ATTINY85 Magnetic Door Sensor (3xAAANiMh 1.2v)(RESOLVED)
62 posts / 0 new
#include <avr/sleep.h>
#include <avr/interrupt.h>
#include <RCSwitch.h>
const int sensor = 3;
RCSwitch mySwitch = RCSwitch();
void sleep() {
    GIMSK |= _BV(PCIE);                     // Enable Pin Change Interrupts
    PCMSK |= _BV(PCINT3);                   // Use PB3 as interrupt pin
    ADCSRA &= ~_BV(ADEN);                   // ADC off
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);    // replaces above statement
    sleep_enable();                         // Sets the Sleep Enable bit in the MCUCR Register (SE BIT)
    sei();                                  // Enable interrupts
    sleep_cpu();                            // sleep
    cli();                                  // Disable interrupts
    PCMSK &= ~_BV(PCINT3);                  // Turn off PB3 as interrupt pin
    sleep_disable();                        // Clear SE bit
    ADCSRA |= _BV(ADEN);                    // ADC on
ISR(PCINT0_vect) {
void initADC()
  ADMUX = (1 << ADLAR) | (0 << REFS1) | (0 << REFS0) | (0 << MUX3) | (0 << MUX2) | (1 << MUX1) | (0 << MUX0);
  ADCSRA = (1 << ADEN) | (1 << ADPS2) | (1 << ADPS1) | (0 << ADPS0);
void setup() {
initADC();
pinMode(sensor, INPUT_PULLUP);
mySwitch.enableTransmit(1);
mySwitch.setProtocol(1);
mySwitch.setPulseLength(401);
mySwitch.setRepeatTransmit(5);
void loop() {
    ADCSRA |= (1 << ADSC);
    while (ADCSRA & (1 << ADSC) );
    if (ADCH > 180)
      int state;
      state = digitalRead(sensor);
        if (state == HIGH){
          mySwitch.send(10107000, 24); //On
          delay(2000);
          sleep();
        else{
          mySwitch.send(10108000, 24); //Off
          delay(2000);
          sleep();
    else {
    mySwitch.send(10109000, 24); //low battery code
    delay(2000);
    sleep();
Is this code any good??
It suppose to be a door sensor that should send the state signal and then goes to sleep and wakes again when the interrupt pin changes.
I am not able to send the close command when i shut the door.
please help me :)
Welcome to AVR Freaks!
Does it send other commands? Is your wireless link even working? How have you tested it?
Hi and thank you for your response.
The 3 codes are being received by an ESP32 with OpenMQTTGateway installed.
That is connected to the Home Assistant & Node-Red.
I made an Node-Red RF433 "Filter" that does the magic with the code.
These 3 commands are the only 3 commands it will send ON/OFF/LOWPOWER | 10107000/10108000/10109000
When i open the door it will send the ON command, but when i close it, it does not send the OFF command
Maybe my code is not right and i needed a bit of a help.
is it possible the interupt pin only wakes the attiny up when the pin is high and not when low?
The voltage is measured by PB4/pin3 with the internal reference voltage.
And a MC-38 magnetic sensor is connected to the PB3/pin2.  [acts as interrupt]
Best Regards
danny
If that is the case, then it is most certainly code. I've not looked at it in detail.
I don't see what wakes it up. In most I have used, you need to set a wakeup source.
Do you know that the door sensor is properly reporting the door state?
Hi and thank you again,
the wake-up source is the mc38 magnetic sensor connected to PB3.
And yeah only the on state :)
regards
danny
Not sure what you mean by
only the on state
Does it not generate an interrupt when going from open to close?
It could be i have to check my wiring on the board, but before is do i wanted to make sure my code was alright :P
Maybe someone could see an error or so :)
I am quite new to this and im learning like crazy.
I have a long way to go :P
I have an attiny85 with an mc-38 magnetic door sensor and 1 rf433 transmitter module connected to 3 AAA battery's with a voltage regulator to keep it 5V as internal voltage reference
-the battery live wire is connected to the regulator and to the ADC2/PB4/Pin3
-the regulated 5v goes to the VCC [This is how i measure the battery status]
- The MC38 is connected to PB3/Pin2 - It should act as an interrupt
- The RF433 transmitter is connected to PB1 and vcc and gnd
When i go from close to open it works, but when i go from open to close it stops
it looks like it wont interrupt when i go from open to close
danny
If you put a volt meter on the door sensor line, what do you see when you open the door and when you close the door?
Door sensors tend to use magnetic reed switches. These don't bounce much, but they are STILL mechanical switches and mechanical switches DO bounce. This always creates problems when you try to use with interrupts. Cannot be confident but my hunch is that might be part of it. The IMPORTANT question is what your volt meter shows.
Is Arduino Pin3 the same as PB3? Just noticed, your last post. You say PB3/pin2. Yet you have the pullup turned on for Arduino pin3. Turn on the pull-up for the pin you are actually using. Then, I think it will work better
Yeah PB3 is fysical pin 2 :)
i thought sensor = 3  is sensor is PB3?
I will check with the volt meter :) but gotto go now to work:P
greets,
danny
As far as I understand,
Refers to the Arduino IO pin number. If it were PB3, there would have to be something to distinguish it from, let's say PA3 or PC3 (not that the Tiny85 has either of these). You have to visualize this in the context of a function that has to work with all of the Arduino boards. Note in the reference, below, the argument "pin" refers to "Arduino Digital pin number".
Reference
Syntax
pinMode(pin, mode)
Parameters
pin: the Arduino pin number to set the mode of.
mode: INPUT, OUTPUT, or INPUT_PULLUP. See the Digital Pins page for a more complete description of the functionality.
Returns
Nothing
Example Code
The code makes the digital pin 13 OUTPUT and Toggles it HIGH and LOW
void setup() {
  pinMode(13, OUTPUT);    // sets the digital pin 13 as output
void loop() {
  digitalWrite(13, HIGH); // sets the digital pin 13 on
  delay(1000);            // waits for a second
  digitalWrite(13, LOW);  // sets the digital pin 13 off
Thanks man for all your help :)
I removed the code and the function sleep is not used at the moment.
I added a buzzer to PB1 or just Digital Pin 1
and the sensor at PB1
This little code does the job at the moment and im going to improve it :)
#define INTERRUPT_PIN PCINT3
#define INT_PIN PB3
void sleep() {
    GIMSK |= (1 << PCIE);                     // Enable Pin Change Interrupts
    PCMSK |= (1 << INTERRUPT_PIN);                  // Use PB3 as interrupt pin
    PCMSK &= ~_BV(INTERRUPT_PIN);                  // Turn off PB3 as interrupt pin
void setup() {
   pinMode(INT_PIN, INPUT_PULLUP);
   pinMode(1, OUTPUT);
ISR(PCINT0_vect)
  if( digitalRead(INT_PIN) == HIGH ) {
  digitalWrite(1, HIGH);
  }else{
 digitalWrite(1, LOW);
void loop(){
bump
Not familiar with the ardreno code how interrupts work but typically you don't call the interrupt from the main loop the hardware vectors the pin change to the interrupt code
But anyway , Here is a sample code (GCC compiler)  not using interrupts. It polls the pin, waits 100 ms and then polls the pin a second time allowing for the bounce in mechanical switches.
Once it sends your switch code it waits in a loop until the pin is changed again, polling and then sleeping and continuing the while loop and sleeping if its still set or cleared for each state to allow for bounce.
If you use a hardware interrupt you would set a flag in the interrupt to signal the main loop the pin state has changed and the same code would then just be checking the flag variable instead of the pin port directly.
That flag would be declared using volatile keyword so it is only changed by the interrupt itself.
That way the switch code is only sent once for each state. Of course you can add switch code sending in the sleep loop to send every x seconds while waiting for the state to change.
int main()
		if( PINB = PINB & (1 << INT_PIN))
			delay(100);
		while(PINB = PINB & (1 << INT_PIN))
			enters_sleep();
		if ( !(PINB = PINB & (1 << INT_PIN )))
			delay(100);
			if (!(PINB = PINB & (1 << INT_PIN )))
			while(!(PINB = PINB & (1 << INT_PIN)))
				enters_sleep();
#define INT_PIN PB3
int timerhigh = 0;
int timerlow = 0;
void setup() {
  mySwitch.setPulseLength(320);
  external_interrupt();
ISR (PCINT0_vect){
  MCUCR&=~(1<<SE);
void external_interrupt()
  sei();                //enabling global interrupt
  GIMSK|= (1<<PCIE);    //Pin change interrupt enable
  PCMSK|=(1<<INTERRUPT_PIN);
void enters_sleep()
  MCUCR|=(1<<SM1);      // enabling sleep mode and powerdown sleep mode
  MCUCR|= (1<<SE);     //Enabling sleep enable bit
  __asm__ __volatile__ ( "sleep" "\n\t" :: ); //Sleep instruction to put controller to sleep
  //controller stops executing instruction after entering sleep mode
void loop() {
if( PINB = PINB & (1 << INT_PIN)){
 delay(100);
  while(PINB = PINB & (1 << INT_PIN)){
   enters_sleep();
if ( !(PINB = PINB & (1 << INT_PIN ))){
 delay(100);
  if (!(PINB = PINB & (1 << INT_PIN ))){
  while(!(PINB = PINB & (1 << INT_PIN))){
   enters_sleep();
I hope i understood it a little right.
Is this a bit what you meant?
My solution did work but i knew it was not perfect.
I am a real newbie and i am trying to learn this.
Please forgive me if i am a bit slow in some things.
thanks for your feedback
danny
Looks good, how is it working?
By the way you don't need the interrupt code, the code is reading the pin in the main loop.
If you do want to use an interrupt you need a function that gets control when the interrupt triggers. In that code you would have one line of code to set a flag variable. In the main loop then you would only have to
compare the flag variable if its 1 or 0 instead of reading the pin. You don't need an interrupt because this is all your code is doing, polling one pin. If you had all kinds of code doing all kinds of things
you could still get buy without an interrupt depending on how long you could wait for the main loop to call the function that reads the pin.
For example a microsecond  timer that starts and stops on a pin change where you want very accurate timing would need to use an interrupt on the pin change to immediately vector the code to the interrupt routine
and INTERRUPT the code running in your main loop at the next instruction where that code might store a time variable of exactly when the pin changed and then return to your main code as if it never happened.
Like an oscilloscope probe reading high and low signals for example needs very fast response.
Hi and thanks again,
yeah i actually forgot the
ISR (PCINT0_vect){
  MCUCR&=~(1<<SE);
I always thought you need an interrupt to wake from sleep.
I can test it without :)
I am going to test it today and will I will let you know :)
bump
bump
bump
I don't know how your sleep code works, I was assuming it might sleep for a few seconds and then return where the loop I had it in would again test for a pin change. Yes the other way is to use an interrupt to break out of sleep but adrino code I don't know how that works. When doing an interrupt you set the interrupt flag on and you also have code for what happens when the interrupt triggers, I don't see that code.
Here is an example (codevision compiler) of two interrupts being set up. The main program sets the proper bits to initialize the interrupts, the interrupt routines are executed when a hardware interrupt triggers.
#include <tiny45.h>
// Declare your global variables here
// Pin change interrupt service routine
interrupt [PC_INT0] void pin_change_isr(void)
//Code to execute on interrupt pin change
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
// Code to execute on interrupt
void main(void)
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Any change
// Interrupt on any change on pins PCINT0-5: On
GIMSK=(1<<INT0) | (1<<PCIE);
MCUCR=(0<<ISC01) | (1<<ISC00);
PCMSK=(0<<PCINT5) | (0<<PCINT4) | (1<<PCINT3) | (0<<PCINT2) | (0<<PCINT1) | (0<<PCINT0);
GIFR=(1<<INTF0) | (1<<PCIF);
// Globally enable interrupts
#asm("sei")
while (1)
      // Place your code here
These:
boolean wdt = 0;
int wdtcounter = 0;
MUST be volatile:
volatile boolean wdt = 0;
volatile int wdtcounter = 0;
Read:
to find out why.
Yeah i read it and thank you for this. :)
I will change it to volatile in the code
Hi metron,
thanks for your help, i am trying to understand what you mean :P
I have updated my solution every time since hoping someone could correct  my mistakes so i will learn more.
ISR (PCINT0_vect){
  MCUCR&=~(1<<SE);
is this the same?
MCUCR=(0<<ISC01) | (1<<ISC00); // this i did not see before and will check this in the datasheet thanks for the info
my int0 has nothing connected to, do I need this still?
thanks for all the help,
Danny
should i also use
uint8_t instead of int? oer does it not matter?
 if(wdt == 0){
  if ( digitalRead(INT_PIN) == HIGH){
    delay(2000);
     mySwitch.send(10109125, 24);
  while( digitalRead(INT_PIN) == HIGH ){
    enters_sleep();
  if( digitalRead(INT_PIN) == LOW){
    delay(2000);
     mySwitch.send(10109150, 24);
    while( digitalRead(INT_PIN) == LOW ){
     enters_sleep();
thanks for this 1 metron :)
Total votes: 2
degiel1982 wrote:
should i also use
Because it is so important that the software in cars does not have major bugs (imagine an ABS system that applied the brakes at the wrong time or a cruise control that could not hold the desired speed!) there is a body called The Motor Industry Software Reliability Association ("MISRA") that have drawn up an agreed standard across all the world's major motor manufacturers for how to write safe, reliable software. They effectively produce a "rule book" that says "when writing C you must do this, this and this and you must not do that, that and that". Among their many rules is one that says you should not use native C types unsigned char, signed char, unsigned short, signed short, unsigned int, signed int, unsigned long, signed long but must, instead, use the types defined in <stdint.h>. The AVR micro is actually a very good illustration of why this should be as it's unusual in that an in t is just 2 bytes and can either represet 0..65535 or -32768..+32767. So if someone wrote some code for one CPU where sizeof(int)==4 then brought that code to an AVR then a simple looking line like:
int n = 123456;
would not work on an AVR as intended. On the AVR 'n' would contain -7616. If the author had used:
int32_t n = 123456;
then whatever CPu that is built for n will contain 123456 because an int32_t will always accommodate the value 123456.
So, yes, my answer would be that you should always use <stdint.h> types. The one exception MISRA make is the type "char". Not everyone realises this but there are THREE types of char. They are "unsigned char", "signed char" and "char". If you were going to use unsigned/signed char you should use uint8_t/int8_t but if the variable really is holding characters like "char c = 'X';" then that is the one occasion you might use one of the base types.
https://bullwhip.physio-control....
https://uk.mathworks.com/help/bu...
https://lost-contact.mit.edu/afs...
bump
bump
CHANGED 27/02/21:
Watchdog(6 sec interrupt), 12 hourly voltage update
#include <SystemStatus.h>
#include <avr/power.h>
#include <avr/wdt.h>
#include <avr/delay.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define F_CPU 8000000
volatile long wdcount = 0;
boolean old = 0;
volatile boolean f_wdt;
volatile boolean first = 1;
void setup() {
setup_watchdog(8);
//All pins set to something
pinMode(0, INPUT_PULLUP);
pinMode(2, OUTPUT); // VCC RF Transmitter
pinMode(3, INPUT_PULLUP); //MC-38 Sensor
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
digitalWrite(2,LOW);
//rcswitch setup
 mySwitch.setRepeatTransmit(15);
void loop() {
 if(f_wdt ==1){
  f_wdt=0;
    if((wdcount == 5 && first ==  1) || wdcount == 43200){
      if(wdcount == 43200){
        wdcount = 0;
      if(first == 1){
        first = 0;
       //enable ADC
       ADCSRA |= (1 << ADEN);
       digitalWrite(2,HIGH);
       delay(500);
       int vcc = SystemStatus().getVCC();
       String strVcc = String(vcc);
       strVcc = "1110" + strVcc;
       long vcc2 = strVcc.toInt();
       mySwitch.send(vcc2, 24);
       delay(500);
  if ( digitalRead(3) == HIGH && old == 1){
    old = 1;
  if ( digitalRead(3) == LOW && old == 0){
    old = 0;
  if ( digitalRead(3) == LOW && old == 1){
    delay(500);
    old = 0;
    delay(500);
  if ( digitalRead(3) == HIGH && old == 0){
    delay(500);
    old = 1;
    delay(500);
  delay(500);
  system_sleep();
void system_sleep() {
  cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
  power_all_disable();
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
  sleep_enable();
  sleep_mode();                        // System sleeps here
  sleep_disable();                     // System continues execution here when watchdog timed out
  power_all_enable();
ISR(WDT_vect) {
 f_wdt = 1;
 wdcount++;
void setup_watchdog(int ii) {
  byte bb;
  int ww;
  if (ii > 9 ) ii=9;
  bb=ii & 7;
  if (ii > 7) bb|= (1<<5);
  bb|= (1<<WDCE);
  ww=bb;
  MCUSR &= ~(1<<WDRF);
  // start timed sequence
  WDTCR |= (1<<WDCE) | (1<<WDE);
  // set new watchdog timeout value
  WDTCR = bb;
  WDTCR |= _BV(WDIE);
Do you even know if your door sensor is 100% working?  Did you first try hooking it to an led (or drive an led pin from the avr) to verify it is at least showing both door opening & closing ?? That should be the first step.  If you don't know 100% find out.  Maybe you already did.
I did ;), it works it has been tested.
I still have to test the batterylife but it looks like it works.
even with fast on off switching it does not get bothered and updates to the right state until now.
It did not hang once or gave me the wrong state
The sleep mode is quite new to me and that is the only thing im not sure about if it actually works. but it does the 2 second time change so i guess so :P
I have no possibility yet to measure mAh or lower ( no good multimeter)
my next thought was maybe when the door sensor has for 1 minute the same state it wont wake up every 2 seconds but stays to sleep until maybe a pin interrupt has been triggered and go back to the 2 second timer sleep
So far so good!!!  On the 50th opening you will find 20 million cash behind the door.
lol i hope so :)
it could be possible i miss something while it is working. if somebosy notice please tell me
lol i found an issue :P
it seems that my old variable is not saved and stays at 0
is that normal when going to sleep mode? can i do something about this?
As  a moderator, I find your bumps very, very annoying. If you don't get answers within YOUR time frame... stiff luck. Others have lives that do not revolve around you. Learn to live with it.
thanks for your opinion :)
I bumped the messages because it was not important info and wrong code, not because I did not get any answers:)
I can understand you find it annoying and I'm sorry
maybe till next time :)
issue is btw resolved. i added it in the solution
Total votes: 2
CONTACT/PIR Sensor Code for ATTINY85 RF433 (3x AAA 1.2v Rechargeable Batterys)
NOTE IN ADVANCE:
I use a 3.3V Step-Up/Step-Down Voltage Regulator w/ Fixed 3V Low-Voltage Cutoff S9V11F3S5C3 from Polulu for my 5V and 3.3v projects
It also cuts off at 3V to save your battery when almost empty.
External Libraries used:
rc-switch
EnableInterrupt
-  AttinyCore SpenceKonde
Code:
#include <EnableInterrupt.h>
#define F_CPU 8000000UL
volatile boolean stateSensor = 0;
volatile boolean watchdogInterruptFlag = 0;
volatile int counter = 0;
volatile boolean firstVccReadFlag = 0;
volatile boolean previousSensorState  = 0;
const boolean device = 0;                           // 0 = Contact Sensor | 1 = PIR Sensor
const unsigned int deviceID = 1010;
const unsigned int openRFcode_P = 9250;
const unsigned int closedRFcode_P = 9225;
const boolean enableVoltage = 1;                     // Don't need voltage readings? turn this off
const unsigned int vccSampleAmount = 100;            // The first voltage reading is mostly not perfect. So here you can choose how many samples it should take before giving you an averaged result.
const boolean enableADC = 0;                         // When enabled it will read the voltage from pin (PB4) if you have enableVoltage enabled. When disabled it will read the internal voltage if you have enableVoltage enabled
float ADCVoltageRef = 5;                             // The voltage you give your attiny85 if you have powered yours with 3.3V then enter 3.3
const unsigned int voltageTransmission_Seconds = 0;
const unsigned int voltageTransmission_Minutes = 0;
const unsigned int voltageTransmission_Hours = 2;
const boolean enableWatchdog = 1;
unsigned long calculateTransmissionTime(unsigned int Seconds1,unsigned int Minutes1,unsigned int Hours1){
  unsigned int result1 = 0;
  result1= round(((Seconds1*1)+(Minutes1*60)+(Hours1*3600)) / (8));
  return result1;
const unsigned long voltageTransmissionTime = calculateTransmissionTime(voltageTransmission_Seconds,voltageTransmission_Minutes, voltageTransmission_Hours);
long stringify(unsigned int deviceID, unsigned int rfCode){
  String SdeviceID = String(deviceID);
  String SrfCode = String(rfCode);
  String SfullCode = SdeviceID + SrfCode;
  long  fullCode = SfullCode.toInt();
  return fullCode;
const unsigned long openRFcode = stringify(deviceID, openRFcode_P);
const unsigned long closedRFcode = stringify(deviceID, closedRFcode_P);
void sensorInterrupt(void){}
void initADC(){
  ADCSRA = (1 << ADPS2) | (1 << ADPS1) | (0 << ADPS0);
long samplingVcc(unsigned int sampleAmount){
  unsigned long sumResult = 0;
  unsigned int a = 0;
  if(!enableADC){
      ADMUX = _BV(MUX3) | _BV(MUX2);
      a = 0;
      do{;
        sumResult = sumResult + readVCC_Internal();
        a++;
      while(a < sampleAmount);
      ADCSRA &= ~(1 << ADEN);
      a = 0;
      sumResult = round(sumResult / sampleAmount);
      return sumResult;
  else{
    a = 0;
    do{
      sumResult = sumResult + readVCC_ADC(ADCVoltageRef);
      a++;
      a = 0;
      return sumResult;
long readVCC_ADC(unsigned int VoltageRef){
  float mvSteps = ((VoltageRef * 1000) / 256);
  int result;
  result = ADCH * mvSteps;
  result = round(result);
  return result;
long readVCC_Internal(){
  delay(20); // Wait for Vref to settle
  ADCSRA |= _BV(ADSC); // Start conversion
  while (bit_is_set(ADCSRA,ADSC)); // measuring
  uint8_t low  = ADCL; // must read ADCL first - it then locks ADCH
  uint8_t high = ADCH; // unlocks both
  long result = (high<<8) | low;
  result = 1126400L / result; // Calculate Vcc (in mV); 1126400 = 1.1*1024*1000
  return result;
ISR(WDT_vect) {
  counter = counter + 1;
  watchdogInterruptFlag = 1;
void sendRF(long rfCode){
  digitalWrite(2, HIGH);
  mySwitch.send(rfCode, 24);
  digitalWrite(2, LOW);
void goToSleep (){
  ADCSRA &= ~(1 << ADEN);         // turn off ADC
  power_all_disable ();  // power off ADC, Timer 0 and 1, serial interface
  sleep_enable();
  sleep_cpu();
  sleep_disable();
  power_all_enable();    // power everything back on
void setup() {
  if(enableWatchdog==1){
  setup_watchdog(9);
  mySwitch.setPulseLength(400);
  if(!enableADC){
  else{
    initADC();
  pinMode(2, OUTPUT);
  if(!device){
    enableInterrupt(PB3, sensorInterrupt, CHANGE);
  else{
    enableInterrupt(PB3, sensorInterrupt, RISING);
void loop() {
  disableInterrupt(PB3);
    if(!watchdogInterruptFlag){
      if(!device){
        stateSensor = digitalRead(3);
        if(stateSensor && previousSensorState==0){
          previousSensorState=1;
          sendRF(openRFcode);
          delay(1000);
          if(stateSensor){
            if(!enableWatchdog && enableVoltage){
              long voltageReading = stringify(deviceID, samplingVcc(vccSampleAmount));
              delay(100);
              sendRF(voltageReading);
            goToSleep ();
        else if(!stateSensor && previousSensorState == 1){
          previousSensorState=0;
          sendRF(closedRFcode);
          delay(1000);
          if(!stateSensor){
              delay(100);
            goToSleep ();
        else{
          goToSleep ();
      else{
        mySwitch.send(openRFcode, 24);
        goToSleep ();
   else{
      if(counter == 5 && !firstVccReadFlag && enableVoltage==1 && enableWatchdog==1){
        firstVccReadFlag = 1;
        delay(100);
        if(!device){
        else{
          goToSleep ();
      else if(counter == voltageTransmissionTime && firstVccReadFlag == 1 && enableVoltage==1 && enableWatchdog==1){
        counter = 0;
        delay(100);
        if(!device){
        else{
          goToSleep ();
      else{
        if(device){
          goToSleep ();
  byte bb;
  int ww;
  if (ii > 9 ) ii=9;
  bb=ii & 7;
  bb|= (1<<WDCE);
  ww=bb;
  WDTCR = bb;
  WDTCR |= _BV(WDIE);
PIR Sensor Schematic (5V with ADC)
MC-38 Contact Sensor Schematic:
finally done :P improvements in the code are helpfull, if someone would like :)
Hi all i have a question:
I wanted to set all pins to input what is possible when go to sleep and back to the original state when wake up.
Is it even possible to do that with the RF module pin 1?
Make it input then output?
thanks in advance
greetings
danny
Normally, in sleep, the pins stay the way they were. If you need some special pin condition during sleep, set the pin that way just before entering sleep.
Hi again and thanks for the reply.
void goToSleep (){
  DDRB &= ~(1 << PB2);
  PORTB |= (1 << PB2);
  cbi(ADCSRA,ADEN);
  sleep_enable();
  sleep_cpu();
  sleep_disable();
  power_all_enable();
  DDRB |= (1 << PB2);
  PORTB &= ~(1 << PB2);
did you mean something like this?
With my RF module i am not specifying the pin 1 as output or input. just enableTransmit(1)
I was hoping i could change that to input and back to enable transmit. only dont know how :)
Thanks for all the help.
Regards
Danny
This project is very interesting, may I ask if there is a video demonstration when it is completed?
Hey hello :), thanks for your reply.
Eventually I will do this. I am still not happy with the code...
I am almost done with the new approach and currently i am testing it, but looks promising.
When I am done i will make an instructable about it :)
Thanks for your interest, just give me a bit time :)
This is the screenshot i have from my Home Assistant
Hi again :)
My code has been updated :), the battery life has been improved a lot with this.
When my instructable is done I will post the link here :)
Now I need electrical help and I am a world noob in this.......
I need a reverse voltage protection and i heard and read about p-channel mosfets. Is this any good and which 1 should I actually use?
Thanks in advance.
greetings
danny
I have used the following simple circuit to protect from reverse polarity, but there is a gotcha, the diodes the current will flow through (two on each line) will drop the voltage. Standard diodes will drop 0.7v each but Schottky diodes will only drop 0.3v each.
Take a look at https://www.electronicdesign.com/power-management/article/21801509/reversepolarity-protection-in-automotive-design where they talk about single diode protection and P- and N-channel MOSFET protection, and then https://www.edn.com/protecting-against-reverse-polarity-methods-examined-part-1/ where they talk about several methods. The circuit I inserted above came from http://www.reuk.co.uk/wordpress/electric-circuit/reverse-polarity-protection/ where they describe its function in detail.
EDIT: Yes the above diagram looks very much like a bridge rectifier for converting AC to DC, but it doubles for polarity protection too.
Wayne
East London
South Africa
  • No, I am not an Electronics Engineer, just a 54 year old hobbyist/enthusiast
  • Yes, I am using Proteus to learn more about circuit design and electronics
  • No, I do not own a licensed copy of Proteus, I am evaluating it legitimately
  • No, I do not believe in software or intellectual property piracy or theft
First of all thanks for your reply and help :)
I did know about this 1 but I read about the power loss and voltage drop it has.
https://www.edn.com/protecting-against-reverse-polarity-methods-examined-part-2/
Here at Method 8: Series Mosfets they say it have the least power loss and my projects are all about battery life.
Only I dont get which mosfet I should buy or use for my projects :(
I dont get the technical stuff yet where to look at what info on the datasheet .
greetings
danny
BHAA-POL | Batteryholders.com | MPD | Batteryholders.com | MPD
Features reverse polarity protection
Any cell holders (polarized) for AAA?
Hello and thanks for the help,
Yeah I thought about it and maybe it is my lack of google searching skills but I can not find any with 3xAAA and where I can buy them. :)
But this would be indeed the best solution to have to holder make it impossible to reverse the battery
greetings
danny
... and not a single decoupling capacitor insight.
Hi again and thanks for your reply.
yes that could be, but as I stated before  " Now I need electrical help and I am a world noob in this......."
So you suggest me  a decoupling capacitor?
thanks for the info :)
Like this you mean?
thanks in advance
No. A 0.1uF cap directly between the ATTiny85's Vcc and Gnd pins.
Hi again,
I hope I get it right this time :)
I am googling and trying to understand it and hope I will.
Thanks for the help
should I also use 1 on the rf transmitter? I draw it just in case
Good for the ATTiny85's decoupling cap. But your transmitter will draw big "gulps" of current, so your 10uF cap placed very close to the transmitter's supply pins will help avoid interference to the ATTiny85.
PS. I don't see the supply connection to your transmitter. Just ground and, presumably, two  data lines back to the ATTiny85.
ps2. Bedtime for me.
Thank you very much :),
Lucky for me those are actually the 2 sizes I have in stock. :)
I also read somewhere that I also should use 1 together with a 4.7 K resistor at the reset pin. Is this any good?
I have my VCC of the transmitter on a OUTPUT pin that I enable/disable when go to sleep for power saving.
greetings,
danny
It will need some adjustments to my pinmodes, but I hope this is something useable :)
I hope I get it right.... The code is currently finished and I am reading like crazy about setting the unused pins.
I choose for external pull-ups.
How are you connecting power to the transmitter?
Hi again :)
I power the RF transmitter with a digital pin, whenever I set it to high in the code it will power the module and when low it will turn it off, someone suggested it to me once.
greetings
danny
This with the capacitor and powered directly to the vcc
