Multiple definition error
6 posts / 0 new
I have got the following files:
USART0_interrupt.h
USART0_interrupt.c
USART0_polling.h
USART0_polling.c
main.c
The files 'USART0_interrupt.c' 'USART0_polling.c' define the same functions. Even though I just include one header file via preprocessor directives in my main.c, I obtain the error 'multiple definition of ...'. If I remove one source file from the project, the code works. So why does the linker link a source to my program, even if it is not used?
Kind regards
Jimmy
As long as both *.c files are part of the "solution" then they will both be compiled and the linker will try to link them!
Remove the .c and .h files of the one your not using.
Did you get them from here:
AN_1451 - AVR306: Using the AVR UART in C on tinyAVR and megaAVR devices
As the application note explains, they give you code for both interrupt-driven and polled operation - you need to pick one.
It doesn't matter what headers you include. If you link 'USART0_interrupt.c' and 'USART0_polling.c' within a single program, you will get multiple definition errors (provided the identically-named functions have external linkage).
Dessine-moi un mouton
Indeed.
The headers just provide declarations - the error says definitions.
http://c-faq.com/decl/decldef.html
If you really want to have both interrupt and polled code in the project, with the decision controlled by preprocessor directives, then you also need to add that control to your .c files; eg,
USART0_interrupt.c
#ifdef USART0_INTERRUPT
// your interrupt-driven code here
#endif
USART0_polling.c
#ifdef USART0_POLLED
// your polled code here
#endif
How could it tell which one to choose - since they have identical names ?
