Help with ASM, and compare and rol.
11 posts / 0 new
I'm missing something fundamental here, looking for some advice.
I have a byte where I need to check the last bit for 1 or 0 and choose a path, then shift that bit off. Thinking a register pair would work with a rol but currently my data is in r16.
Here was my attempt.
mov r19, r16 //move data from r16 to r19
andi r19, 0x80  ; and the last bit , result goes in r19 ?
 cpi     r19, 0     ;     //check if its a 0 or 1.
 breq sb_send0%=; //path for 0
 rjmp sb_send1%= ; //path for 1
later on do a
 lsr r16
The above does not seem to work, is there faster/better way to do this operation?
you can do
sbrs r16, 0
rjmp was lo
rjmp was hi
to get rid of the bit (shifting) just  do:
lsr r16
if 2 bytes (shifting, working 16 bits) do
lsr r19
ror r16
after the single byte lsr shift or compound 2-byte ror shift, you could test
brcc  was_low
rjmp was_hi
Will always be 8bit in this case.
sbrs r16, 7    would skip if value was 0x80 right? And I'd want to shift left, in this case.
visual exmaple...
Starting with 100100
test the 7th bit go to lable:  sb_send1%=
shift it off 001000 remains
sbrs r16, 7
breq sb_send0%=
rjmp sb_send1%=
lsl r16
FYI, ANDI sets (or clears) the Z bit in SREG, depending on the result of the ANDI operation, So, you do not have to test the result against zero. It is already there in SREG. Then you can use either BREQ or BRNE to branch based on the value of Z. That is one of several ways of doing it with fewer instructions.
You live a dangerous life!
yes 0x80, and 0x81, and 0xE7, 0xA9,  etc ...many skip...don't overlook that (when it detects 0x80, machine will dispense $100 winnings
I will add to #4
You have to go thru the instructions ad get a clear picture of witch flags in SREG the instructions change and the name for the branches that correlate.
(if you aren't used to signed 8 bit I think that the S flag will be last to master.)
About #5
OP wants to to check highest bit so he and the rest off, so just check for high bit is fine with SBRS R19,7
But for the code in #1 you don't need r19 for anything this code will solve the same problem:
or r16,r16 ; don't change r16, but update flags
brmi L1    ; jump if bit 7 set
;code for cleared here
lsr r16
edit error in code
add: the code above don't change the Carry flag.
An other way is code that does.
you want to check if bit 7 is set or not, that also means that if you subi 0x80 from r16 the carry flag now hold the info you want if the value was below 0x80 you had to borrow and Carry would be set, so if Carry cleared the bit was set. Now you don't want to sub $80 from r16 so you do a cpi  with 0x80 so the flags get's updated but not r16 :
cpi r16,0x80
brcc ; bit 7 was set
; here if bit 7 was cleared
lsr r16
I would probably do:
   lsl r16
   brcs sb_send1%   // bit was one.
   // bit was zero code.
Which merges the shift and the setting of flags based on the old register contents into one instruction (the MSB is shifted into the carry flag.  (but it might not be available if you wanted to look at it again.)
But honestly, I don't see why your original code isn't working, even if it's longer than needed.
OP want r16 to shift right ! not left
I also need the test before the shift.
This worked  best for me
lsr r16
if it was broken code it worked nicely :)
or r16,r16
brmi make_a_1%=
rjmp make_a_0%=
to be precise.
Good you solved it, and bit 7 is always easy to check for.
But if you want to learn ASM then perhaps also take a look BST, and then branch on the T flag, it's especially help full if you need to remember the result for a while.
