USART Flow Control with Atmel Start ATSAMD51N20A
4 posts / 0 new
Hello everyone,
Does anyone know what the trick is to get UART data with flow control going?  When I configure Atmel Start to NOT use flow control (i.e. MODE = UART) I can see data being sent out on TX pin with the code below.  But as soon as I configure Atmel Start configuration of USART_0 to use flow control (i.e. MODE = UART with flow control) I no longer get any data being transferred and no interrupts fire.
The UART (with flow control) is connected directly to a Microchip RN41 bluetooth module.  I believe the wires are connected correctly (I've looked at it a million times to make sure, but something has to be wrong):
QFP100 package of MCU.
ATSAMD51N20A pin RN41 Pin
CTS - PA25 - pin 75 input RTS - pin 15 output
RTS - PA24 - pin 74 output CTS - pin 16 input
RX - PB21 - pin 69 input TX - pin 14 output
TX - PB20 - pin 68 output RX - pin 13 input
I paused the debugger during execution and read the TXPO and RXPO config bits in the CTRLA register.  And that looked good when I decoded it.  Is there anything I else I need to call when using the Atmel Start Framework to get flow control to work?
James.
#include "main.h"
volatile bool UartTxFlag = 0;
volatile bool UartRxFlag = 0;
static void tx_cb_USART_0(const struct usart_async_descriptor *const io_descr)
    /* Transfer completed */
    UartTxFlag = 1;
    asm("nop");
static void rx_cb_USART_0(const struct usart_async_descriptor *const io_descr)
    /* string received */
    UartRxFlag = 1;
    asm("nop");
static     uint8_t example_USART_0[12] = "Hello World!";
    /* Initializes MCU, drivers and middleware */
    atmel_start_init();
    // enable tick timer
    tick_init();
    // register callback functions which also enables the interrupt
    usart_async_register_callback( &USART_0, USART_ASYNC_TXC_CB, tx_cb_USART_0 );
    usart_async_register_callback( &USART_0, USART_ASYNC_RXC_CB, rx_cb_USART_0 );
    // usart_async_register_callback(&USART_0, USART_ASYNC_ERROR_CB, err_cb);
    // now enable uart
    struct io_descriptor *io;
    usart_async_get_io_descriptor( &USART_0, &io );
    usart_async_enable( &USART_0 );
    io_write(io, example_USART_0, 12);
    /* Super-Loop */
    while (1)
        uint32_t ii;
        tick_t ticks_now = tick_get();
        if( tick_get_diff( ticks_start, ticks_now) >= TICKS_500MS )
            gpio_toggle_pin_level( nLED1 );
            gpio_toggle_pin_level( nLED2 );
            ticks_start = ticks_now;
    } // super-loop()
} // main()
Hi James,
I am facing the same issue. Were you able to figure out the cause of this issue?
Saba
Saba
There are restrictions on the pins selected, check the datasheet 6.2.8 IOSET Configurations.
At least that looks like a problem in the original post.
/Lars
Thanks Lars,
That solved my issue as well as the initial design  had PADs configured with different IOSETS.
Saba
Saba
