Debouncing several inputs in Arduino world
8 posts / 0 new
Hey All,
I have 4 digital inputs connected to my UNO.  I want to do a little debouncing(oh goodie here we go again), but from what I see in the Arduino examples, they show a single input sitting in the main loop and the code runs through that code.
I am thinking I could sense the input state change, and then pass the ID of the input I am monitoring to a function and have the function do the debounce and then activate a BOOL flag to be returned to the main loop for processing....
Am I making this more complicated than it needs to be?
EDIT:
For reference:
https://arduinogetstarted.com/tu...
so something similar to the ezButton() function in the example reference?
Flyover Jim
Keys to wealth:
OH HELL!!!
In my near sightedness I did not scroll down far enough.
That will work for now.
THANKS!
Thanks for the reference, I've added that to my library too! smiley
Keys to wealth:
I'm not saying it's great but I wanted debounced buttons here:
https://github.com/wrightflyer/s...
Some of the pins are bouncy buttons (for example):
///////////// PORT A //////////////
DualJoystick joy(0, 1, 64); // on A0/A1
// A2 - unused
Button  butJoy(&PORTA, 3, Button::NO_PULL_UP);
Button  but1(  &PORTA, 4, Button::NO_PULL_UP);
Button  but2(  &PORTA, 5, Button::NO_PULL_UP);
Button  but3(  &PORTA, 6, Button::NO_PULL_UP);
Button  but4(  &PORTA, 7, Button::NO_PULL_UP);
Each uses:
and
That relies on the main() code also doing:
    tim.start(64);
    tim.attachInterrupt(Timer0::TIM0_COMP_ISR, timerUpdate);
and then my ISR callback is:
void timerUpdate(void) {
    enc1.intUpdate();
    enc2.intUpdate();
    enc3.intUpdate();
    enc4.intUpdate();
    enc5.intUpdate();
    enc6.intUpdate();
    enc7.intUpdate();
    enc8.intUpdate();
    but1.update();
    but2.update();
    but3.update();
    but4.update();
    but5.update();
    but6.update();
    but7.update();
    but8.update();
The update code being run for each button is then:
// this called back from timer interrupt.
void Button::update() {
    uint8_t in;
    in = *mPIN;
    //printf("raw=%02X ", in);
    in = in & mPinMask;
    //printf("masked=%02X, prev=%02X\r\n", in, mPrev);
    if (in == mPrev) {
        mCount++;
        if (mCount >= 4) {
            //printf("state=%02X\r\n", in);
            mState = in;
            mCount = 0;
    else {
        mCount = 0;
        mPrev = in;
Because the class for each button holds a "prev" state fort the button and a "count" then it just compares current state with prev state and counts how many times it has seen that - if more than 4 consecutive inputs the button is pressed.
Now sure this is not as slick as Danni/Lee's solutions for bouncing which pack multiple button states into bytes and so on. This class wastefully holds a whole byte for each of:
    uint8_t mCount;
    uint8_t mPrev;
    uint8_t mState;
but the advantage is that you can instantiate as many of these as you have buttons and each instance of the class independently just handles the "memory" of each individual button. But it's not efficient and could most easily be described as wasteful. But it is simple and does the job.
Interesting way to do this Cliff.
I think for what is happening here, I will go with 'other Jims' find.  That I missed.
I like to do it the way the original Nintendo did, with a shift register.  Poll the shift registers at 50Hz and you've got a 20ms debounce filter.  10ms is usually sufficient.
Whether you use a shift or inc/dec, its probably much the same cost. Using a downcount, the test becomes a breq rather than a compare. Swings and roundabouts really.
