Updated Atmel Studio Microchip Studio...
5 posts / 0 new
I canceled out of the XC8 compiler install part.  Would that have given two compiler choices inside Microchip Studio or installed MPLAB?
Also, I saw some posts about newer versions of gcc - do they work with studio?  After installing the Microchip Studio and rebuilding a project, it says 5.4.0 for gcc's version, but I've seen references to 8 and a google search shows 10.
Can these newer gcc versions be used in studio?
The XC8 is a separate installer, not bundled with MPLAB X. It would have given you two compiler choices in Studio.
Yes - see: https://www.avrfreaks.net/commen...
or installed MPLAB?
No.
Sure. Serach for the term "toolchain flavour":
also:
You basically set the "Base Path" to the ...\bin directory where the copy of avr-gcc.exe is located.
I guess I am an old dog not up to new tricks.  I think I have the last Atmel Studio version on this laptop, and the previous version downstairs on my bench.  I have no intention of upgrading either of them ever.  But then, I only use older mega's, of which I believe I have a lifetime supply.  I would probably still be happy with AVRStudio 5.1.  I kind of liked it.
