Hi! My goal was to "trig" start of ADCIF sequencer 0 with exteral pin by PEVC function. Let the ADCIF SEQ0 run at ful speed and save a number of sampels with PDAC function from two ADCIN channels. The setup that I have done works almost as I want. The 10 sampels is collected and the PDAC interrupt works but I have to schift level on the external pin 10 times to get my 10 samples and the PDAC interrupt. Anyone! can I achive the function that I want or do I need to configurate ADCIF, PDAC or PEVC in an other way? "Free Running Mode" on ADCIF SEQ0 do not help either.
// Size of the string to transfer from ADCIF to memory through the PDCA #define STRING_TRANSFER_SIZE 10 // Number of samples for one ADCIF channel #define ADCIF_CH_IN_USE 2 // ADCIN0 and ADCIN1 is used #define PDCA_CHANNEL_ADCIF 0 // Address of PEVC module volatile avr32_pevc_t* ppevc = &AVR32_PEVC; // PDCA channel volatile avr32_pdca_channel_t *pdca_channel; static volatile U32 u32PdcaIsr; // String to transfer ADCIF SEQ0 to memory through the PDCA. static volatile uint16_t aDataTransfered[ADCIF_CH_IN_USE*STRING_TRANSFER_SIZE]; // ********* PDCA Interrupts handler *********************************************** ISR(pdca_int_handler, AVR32_PEVC_IRQ_GROUP0, 0) { if (DBG_MODE_RS232){print_dbg("PDCA int handler!\r\n");} u32PdcaIsr = pdca_channel->isr; if( u32PdcaIsr & (1<<AVR32_PDCA_ISR0_TRC_OFFSET) ) { // Count the number of Transfer Complete interrupts. pdca_reload_channel(PDCA_CHANNEL_ADCIF, (void *)aDataTransfered, sizeof( aDataTransfered )); print_dbg("\r\n"); } } // ********** PEVC overrun and trigger Interrupt handler *************************** ISR(pevc_int_handler, AVR32_PEVC_IRQ_GROUP, 0) { if (DBG_MODE_RS232){print_dbg("PEVC int handler!\r\n");} int32_t i=0; for(i=0;i<PEVC_NUMBER_OF_EVENT_USERS;i++) { if(true == pevc_channel_is_trigger_interrupt_raised(ppevc, i)) { // An overrun on the channel Id=i occurred. // Clear the interrupt pevc_channel_clear_trigger_interrupt(ppevc, i); // if (DBG_MODE_RS232){print_dbg("PEVC clear interrupt\r\n");} gpio_tgl_gpio_pin(AVR32_PIN_PA08); // PA08, pin 11 } if(true == pevc_channel_is_overrun_interrupt_raised(ppevc, i)) { // An overrun on the channel Id=i occurred. // Clear the interrupt pevc_channel_clear_overrun_interrupt(ppevc, i); // if (DBG_MODE_RS232){print_dbg("PEVC clear overrun\r\n");} gpio_tgl_gpio_pin(AVR32_PIN_PA09); // PA09, pin 12 } } } // ********* brief Init PEVC ******************************************************* void init_pevc_PAD_2(void) { // Use external pin 9 (PA06) to trig start of ADCIF and SEQ0 // PEVC Event Shaper options. static const pevc_evs_opt_t PEVC_EVS_OPTIONS = { .igfdr = 0x0A, // Set the IGF clock to be clk_slow*2pow11 .igf = PEVC_EVS_IGF_OFF, // Input Glitch Filter off .evf = PEVC_EVS_EVF_ON, // Enable Event on falling edge, Low when SW pressed .evr = PEVC_EVS_EVR_OFF // No Event on rising edge }; // Need to Setup GPIO ash PEVC PAD EVT static const gpio_map_t PEVC_GPIO_MAP = { {AVR32_PEVC_PAD_EVT_2_1_PIN , AVR32_PEVC_PAD_EVT_2_1_FUNCTION} // PA06, pin 9 }; // Assign GPIO pins gpio_enable_module(PEVC_GPIO_MAP, sizeof(PEVC_GPIO_MAP) / sizeof(PEVC_GPIO_MAP[0])); // Register PEVC interrupts irqflags_t flags = cpu_irq_save(); irq_register_handler(pevc_int_handler, AVR32_PEVC_TRIGGER_IRQ, 0); irq_register_handler(pevc_int_handler, AVR32_PEVC_OVERRUN_IRQ, 0); cpu_irq_restore(flags); // Assign PEVC PAD 2 to ADCIF and SEQ0 if(FAIL == pevc_channel_configure(ppevc, AVR32_PEVC_ID_USER_ADCIFA_0, AVR32_PEVC_ID_GEN_PAD_2, &PEVC_EVS_OPTIONS)) { print_dbg("PEVC channel config failed!!!\r\n"); while(1); } // Enable the PEVC trigger interrupt. pevc_channels_enable_trigger_interrupt(ppevc, 1<<AVR32_PEVC_ID_USER_ADCIFA_0); pevc_channels_enable_overrun_interrupt(ppevc, 1<<AVR32_PEVC_ID_USER_ADCIFA_0); // Enable the PEVC channel "PDCA CHANNEL 0/1 ONE-ITEM-TRANSFER" pevc_channels_enable(ppevc, 1<<AVR32_PEVC_ID_USER_ADCIFA_0); } void init_pdca_adcif(void) { // PDCA channel 0/1 options static const pdca_channel_options_t PDCA_CH_OPTIONS = { .addr = (void *)aDataTransfered, // memory address .pid = AVR32_PDCA_PID_ADCIFA_CH0_RX, // select peripheral, ADCIF .size = (sizeof(aDataTransfered)/sizeof(uint16_t)), // transfer counter, number of samples .r_addr = 0, // No reload address .r_size = 0, // No reload counter .transfer_size = PDCA_TRANSFER_SIZE_HALF_WORD, // 16-bit transfer .etrig = false // No event trigger }; // register Register interrupts irqflags_t flags = cpu_irq_save(); irq_register_handler(pdca_int_handler, AVR32_PDCA_IRQ_0, 0); cpu_irq_restore(flags); // PDCA Init. // Init PDCA channel with the pdca_options. pdca_init_channel(PDCA_CHANNEL_ADCIF, &PDCA_CH_OPTIONS); pdca_channel = pdca_get_handler(PDCA_CHANNEL_ADCIF); // For use in the pdca interrupt handler. // Enable pdca transfer error interrupt & transfer complete interrupt. pdca_enable_interrupt_transfer_error(PDCA_CHANNEL_ADCIF); pdca_enable_interrupt_transfer_complete(PDCA_CHANNEL_ADCIF); // Enable the PDCA. pdca_enable(PDCA_CHANNEL_ADCIF); } // ********************************************************************************** // For ADC converter setup for sequencer 0 adcifa_opt_t adc_config_t; adcifa_sequencer_opt_t adcifa_sequence_opt; adcifa_sequencer_conversion_opt_t adcifa_sequence_conversion_opt[ADCIFA_NUMBER_OF_SEQUENCE]; volatile avr32_adcifa_t *adcifa = &AVR32_ADCIFA; // ADCIFA IP registers address int16_t adc_values[ADCIFA_NUMBER_OF_SEQUENCE]; // For "print_dbg" function // Assign and enable GPIO pins to the ADC function. gpio_enable_module(ADCIFA_GPIO_MAP, sizeof(ADCIFA_GPIO_MAP) / sizeof(ADCIFA_GPIO_MAP[0])); // Configure the ADC for the application adc_config_t.frequency = 1500000; // ADC frequency (Hz) adc_config_t.reference_source = ADCIFA_REF06VDD; // Reference Source, Internal 0.6*VDDANA ref adc_config_t.sample_and_hold_disable = false; // Disable Sample and Hold Time adc_config_t.single_sequencer_mode = false; // Single Sequencer Mode, adc_config_t.free_running_mode_enable = false; // Free Running Mode adc_config_t.sleep_mode_enable = false; // Sleep Mode adc_config_t.mux_settle_more_time = false; // Wat is this??? // Get ADCIFA Factory Configuration adcifa_get_calibration_data(&AVR32_ADCIFA, &adc_config_t); // Calibrate offset first, CPU clock must be running adcifa_calibrate_offset(&AVR32_ADCIFA, &adc_config_t, FPBB_HZ); // PB clock 32MHz // Configure ADCIFA core, CPU clock must be running adcifa_configure(&AVR32_ADCIFA, &adc_config_t, FPBB_HZ); // PB clock 32MHz // ADCIFA sequencer 0 configuration structure adcifa_sequence_opt.convnb = ADCIFA_NUMBER_OF_SEQUENCE; // Number of sequence, two ADCIN channels adcifa_sequence_opt.resolution = ADCIFA_SRES_12B; // Resolution selection adcifa_sequence_opt.trigger_selection = ADCIFA_TRGSEL_EVT; // Trigger selection, event adcifa_sequence_opt.start_of_conversion = ADCIFA_SOCB_ALLSEQ; // Conversion Management adcifa_sequence_opt.sh_mode = ADCIFA_SH_MODE_OVERSAMP; // Oversampling Management adcifa_sequence_opt.half_word_adjustment= ADCIFA_HWLA_NOADJ; // Half word Adjustment adcifa_sequence_opt.software_acknowledge= ADCIFA_SA_NO_EOS_SOFTACK; // Software Acknowledge // ADCIFA conversions for sequencer 0 // ADCIN0 adcifa_sequence_conversion_opt[0].channel_p = ADC_AIN0_RECEIVER_INP; // Positive Channel adcifa_sequence_conversion_opt[0].channel_n = ADC_AIN0_RECEIVER_INN; // Negative Channel adcifa_sequence_conversion_opt[0].gain = ADCIFA_SHG_1; // Gain of the conversion // ADCIN1 adcifa_sequence_conversion_opt[1].channel_p = ADC_AIN1_RECEIVER_INP; // Positive Channel adcifa_sequence_conversion_opt[1].channel_n = ADC_AIN1_RECEIVER_INN; // Negative Channel adcifa_sequence_conversion_opt[1].gain = ADCIFA_SHG_1; // Gain of the conversion // Configure ADCIFA sequencer 0 SEQ0 adcifa_configure_sequencer(&AVR32_ADCIFA, 0, &adcifa_sequence_opt, adcifa_sequence_conversion_opt); // Start ADCIFA sequencer 0 SEQ0 for ADC starting ADC conversion adcifa_start_sequencer(&AVR32_ADCIFA, 0); // **********************************************************************************
