Error unknown field 'pfnNMI_Handler' specified in intializer and 'pfnSVC_Handler specified in intializer'
8 posts / 0 new
Hi all,
I will take SAML22J16A to USB CDC boot loader by SAM-BA-MONITOR-ROMLESS but i found some error and it can not solve it.
please advice me to solve this problem or example code
So look at the code to which those messages relate.
Sounds like you're trying to initialise a struct, setting the fields by name (ie, using "designated initialisers") - but you've got the names wrong.
https://stackoverflow.com/questions/47202557/what-is-a-designated-initializer-in-c
So look-up the definition of the struct, and see what the correct names are.
EDIT
See this post https://www.avrfreaks.net/commen... on using the 'Output' window - instead of that error list view.
The messages in the 'Output' window would have given you a lot more information - including quoting the offending line, and pointing directly at where the error is.
The error is in the vector table.  I ma not sure why, but here is how the vector table works
1) The structure "DeviceVectors" is specified in samxxxxx.h, where xxxx is the chip you are using, for example my atsaml22 design includes saml22n18a.h,
2) An instance of the structure is declared in startup_saml22.c and each vector assigned to a function
3) The functions are aliased to Dummy_handler so they can be replaced by use functions.
The error saying that startup.l22.c is setting pfnSVCall_Handler, but that is not specified in the structure.
John Malaugh
@manasa: you can find that startup file in your Solution Explorer:
And see where the structure instance is created - and the .pfnSVCall_Handler element gets initialised:
If you right-click the 'DeviceVectors' struct name, you will get the 'Go To Implementation' pop-up:
Click that to get to the struct definition:
typedef struct _DeviceVectors
  /* Stack pointer */
  void* pvStack;
  /* Cortex-M handlers */
  void* pfnReset_Handler;
  void* pfnNonMaskableInt_Handler;
  void* pfnHardFault_Handler;
  void* pvReservedM12;
  void* pvReservedM11;
  void* pvReservedM10;
  void* pvReservedM9;
  void* pvReservedM8;
  void* pvReservedM7;
  void* pvReservedM6;
  void* pfnSVCall_Handler;
  void* pvReservedM4;
  void* pfnTRNG_Handler;                  /* 25 True Random Generator */
} DeviceVectors;
Indeed - but, from the above, pfnSVCall_Handler should be defined as an item in that structure.
So there must be something else wrong with the OP's Project!
@manasa: please do a 'Clean Solution', then a 'Build Solution', and then copy & paste the complete content of the 'Output' window.
Did anyone find a solution to this?
Just edit the startup .c file to match the current naming in the .h. Or create a new empty project and copy the startup .c file from that to your bootloader project.
/Lars
We never did find out from the OP what the actual problem was in order to solve it.
frown
@manasa never replied on that.
So perhaps you could do that - so we can see what's actually going on?
Or, perhaps, zip-up your project and post it?
Just note that this is not what the error in post #1 is saying, so some renaming of the struct members has occurred, easy to fix as mentioned.
/Lars
