Nope remainder is where you for example divide 13 by 3 and get the dividend 4 with a remainder of 1. 3 goes into 13 four times with 1 left over.
It's true that 13/3 can also be seen as 4.33 where the 4 is the integer result and the .333 (which represent the "remainder 1") is the fractional result but it would be wrong to refer to the .33 part of this as the "remainder".
These are measurements without counting INPUT and without BCD packing.
I am wrong now, and I was wrong also the first time I did the measurement:
my original version (V2) is AVG=50.532 Clks on 0-65535
my actual version (see bellow) AVG=51.98 Clks on 0-65535
Actual version has this code bellow:
add r16,r0
adc r1,r1
breq PC+11
; r1 can be 1 or 3
dec r1
breq PC+3 ; it means it was 1, but now is 0
inc r17
mov r1,SIX
add r1,SIX ; now r1 is SIX or TWELVE
inc r17 ; increment Quotient
add r16,r1 ; add SIX or TWELVE
brcc PC+3 ; possible one do-it-again on Carry resulted from last instruction
inc r17
add r16,SIX
; previous 13 instructions: min. 4 and max. 14 clk
and this is worse than V2 version:
lsr r1 ; r1=0 and possible 1 shifted to C
brcc PC+4 ; branch if zero (evident)
inc R17 ; increment Quotient(R1 was one)
add r16,SIX ; add SIX; because we INC Quotient
brcs PC-2 ; possible one do-it-again on Carry resulted from last instruction
; On previous 5 instructions
; if High(INPUT)>$A8 5 or 9 clk, depending on RB256
; if High(INPUT)<$A8 3 or 5 clk, depending on RB256
add r16,r0 ; we add Remainder on the old one
brcc PC+4 ; but if we have CARRY?
brcs PC-2 ; possible one repeat on Carry resulted from last instruction
; if there were 6 or 9 on previous paragraph we have only 3 clk here
; if there were 3 or 5 on previous paragraph we have 3 to max. 9 here
; so, this is somehow compensated (on both) to 6 to max. 15 clk
Were I can see that "min. 4 and max. 14 clk" is worse than "6 to max. 15 clk"
yes the 99 split works fine without correction for 65, the only errors are at 69 79 89 and 99.(I write 64 because the check is for that bit)
See #41 there are all the numbers.
Add:
One thing could actually be to make a version that don't use the HW mul. That will be slower (about 70-80 clk), but by far the fastest on on chips like tiny85.
Result in: R20:R19:R18:R17:R16 ( R0 is also used )
Max 74 & Min 56 Cycles and measured AVG=65.18
Used Code Segment memory 76 Words
The Unpacked version is less or equal than 74 Cycles.
Above modifications in Red, due to:
mov r0,r17 ;
add r0,r0 ; These are replacement for MUL ( +3 clk )
add r0,r17 ; as suggested by
add r0,r0 ; https://www.avrfreaks.net/users/...
sbc r19,r19 ; r19 = minus carry
MySecond Version on Two Bytes AVG under50 Cycles. (AVRe)
Tested.
; 3529736 Counter with program
; 393215 Counter run empty
; 3136520 Diffrence
; 47.86 Diffrence/65536 My Second Under 50 Cyles Average!
; uses 7 MUL's so it should be 43 Words length Min/Max 47/50
It was indeed a welcome pause to do the:
Atiny85 BCD UnPacked version.
I just tried a couple and got broadly similar answers for cycles in the simulator. I was a bit surprised that megas (MUL) actually return almost identical numbers to tiny.
The core code (itoa leads to ultoa_ncheck) is here:
I am reopening this post for a small, but important issue.
I am using the word "Remainder" as in a result of Modulo(Integer,1000).
In https://www.avrfreaks.net/commen...
You are using remainder as the decimal part of an integer division.
When I look at https://en.wikipedia.org/wiki/Re..., I might
think that I haven't incorrectly used the word.
Am I wrong?
TopNope remainder is where you for example divide 13 by 3 and get the dividend 4 with a remainder of 1. 3 goes into 13 four times with 1 left over.
TopSo, I just raised the problem to El Tangas:
"so the next digits pop up from the remainder just by mul with 10"
I think that's the decimal part of the result of dividing the
"Two Bytes" Number by 1000.
He multiplies the number by constant 256^3/1000;
that is multiplied by 256^3 and then dividing by 1000; he is making an unambiguous Approximation.
Thus, you have to round the Decimal part on very, very many divisions. It's normal.
The Problem is Remainder is an Integer, not a Fractional Number.
So, I thing here he was unintentionally misleading.
When you multiply by 10 the decimal part of a division it's obvious that the "next digits pop up".
This is not True about Remainder.
TopI was trying to understand El Tangas's algorithm, and I encounterd difficulties.
Than it poped my mind that maybe he's not meaning Remainder.
I think that many people are using Remainder as "the decimal part of a fractional number",
but it is not absolutely correct.
Thank you.
TopThat's right, I mean the fractional part, not "remainder" in a strict mathematical sense. Sorry if it caused confusion.
IIRC I used some kind of fixed point format.
TopI studied your algo. Though uses aproximation it's avg. just few fractions of Cycle faster than mine.
I tried hard to get one instruction faster on my algo, but in vain.
I guess aproximation works harder on many Bytes. I'll try there. :-)
I'll update all my sources, from time to time, on first post. (#1)
Thanks a lot.
TopAre you now talking about a 16 or 24 bit version , packed / unpacked and what is the number of clocks ?
Then I will see if I can solve at better way :)
For others yes I do this for fun, like a crossword, since we know it can be less than than 1% of the AVR's time there is no need!
TopI'm hopeless. I'm still at contest; can't abstain.
Still the Two Bytes; were I might have found something; though Not Sure Yet!
If you discount the BCD packing, on my 16 bit, I'm at 49,53 clk AVG. <---WRONG , it is 51.53
That's one instruction, and AVG will fall below 49.
Yes, I now I'll be up on MAX; but as I said: "I can't abstain".
Toptry this on debug, AS7:
ldi r16,low(01234)
ldi r17,high(01234)
it gives:
and without first zero:
ldi r16,low(1234)
ldi r17,high(1234)
gives:
01234 means Octal(1234) which equals Hex (29C). It seems that I got screwd up by this!
TopThese are measurements without counting INPUT and without BCD packing.
add r16,r0
adc r1,r1
breq PC+11
; r1 can be 1 or 3
dec r1
inc r17
mov r1,SIX
inc r17
add r16,SIX
"much ado about nothing"
TopDo you know the record on 24 and 32 bits?
TopNope.
And it will start to get crowded in the registers so perhaps it should include store result in RAM.
Top(FYI)
My "posted here" Three Bytes(24bit) version is AVG=145.76 from 00:00:00 to FF:FF:FF
My "posted here" Three Bytes(24bit) version is AVG=148.07 from FF:00:00 to FF:FF:FF
(it'll take hours to count from 00:00:00 to FF:FF:FF; it should thus be under 150 clk)
Top49.86 clk
My First Version on Two Bytes AVG under 50 Cycles.
Topnice job
Add:
TopYou made me do that nice job; and I'm very glad you did it!
You are right about 65; it was in my mind to change something in comment there, too.
But, I'm still searching on why can't I get one instr. faster. Can't move along until that hepens.
HW mul is very powerfull; I can make "a touch" on the subject, as a pause.
Yes, it would be a good thing to make a change in my thoughts; at least for a while.
TopGuess first "MUL by 6" can be relaced with something like:
add R16,R16
mov Rn,R16
add Rn,Rn
add Rn,R16
brcc ; check Carry
The rest can be done with with "my 12.5clk version"; see. #25 .
I'll try.
TopAVG 73.18 CLK
This is a DRAFT, still untested, but seems to work; I'll try to fasten and update.
Att. Removed. It is WRONG. Has 26200/65536 errors on output. I'll be back.
Replaced .DEF SIX=R18 with .DEF SIX=R19; because I was using R18!
Now works 0-65535.
TopOn an AVR you normally don't check for carry, but have a register that is zero, so you just ADC with zero (I always use R15, don't use R1 as GCC)
TopYes, this I'll have to learn.
It's just a rapid transformation; copy and paste ... Draft, No Deep Thinking. Please excuse.
Thanks.
TopSee Att. tested Atiny85 BCD Packed version.
Result BCD packed in R18:R17:R16
Used Registers: R0,R2,R3,R16,R17,R18
Max 83 & Min 65 Cycles and measured AVG=73.18
Used Code Segment memory 84 Words
I believe The Unpacked version will be Max<80 Cycles, also.
TopI'm doing the same but, Here I have both to:
- Increment Quotient
- Add Six to Remainder
And I know i spent few days optimizing this, 'cause the "below 50" uses this.
TopSee Att. retested Atiny85 BCD UnPacked version.
mov r0,r17 ;
sub R17,r19 ; add carry
TopIf this code
is replaced by
and nothing gets broken (I didn't check) a cycle may be saved.
TopI checked. This is finesse!
Top47.86 clk
My Second Version on Two Bytes AVG under 50 Cycles. (AVRe)
Tested.
; 3136520 Diffrence
TopPresumably, things like itoa() and printf() must be doing basically this - so has anyone looked at their implementations ... ?
TopNo.
We are speaking here about 65 ns (at 16MHz)! <-- There, in red, It was mistakenly written "S".
This is, I have to do it "because it is there" (was first uttered by Edmund Hillary when he and Tenzing Norgay conquered Mount Everest in 1953).
Added later: May be, some should see my "/1000" algo.
Toplowercase 's' for seconds.
(uppercase 'S' = siemens)
Tops= second. I do apologize for any inconvenience.
TopSeven for the Dwarven Lords, in their halls of stone.
TopI deleted the original post.
It was inappropriate.
TopSeven Units for Seven Quantities ... ?
Tophere was the answer back in 2016
So itoa() take about 875clk for 12345
(And since AVR's with and without HW take about the same time I guess it use a normal div routine.)
But perhaps the libs have changed.
Add:
if it's a signed or unsigned version don't really make a difference, (neg16 take 3 clk)
TopSo just the binary-to-BCD part should be a little less?
Topcited from "Eurythmics, Annie Lennox, Dave Stewart - Sweet Dreams (Are Made Of This) (Official Video)".
TopThe core code (itoa leads to ultoa_ncheck) is here:
http://svn.savannah.gnu.org/view...
Topbut that code use 32bit , there should be a 16bit version !?
TopFor the sake of the argument,
let us say that the Assembly Language is like a motorcycle
and other programming languages are like a car.
Now, if you are on a motorcycle you know that drivers may fail to see motorcycles in plain sight.
You may feel you want to ride a motorcycle or not,
but for me being on a motorcycle there is no point in arguing with someone who may fail to see me.
TopI have a 4-byte(32bit unsigned) version of about 170clk; hope I'll finish bugs and testing in the next days.
Is there realy a need for numbers larger than 256^4-1 = 4_294_967_295 ?
This post is about speed and anyone may question the need for speed.
As I've already already said,
nobody's compelled to do caving discovery or mind entertainment exercises.
TopPages
