AVR304 software serial
66 posts / 0 new
Hello. I wish to use AVR-304 based software serial routine to send some strings to a putty terminal. The concept is simple, send a couple of strings, use avr gcc delay_ms() to have some delay and repeat sending the strings. I use Atmel Studio 7 and Arduino Pro Mini. Please note, the Arduino is only used as a hardware board, I do not use Arduino IDE.
The code is posted. there are two files, main.c and sw_uart.c. No Header files for such a small project. The problem is that upon power on or reset, the board transmits the two strings shown perfectly the first time. Once it goes through the delay routine, the strings are unprintable characters. But they are in proper sequence, with proper delays in between. It is just that the strings are garbled.
I have tried many things, including reducing the baud rate to 9600 (as at present). I am not using the RECEIVE part at present.
One thing to note: In the same main.c() program, if I write a code to make the on board LED at D13 toggle with the same delay, it works perfectly. I feel the issue is some interaction between the software delay program and the software delay loop.
Been on this for a week now, any assistance will be much appreciated.
The code files as attached:
sw_uart.c
#include // Device specifics.
#include // Interrupt specifics.
#include
//Desired baudrate...choose one, comment the others.
#define BR_9600
//#define BR_19200
//#define BR_38400
//This section chooses the correct timer values for the chosen baudrate.
#ifdef BR_9600 //****CHECK BIT VALUES**** These are for 16MHz, prescalar = 32
#define TICKS2COUNT 52 //Ticks between two bits.
#define TICKS2WAITONE 52 //Wait one bit period.
#define TICKS2WAITONE_HALF 78 //Wait one and a half bit period.
#endif
#ifdef BR_19200 //****CHECK BIT VALUES**** These are for 16MHz, prescalar = 8
#define TICKS2COUNT 104 //Ticks between two bits.
#define TICKS2WAITONE 104 //Wait one bit period.
#define TICKS2WAITONE_HALF 156 //Wait one and a half bit period.
#endif
#ifdef BR_38400 //****CHECK BIT VALUES**** These are for 16MHz, prescalar = 8
#endif
#define INTERRUPT_EXEC_CYCL 9 // Cycles to execute ISR after interrupt.
//Some IO, timer and interrupt specific defines.
//MCU definitions - CHECK for proper Timer SFR definitions
#if (defined(__ATmega8__))
#define ENABLE_TIMER_INTERRUPT( ) ( TIMSK |=_BV(OCIE2))
#define DISABLE_TIMER_INTERRUPT( ) ( TIMSK &= ~_BV(OCIE2))
#define CLEAR_TIMER_INTERRUPT( ) ( TIFR |=_BV(OCF2))
#define ENABLE_EXTERNAL0_INTERRUPT( ) ( GICR |=_BV(INT0))
#define DISABLE_EXTERNAL0_INTERRUPT( ) ( GICR &= ~_BV(INT0))
#define TX_PIN PD6 //Transmit data pin
#define RX_PIN PD2 //Receive data pin, must be INT0
#define TCCR TCCR2 //Timer/Counter Control Register
#define TCCR_P TCCR2 //Timer/Counter Prescaler
#define OCR OCR2 //Output Compare Register
#define TCNT TCNT2 //Tmr counter register
#define EXT_IFR GIFR //Ext Interrupt Flag Register
#define EXT_ICR MCUCR //Ext Interrupt Control Register
//#define TIMER_COMP_VECT TIMER0_COMP_vect //!< Timer Compare Interrupt Vector
#elif (defined (__AVR_ATmega328P__))
#define ENABLE_TIMER_INTERRUPT( ) ( TIMSK2 |= ( 1<< OCIE2A ) )
#define DISABLE_TIMER_INTERRUPT( ) ( TIMSK2 &= ~( 1<< OCIE2A ) )
#define CLEAR_TIMER_INTERRUPT( ) ( TIFR2 |= ((1 << OCF2A) ) )
#define ENABLE_EXTERNAL0_INTERRUPT( ) ( EIMSK |= ( 1<< INT0 ) )
#define DISABLE_EXTERNAL0_INTERRUPT( ) ( EIMSK &= ~( 1<< INT0 ) )
#define TX_PIN PORTD6 //Transmit data pin,PDx is for ATMega8
#define RX_PIN PORTD2 // Receive data pin, must be INT0
#define TCCR TCCR2A // Timer/Counter Control Register
#define TCCR_P TCCR2B //Timer/Counter ControlPrescaler
#define OCR OCR2A // Output Compare Register
#define EXT_IFR EIFR // External Interrupt Flag Register
#define EXT_ICR EICRA // External Interrupt Control Register
#define TIMER_COMP_VECT TIMER2_COMPA_vect // Timer Compare Interrupt Vector
#endif
#define TRXDDR DDRD //Set Tx/Rx ports, pins
#define TRXPORT PORTD
#define TRXPIN PIND
#define SET_TX_PIN( ) ( TRXPORT |=_BV(TX_PIN))
#define CLEAR_TX_PIN( ) ( TRXPORT &= ~_BV(TX_PIN))
#define GET_RX_PIN( ) ( TRXPIN & (_BV(RX_PIN)))
//Type defined enumeration holding software UART's state.
typedef enum
IDLE, //Idle state, both transmit and receive possible.
TRANSMIT, // Transmitting byte.
TRANSMIT_STOP_BIT, //Transmitting stop bit.
RECEIVE, //Receiving byte.
DATA_PENDING //Byte received and ready to read.
}AsynchronousStates_t;
static volatile AsynchronousStates_t state; //Holds state of UART.
static volatile unsigned char SwUartTXData; //Data to be Tx'ed.
static volatile unsigned char SwUartTXBitCount; //TX bit counter.
static volatile unsigned char SwUartRXData; //Storage for Rx'ed bits.
static volatile unsigned char SwUartRXBitCount; //RX bit counter.
// External interrupt service routine.
ISR(INT0_vect) //Receive interrupt - falling edge
state = RECEIVE; // Change state
DISABLE_EXTERNAL0_INTERRUPT( ); // Disable intr during the data bits.
DISABLE_TIMER_INTERRUPT( ); // Disable timer to change its reg.
TCCR_P &= ~(( 1 << CS21 )|( 1 << CS20 )); // Reset prescaler counter.
TCNT = INTERRUPT_EXEC_CYCL; // Clear counter register. Include time to run ISR.
TCCR_P |= (( 1 << CS21 )|( 1 << CS20 )); // Start prescaler clock.
OCR = TICKS2WAITONE_HALF; // Count 1.5 bits to sample first bit.
SwUartRXBitCount = 0; // Clear received bit counter.
CLEAR_TIMER_INTERRUPT( ); // Clear interrupt bits
ENABLE_TIMER_INTERRUPT( ); // Enable timer0 interrupt on again
// Timer2 interrupt service routine.
ISR(TIMER_COMP_VECT)
switch (state)
// Transmit Byte.
case TRANSMIT:
// Output the TX buffer.
if( SwUartTXBitCount < 8 ) { if( SwUartTXData & 0x01 ) // If LSB of the TX buffer is 1: { SET_TX_PIN(); // Send a logic 1 on the TX_PIN. } else { // Otherwise: CLEAR_TX_PIN(); // Send a logic 0 on the TX_PIN. } SwUartTXData = SwUartTXData >> 1; // Bitshift the TX buffer and
SwUartTXBitCount++; // increment TX bit counter.
//Send stop bit.
SET_TX_PIN(); // Output a logic 1.
state = TRANSMIT_STOP_BIT;
break;
// Go to idle after stop bit was sent.
case TRANSMIT_STOP_BIT:
DISABLE_TIMER_INTERRUPT( ); // Stop the timer interrupts.
state = IDLE; // Go back to idle.
ENABLE_EXTERNAL0_INTERRUPT( ); // Enable reception again.
break;
//Receive Byte.
case RECEIVE:
//Count one period after the falling edge is trigged.
OCR = TICKS2WAITONE;
if( SwUartRXBitCount < 8 ) //Receiving, LSB first. { SwUartRXBitCount++; SwUartRXData = (SwUartRXData>>1); // Shift due to receiving LSB first.
if( GET_RX_PIN( ) != 0 )
SwUartRXData |= 0x80; // If a logical 1 is read, let the data mirror this.
//Done receiving
// Enter DATA_PENDING when one byte is rx'ed.
state = DATA_PENDING;
// Disable this interrupt.
// Reset flag not to enter the ISR one extra time.
EXT_IFR |= (1 << INTF0 );
// Enable interrupt to receive more bytes.
break;
// Unknown state.
default:
state = IDLE; // Error, should not occur. Going to a safe state.
} //end switch
} // end intr
// Function to initialize the software UART.
//This function will set up Tx & Rx pins, tmr CTC mode, prescalar & interrupts.
//Leaves init routine after setting uart in Rx mode by enabling ext INT0.
void initSoftwareUart( void )
//Set PORT
TRXPORT |=_BV(RX_PIN); // RX_PIN is input, pulled up.
TRXDDR |=_BV(TX_PIN); // TX_PIN is output.
SET_TX_PIN( ); // Set the TX line to idle state.
//Set Timer2
DISABLE_TIMER_INTERRUPT( ); //(TIMSK &= ~_BV(OCIE2))
TCCR = 0x00; //Ensure TCCR is initialised on power on
TCCR_P = 0x00;
TCCR |= (1 << WGM21); // Timer in CTC mode.
TCCR_P |= (( 1 << CS21 )|( 1 << CS20 )); // set prescaler.
//Set External interrupt
EXT_ICR = 0x00; // Init MCUCR
EXT_ICR |= (1 << ISC01 ); // Interrupt on falling edge.
ENABLE_EXTERNAL0_INTERRUPT( ); // Turn external interrupt on.
//Internal State Variable
state = IDLE;
// Send an unsigned char.
static void putChar( const unsigned char c )
while( state != IDLE )
; // Don't send while busy receiving or transmitting.
state = TRANSMIT;
DISABLE_EXTERNAL0_INTERRUPT( ); // Disable reception.
SwUartTXData = c; // Put byte into TX buffer.
SwUartTXBitCount = 0; //set bit count 0
TCNT = 0; // Clear counter register.
TCCR_P |= (( 1 << CS21 )|( 1 << CS20 )); // CTC mode. Start prescaler clock.
CLEAR_TX_PIN(); // Clear TX line...start of preamble.
CLEAR_TX_PIN( ); // Clear TX line...start of preamble
ENABLE_TIMER_INTERRUPT( ); // Enable o/p compare interrupt
// Print unsigned char string.
//param const unsigned char* Pointer to the string that is to be printed.
//retval void
void print_string( const unsigned char *data )
OCR = TICKS2WAITONE; //set bit times
while( *data != '\0' )
putChar( *data++ );
main.c
#include #include #include #include #include #include
#include "ds18b20.h"
//function declarations
void initSoftwareUart( void );
void print_string( const char * );
//init uart
initSoftwareUart();
//init interrupt
sei();
print_string("DS18B20 Temperature Probe\r\n");
for (;;)
//software serial routines
print_string("Temperature: ");
print_string("\r\n");
_delay_ms(1000);
return 0;
I regret to post the code like this, I could not see any special way to post the code. Also, some "toolbar" is mentioned for formatting, I cannot see any such toolbar. May I request assistance on how to use this highly helpful forum more effectively?
No one can read that. I realise it might have lost the indent when you pasted it in but in future I'd suggest using:
which will bring up the code editor so you can paste your code in.
See Tip #2 in my signature (below) - also FAQ#3 in clawson's
Something must be going wrong with your timing ...
Here is the properly posted code.
Thanks for the advice, Clawson
#include <avr/io.h>     	// Device specifics.
#include <avr/interrupt.h>     // Interrupt specifics.
#include <util/delay_basic.h>
#define BR_9600
//#define BR_19200
//#define BR_38400
#endif
#endif
#endif
#endif
#define TRXPIN  PIND
typedef enum
  switch (state)
  // Transmit Byte.
  case TRANSMIT:
	 {                                // Otherwise:
    //Send stop bit.
  break;
  break;
  //Receive Byte.
  case RECEIVE:
        SwUartRXBitCount++;
    //Done receiving
  break;
  // Unknown state.
  default:
  } //end switch
}	// end intr
  //Set PORT
  //Set Timer2
  TCCR_P = 0x00;
  state = IDLE;
  state = TRANSMIT;
//retval void
    putChar( *data++ );
main.c
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <util/delay.h>
	//init uart
	initSoftwareUart();
	//init interrupt
	sei();
	for (;;)
		_delay_ms(1000);
	return 0;
Agreed, if the baud rates do not match, there will be junk characters. However, since the strings are properly displayed in the first run of the program, it confirms the baud rate is correct. Also, if I comment out the delay_ms() routines, the string is properly displayed repeatedly, of course at a good speed, confirming the baud rate set in the program (9600) matches that of the PUTTY terminal. I too understand something going wrong with the timing, but have not been able to identify the issue. Hence requested support.
Looks like your strings are in RAM - so maybe they're getting corrupted?
Do you have a debugger to see what's actually going on?
EDIT
Or something in your timers and/or soft-UART stuff isn't being properly reset ready to again after the first set of strings - again, a debugger would help here.
Or maybe use the real UART for debug output?
EDIT 2
Your code indentation is a bit random, which makes the code hard to follow - especially the timer ISR state machine.
But it doesn't look like you have any proper handling for the IDLE state ?
So, for the first run through, the first string is sent immediately after initialisation, and each subsequent string is sent immediately the previous one has finished - so there is no IDLE time.
But, when you put the delay in, you get a whole load of IDLE time ...
Just to be sure
which chip ?
which optimizing level ?
normally _delay_ms() and interrupts isn't a good mix, but normally it's just the delay that get's to long.
does it work in the simulator ? (tx is easy to simulate)
you should use the timer ISR to make the delay, but for test try to cli() sei() around the delay
here is code from another freak you may want to try out if you can't get this to work.
Keys to wealth:
Are you using a crystal--please don't say you are trying to use the internal RC osc...you will go on a goose hase.
In general, yes - always use a crystal where async serial comms is required.
But OP said it works first time through - so must be correct baud rate - just on subsequent iterations of the loop it fails.
I would think it unlikely that the internal RC would change so much & so quickly for that to be the cause here?
A couple of thoughts...
First, I ought to stay out of this, as I don't know C.
Next, thank you for including comments in your code!
Finally, one HW comment, one SW comment:
HW:
Is the Receiving data input pin held in a known state, with a pull-up / pull-down, (whatever) resistor?
Or is it floating?
I didn't study your code to see how a string of Rx interrupts could distort your Tx data transmission timings.
If the Rx input is floating it could generate a seemingly endless string of Rx interrupts and that might totally trash your transmitter.
SW:
The difference between your initial power up data string transmission and your subsequent data string transmissions is that you have just finished your USART initialization subroutine the first time.
Presumably, but perhaps erroneously, one of the setup parameters was somehow trashed on the final exit of the Tx  Data ISR and the PutChar routine.
In theory it shouldn't make a difference, but what happens if you disable interrupts, rerun your InitSoftwareUart routine, and then re-enable interrupts, AFTER your Main Loop's delay, before the code loops back to the PrintString instruction.
That would mimic the entry into the PrintString/PutChar / Tx ISR code as if it had been called via the initial, post power up, entry.
If that works, then we can focus on what got trashed when the Tx data ISR exited for the "final" time from the first time through.
Edit: Typos
Yes, I think that's key.
See EDIT 2 in #6
I am sorry to respond after long, but was busy today. Also the time zones may not be matching, I am in Bombay, India. My sincere apologies.
Awneil, I do not have a debugger, but will use the Atmel Studio 7 built in simulator. To check if there are issues with long delay_ms() loops, I have reduced the delay to 10ms. I have placed a putty screen capture snippet below:
As you can see, the first two lines are perfect. Subsequent prints are a mess. But what can be observed is that all subsequent lines are identical. Does this ring any bells? If the strings are corrupted after every delay loop, should they not spew out different garbage in new lines?
But I will try to trace the flow and check the string locations in the simulator for any changes after the delay_ms().
Next, after all 8 bits are transmitted ( line 146), the STOP BIT is transmitted. This just pulls up the Tx line and changes state to TRANSMIT_STOP_BIT. When the next timer interrupt enters this state, it changes the state to IDLE and breaks, back to the main().  Now the delay loop starts. So, we can see that the state is placed in IDLE before the delay loop. Agreed, the time between the system entering IDLE and the execution of the delay loop is just a couple of instruction cycles, but it is there.
However, I will look at the program through the simulator and revert.
Just a thought: when the print_string function is called every time, does it not re-initialise the string? So even if the string is corrupted during the delay loop, will the function not set it properly again?
Sparrow2, I am using a standard Arduino Mini Pro, ATMega 328P, 16MHz. But I am using it as a bare board, not with Arduino IDE.
I will check your good advice to have the delay loop in between cli() and sei(). This will surely disable the interrupts during the delay execution, and enable after.
As mentioned in another reply, I will check out with the simulator, it should be a bit easy.
Yes, I am using the Arduino board, which has a 16MHz crystal.
so what about using a real UART for some debug output?
Maybe  it's always the same corruption that happens?
It seems that you leave the timer running after the end of transmission - I'd suggest you check that doesn't cause any problems ...
then how about getting an ATmega328p Xplained Mini - then you will have a debugger.
eg, https://in.element14.com/microch...
DocJC, the receiving data pin is INT0, enabled to generate interrupt on falling edge. But I am not using the system in receive mode at this juncture, so am I right in saying this may not matter? Or is there some "hidden" hardware / software issue here? The receive part begins only with an INT0 falling edge, which is not the case here.
"The difference between your initial power up data string transmission and your subsequent data string transmissions is that you have just finished your USART initialization subroutine the first time.
Presumably, but perhaps erroneously, one of the setup parameters was somehow trashed on the final exit of the Tx  Data ISR and the PutChar routine."
Yes, this will come out when I run through the simulator. Now that the delay is reduced, the simulation may not take too long. Also I only have to check the first time after the delay loop to know whether the string is corrupted.
"In theory it shouldn't make a difference, but what happens if you disable interrupts, rerun your InitSoftwareUart routine, and then re-enable interrupts, AFTER your Main Loop's delay, before the code loops back to the PrintString instruction."
Doing the above may not help if the string is corrupted. It will still stay corrupted.
This shouts to me you are not converting your temperature value from it's binary value to an ASCII (printable) value before sending it to the terminal.
As your terminal only displays ASCII values, you need to convert your data to ASCII.  Perhaps using itoa() function before sending out the USART(soft or hard)!
Keys to wealth:
I will look at this debugger.
As your terminal only displays ASCII values, you need to convert your data to ASCII.  Perhaps using atoi() function before sending out the USART(soft or hard)!
Jim, I only want to check if the text strings are printed out correctly. In the present code, I am not measuring the temperature. Of course, I will use the proper functions to convert the temperature readings into proper strings.
It is a good idea, I will use the UART after the delay loop to print the strings. This will provide proof if the strings are indeed corrupted.
Note that it's not just a debugger - it is a complete development board, with built-in debugger/programmer.
See https://www.avrfreaks.net/forum/xplained-mini-mega328pb for examples
I would simplify this code:
to this:
TCCR_P = 0; // Reset prescaler counter.
TCCR_P = ((1 << WGM21)|( 1 << CS21 )|( 1 << CS20 )); // CTC mode. Start prescaler clock.
and see what happens.
Keys to wealth:
I'm confused. The code actually says:
	for (;;)
		_delay_ms(1000);
So on the output we might expect to see:
Temperature:
Temperature:
Temperature:
Temperature:
There isn't actually any code there (that I can see) that would be attempting to print an actual temperature value at all.
So presumably those corrupted lines are the actual text "Temperature: " after it has been corrupted?
That would then lead to the question "exactly where in memory are the letters 'T-e-m-p-..." located ?". As it's the parameter to:
then C will start with a copy of those letters in flash. But during initialisation they will be copied out to RAM and then the parameter to the function call will be the address in RAM where they are now located. Something is presumably writing to those locations?
So then you would wonder what mechanisms exist in the code to make memory writes. Each time you see:
something = value
then if the location of something (often an uninitialised pointer) were corrupt then it could well accidentally hold the location in RAM to which Temperature had been copied.
But when I look at the code and every = assignment in it I cannot immediately spot any that might be writing to a rogue location.
Next to consider is often "has the stack crashed into .data/.bss?" but for that to happen you either have to have heavy memory allocation or recursivity or a stack inbalance or something that might cause it but, again, I don't see that.
Another common way to "corrupt stuff" is as soon as you stop using C and start embedding asm() sections without a total understanding of what it might be doing. But again I cannot see examples of that.
So it's a bit of a mystery but perhaps someone else can spot one of these things going on (for example the #define's of common symbols then a write through those can sometimes cause problems if a level of indirection is missed).
But anyway I would be concentrating on trying to understand where "Temperature :" ultimately resides and then what may be writing to the location.
Just to see if there is a correlation between "Temperature" and the rest of the lines can you show the hex values of what you receive.
It seems that you receive the \r\n correct !
it looks like a false start bit or too short stop bit or ???
No, there isn't - he hasn't done that bit yet:
Other than data corruption, My guess is it's something to do with the timer being allowed to "free run" during the delay; and/or not being properly re-synced/re-started for subsequent iterations of the 'for' loop ...
	for (;;)
		_delay_ms(1000);
Temperature:
Temperature:
Temperature:
Temperature:
something = value
Yes Clawson. The string "Temperature: " (without quotes) is located at 011B to 0128 in RAM. Using breakpoints at proper locations in the code and running the program, I could not see any corruption in this string.
It seems there is some timing problem as others have mentioned, which is consistent, since the subsequent lines all have same bytes in the strings.
I removed the software delay (_delay_ms()) an used the Timer1 in CTC mode for delays. Here too the same issue occurs. This means there is some timing changes that happens after a delay.
I will have to check the codes in depth and see what I can do. This issue has to be resolved so that we can use software uart when we are short of the AVR's UART.
A really stupid question:
What is the level of your RX pin ?
(if that is constant low(start bit) I think it could make a mess).
Not necessarily a change in the timing itself - possibly just that you start at the "wrong" point in a timing cycle ... ?
I am not using the receive mode. But it is pulled up.
I have attached a Realterm capture snapshot as below. One can see the consistent wrong hex characters after the first line is properly output.
If the start point in the timing cycle is wrong, then the bytes should relate, either by left shift or right shift. E.g., the first byte which is supposed to be 0x54 ('T'), should be either 0xA8 (if <<)  or 0x4A (if>>).
This is because the wrong bytes are consistently wrong, not random for each line. Hence timing shifts should be consistent. This is my logic, which may be corrected.
Well, that's a hypothesis - now you need to test that hypothesis: http://www.8052mcu.com/faqs/120313
A quick look :
It looks like the byte are shifted 2 places down.
Why don't you simulate it ? (TX is easy), then get the time between each bit, and is speed really don't matter perhaps make 2 stop bit so you are sure you don't start to early.
It is interesting that after the first line is printed, ending in <cr><lf>, every line after that ends with <sp><sp><cr><lf>, yet in the program posted, there is no <sp><sp> shown, on the <cr><lf>?
Where are these two spaces coming from?
Keys to wealth:
If your needs are as simple as you say, why go through all the extra work of trying to get a timer/interrupt system involved when something real simple would work-
https://godbolt.org/z/ox3Eaq
Tested on a tiny3217, changed a few lines of code.
and a version that can print out to every pin you have-
https://godbolt.org/z/4ncTx5
Testing whether the string literal is corrupted should not be too hard even without a debugger.
Use it to initialize a const array.
Pass it to a function in a separate file.
If the array does not have the correct data,
the function can blink an LED at you or something.
Hello. I used the AVR's USART to transmit the same string. I placed the function UART_SendString("Temperature: "); just after the software uart print_string("Temperature: "); instruction.
I find that the USART's output to Realterm is proper, while the software uart's output is still jumbled. So it is confirmed that there is some timing issue with the software uart once it comes back after a delay loop.
Some queries:
1. Even though the s/w uart output is jumbled, it is consistent for all time the printing is being done. Please see the Realterm screen shot sent before. I checked on the AS7 simulator, there seems to be no issue.
2. Without the delay loop, the s/w uart output is proper as mentioned before.
3. There is no issue with the baudrate. If there was, the jumbled output would not be consistent.
I have to use the AVR USART to send information to ESP-01 (with AT command set) and then on to the Thingspeak cloud. So this USART cannot be used to send data to a terminal. I have to use the s/w uart.
Any ideas on what is going on?
Regards.
could be a limitation of the simulation - would be better to check in real hardware
Not necessarily; if it were a fixed baud rate error, it could produce consistent wrong output.
Or choose an AVR with sufficient hardware UARTs in the first place?
I'd still be looking into a state thing - the delay means you're catching something in the wrong state; eg,
In #34, sparrow2 wrote:
A quick look :
A quick look :
Bytes shifted two places "down". Please elaborate, down = left shift or right shift? I did check some time back, but cold not find any sequence. But I will check again.
I will try to rewrite the code without a state machine concept. Then I will check.
There's no need to quote the entire post just to refer to one line:
https://www.avrfreaks.net/forum/man-forum-how-reply-post-forum
"down" = "towards the lower end" = to the right.
So what does this mean ?
Have you debugged the code with the simulator ?
set a breakpoint everywhere the uart tx pin can change, run your code, and if nothing else (timers etc.) then write down the numbers of cpu clocks there are between each bit, and the letter itit try to send.
from that it should be relative easy to see what is wrong.
Do you actually need to use RX ?
The simple code in #36 will work, either the pin specific version or the any/multi pin version. Difficult to do software serial with other interrupts running, so really no need for an interrupt version for sending as you will most likely be blocking anyway.
I'm not sure if anyone reads the links I post, but this is what the pin specific version is doing-
//atmega328p, PD6
static void txHigh  () { PORTD |= 1<<6; }
static void txLow   () { PORTD &= ~(1<<6); }
static void txIdle  () { DDRD |= 1<<6; txHigh(); } //output, high
//FILE put compatible
static int txPut(char c, FILE* f){
    txLow(); //start 1 bit low
    __builtin_avr_delay_cycles( F_CPU/BAUD - 3 ); //tweak -3 as needed
    for( u8 i = 0; i < 8; i++, c >>= 1 ){
        if( c & 1 ) txHigh(); else txLow();
        __builtin_avr_delay_cycles( F_CPU/BAUD - 8 ); //tweak -8 as needed
    txHigh(); //stop 2 bits
    __builtin_avr_delay_cycles( F_CPU/BAUD *2 );
    return 0;
Quite simple. Adjust the -3 and -8 to account for time that is not part of the delay. If other interrupts are being used, then they need to be disabled via the global irq before printing. The printing blocks until done. As #36 links show, you can easily interface to vfprintf.
sparrow2 wrote:
Just to be sure
which chip ?
ATMega328P, Optimisation at -O1
I am testing the code with AS7 simulator. I tried
- using Timer1 in CTC mode to generate the delay using ISR.
- before the delay I put cli() and after delay I put sei().
The results are consistently same.
One observation I always made is that the CR/LF non printable characters are correct. In fact the correct hex codes are displayed. But all printable characters are not correct.
again what is the time between each change of the TX pin, some timing must be off. (we know that the basic logic is correct)
I checked the stopwatch on the simulator for each bit sent out. It is about 104 microseconds @ 9600 baud. This is correct.
sparrow2 wrote:
A quick look :
I checked this possibility. Please see the following for just the first few chars:
Char   on terminal       >>2          Proper ASCII
T          AA                   2A               54
e          59                   16                65
m         5B                   16                6D
I cannot see any pattern in this. Can anyone "see" some clues?
I did use AS7 simulator. The bits on PORTD6 seem fine for each iteration. It is a bit tedious and confusing to breakpoint the entire string. So I will try to print just one char 'T' and check.
I have seen the code mentioned in the link you sent & will try this out. I have to understand the FILE concept, which I will do. Thanks.
Since you seem to want to make the irq version work...
You should probably clear the timer interrupt flag before enabling the timer interrupt. Since the timer is still running, the flag is getting set unless you are quick enough to get back to putChar (no delay in use). Since the flag is set, you get an isr firing sooner than you planned.
  state = TRANSMIT;
Yep - that's exactly the kind of thing I was getting at ...
Since the T also is wrong you don't need to change anything. (you should already have found the error by then).
    ...... (rest of the putchar() code)
[\quote]
Thanks Curt. If you see the code the timer interrupt is disabled after the stop bit is sent out. The code snippet is as follows.
  break;
So the interrupt is disabled and enabled again in the putchar() code. Hope this clarifies.
To trace the problem, it is simpler to output just one char. It may be that the issue is with a large number of chars being printed. Sounds illogical, but let me check. I can also use my oscilloscope to see one char easily in single sweep mode.
The timer is still running, though. Since it is running, a compare match sets the compare flag. And since the flag is set when the irq is enabled again, you will get to the isr as soon as you enable the irq, and what you thought was going to be a 1 bit time wait, is now no bit time wait.
It does seem odd they could put out appnote code that has this problem, but it seems so unless I'm missing something obvious.
Please let me know if I understood yo correctly. The putchar() code is:
  state = TRANSMIT;
Here, the timer is reset and started before the timer interrupt is enabled. So the timer is already running. Now, if we clear the interrupt flag just before enabling it again, how will that help? The timer is already running and few microseconds have passed before the flag if cleared and set again. I understand clearing the interrupt flag does not affect the timing?
+1
so perhaps entry to IDLE should stop (and reset?) the timer?
It seems like I'm doing too much explaining, so must not be making it very clear.
Timer is still running while you delay.
On a compare match, compare flag is set. Doesn't matter that the irq is disabled. A match sets the flag.
Now, back to putChar for some more printing-
You clear TCNT to 0.
OCR is set to give an irq in 1 bit time.
The timer irq is enabled.
problem here- the timer flag is already set so we jump to the isr here instead of waiting until the tcnt/ocr match
I feel you are right Awneil. There is no IDLE state in switch statement. The IDLE state is merely to dictate that no char may be written if not in this state.
I think I may have to rewrite the code to include IDLE handler or look at the code mentioned by Curt in the link  https://godbolt.org/z/ox3Eaq
I understand. How will it be if I stop the timer before the delay loop and let putchar() restart it? Also, I can disable the interrupt flag itself. I will check the code and try. Effectively:
- stop timer, clear flag, disable timer interrupt
- delay loop
After the delay, when the program goes to execute the code, the time will start again. Would this be right?
Add the clearing of the flag, Try it. It either helps, or it doesn't.
If other irq's are in use, you can surround this function with saving/disabling/restoring interrupts. That would at least allow interrupts to fire between chars.
    u8 sreg = SREG;
    asm("cli");
    __builtin_avr_delay_cycles( F_CPU/BAUD - 3 ); //tweak as needed
    SREG = sreg; //timing no longer important
    __builtin_avr_delay_cycles( F_CPU/BAUD *2 ); //not important if takes longer
    return 0;
Ok Curt. I will fist try to edit my code. Else I will work on the code you mention. Anyway, I have to get it working. I am looking at more projects where I will need a soft uart.
Thanks.
Wouldn't it make more sense to have the end of your stop bit handling stop the timer?
Right. I can do so easily. Also, to be sure, clear the timer flag & interrupt.
It make totally sense with a hanging ISR, that way there will be no start bit (yes but shorter than 1/2 bit time).
So some of the low data bits become the start bit.
My guess is that this is written for the mega8 and works, then the mega328 is added and some of the ISR things is working a bit different.
Hello all. After due consultations with yo all, the issue seems to be solved. As suggested by Curt & Awneil, I have stopped he timer, cleared the OCR flag bit, disabled the OCIE interrupt after the TRANSMIT_STOP_BIT.
The code snippet is shown
 // Go to idle one bit time after stop bit was sent. This ensures one stop bit.
	TCCR_P &= ~(( 1 << CS21 )|( 1 << CS20 )); // Reset prescaler counter, stop timer.
	CLEAR_TIMER_INTERRUPT( );			//reset OCR flag bit
  break;
I have removed cli() and sei() from before and after the delay loop.
After building the code, I checked the output, it is proper now. I have also tried this at 38400 Baud ( it was at 9600 Baud first). All ok for now.
Thanks a lot to all the experts who assisted in solving the issue.
Great - thanks for feedback.
Please mark the solution - see Tip #5:
