot */
	TCB0.DBGCTRL = 1 << TCB_DBGRUN_bp; /* Debug Run: enabled */
	// TCB0.EVCTRL = 0 << TCB_CAPTEI_bp /* Event Input Enable: disabled */
	//		 | 0 << TCB_EDGE_bp /* Event Edge: disabled */
	//		 | 0 << TCB_FILTER_bp; /* Input Capture Noise Cancellation Filter: disabled */
	TCB0.INTCTRL = 0 << TCB_CAPT_bp /* Capture or Timeout: disabled */;
	// TCB0.CTRLA = TCB_CLKSEL_CLKDIV1_gc /* CLK_PER (No Prescaling) */
	//		 | 0 << TCB_ENABLE_bp /* Enable: disabled */
	//		 | 0 << TCB_RUNSTDBY_bp /* Run Standby: disabled */
	//		 | 0 << TCB_SYNCUPD_bp; /* Synchronize Update: disabled */
	return 0;
What I am doing wrong ?
I think you need to use an event channel to start the timer in single-shot mode.  And then I don't think you can remove the CTRLA enable disable statements in your loop.
EDIT:
It looks like the following at the beginning of the loop:
      EVSYS.ASYNCUSER0 = EVSYS_SYNCCH0_TCB0_gc;
where you have enabled input events via
    TCB0.EVCTRL = TCB0_CAPTEI_bm;
in your init routine.
Fixed already. It needs some time after enabling TCB, asm("nop") and reset TCB0.CNT = 0 before reenabling TCB (CNT remains at TCB0.CCMP = 5500 after counting)
I need to start TCB "manually" by program.
Fixed code:
int main(void) {
    atmel_start_init();
    while (1) {
        asm("nop");
        TCB0.CNT = 0;
        _delay_ms(500);
Did you read the datasheet?  The way you are using it doesn't seem consistent with the intent I read in the datasheet.
Yes, maybe. The problem with the datasheet is that it does not answer all your questions, that you may have. But if you have a deep technical knowledge and right equipment (oscilloscope) you can test it and find out how to fix the problem.
Not related, but you are defeating the purpose of the SET/CLR registers in a number of places (and missing that DIRSET is also available). These require the use of only = to get an atomic write to a specific bit or bits. When you do |= you are getting more information than you bargained for (pin information you do not need/want), and potentially corrupt the register which the SET/CLR registers were created to avoid. You want specific bit(s) set/cleared, and all the others can be written as 0 so as not to touch them, therefore the = only.
Thank you for your advice, you are right with PORTA.OUTCLR = PIN1_bm. I was using PORTA.OUT |= PIN1_bm previously so it was a little overkilled wink.
