Alternate Pin Allocation Question
3 posts / 0 new
Hey Ho,
I am using the SPI port on the UNO to drive a DAC.  I am not using the MISO input, and teh Relay Shield I am using uses the MISO lone to activate Relay 4.
Can I simply set teh direction of the PIN and its mode in the SETUP loop and move on, or will this cause headaches?
I strongly advise you to avoid MISO pin as GPIO.
SPI.begin() is going to assign it as an INPUT.
There should be enough GPIO pins on a Uno.
Good Enough for me.  Thanks!
