Comparing two preprocessor macros
12 posts / 0 new
#define DEV_PORT PORTC
#if DEV_PORT == PORTB
#define PCI PCIE0
#define PCMSK PCMSK0
#define PCINT_VECT PCINT0_vect
#elif DEV_PORT == PORTC
#define PCI PCIE1
#define PCMSK PCMSK1
#define PCINT_VECT PCINT1_vect
#else
#define PCI PCIE2
#define PCMSK PCMSK2
#define PCINT_VECT PCINT2_vect
#endif
compiler says:
operator '*' has no left operand
How should I check which port is the DEV_PORT in compile time? MCU is ATmega328P.
Slow and Steady!
pajuhesh80 wrote:
compiler says:
Where, exactly, does it say that?
The best way to see what's going on when you get problems with preprocessor macros is to look at the preprocessor output.
With GCC, use -save-temps:
https://gcc.gnu.org/onlinedocs/gcc/Developer-Options.html - search on that page for "save-temps"
from 2002: http://www.8052mcu.com/forum/rea...
BTW: rather than just an 'else' at the end of your test, I would strongly recommend that you have an "error catch":
#define PCI PCIE0
#define PCI PCIE1
#elif DEV_PORT == PORTE
#define PCI PCIE2
#else
#error Unsupported DEV_PORT
#endif
Then you won't get invalid DEV_PORT settings being defaulted to PORTE
The #if preprocessor conditional  will be flummoxed by
the definition of PORTB being something like (*(volatile uint8_t *)((0x05) + 0x20))
First thing that springs to mind is you could do something like the following (there may be other/better ways)
#define DEV_PORT_SELECT_PORTB 1
#define DEV_PORT_SELECT_PORTC 2
#define DEV_PORT_SELECT_PORTD 3
/* choose one of the above */
#define DEV_PORT_SELECT DEV_PORT_SELECT_PORTB
#if DEV_PORT_SELECT == DEV_PORT_SELECT_PORTB
#define DEV_PORT PORTB
/* other stuff */
#elif DEV_PORT_SELECT == DEV_PORT_SELECT_PORTC
/* other stuff */
#elif DEV_PORT_SELECT == DEV_PORT_SELECT_PORTD
#define DEV_PORT PORTD
/* other stuff */
#else
#error "DEV_PORT_SELECT not set"
#endif
    DEV_PORT = 0xff;
#define DEV_PORTC
#if defined(DEV_PORTB)
#elif defined(DEV_PORTC)
#elif defined(DEV_PORTD)
#else
#error "DEV_PORT not defined"
#endif
I was thinking about it also, but I should get it to work first. Thanks for this suggestion.
Your solution is good but isn't there any straight way to check if two macros are same?
Slow and Steady!
Not really.
You need to understand how macros work: the comparison is done after the macros have been expanded.
What  MrKendo  suggested is a pretty standard approach:
http://c-faq.com/cpp/ifstrcmp.html
http://c-faq.com/cpp/notgeneral.html
Not really possible, as mentioned. Compile time is really 2 steps:
1) preprocess step
2) actual compile step
What you are asking is if you can compare macros at the preprocess step. Not that I know of, only numeric expressions. You can expand the macros and stringify them, then compare/process the strings at the compile step if you are using C++ (i.e. with constexpr functions).
This is an extremely convoluted process that I tried once just as proof of concept, not something I recommend.
You have to bear in mind that the preprocessor doesn't know anything about keywords, types, pointers, enumerations etc.
Those things are only understood by the compiler.
So given
#define PORTB (*(volatile uint8_t *)((0x05) + 0x20))
if you say
#if PORTB
when the preprocessor evauluates that #if expression it doesn't apply any special meaning to volatile and uint8_t,  it just sees volatile as an undefined macro and substitutes 0, likewise uint8_t,
so it actually sees
#if (*(0 0 *)((0x05) + 0x20))
That's why, for example, you can't use  a cast in a preprocessor #if expression (eg. it would choke on #if (uint16_t)33 ), and you can't use sizeof() etc.
Silly question but have you considered C++ rather than C? Templates allow you to achieve a lot of what you might previously have done with preprocessor macros in C but are done by the compiler not in a separate parsing phase.
Not really.
I think Only if they are purely numeric expressions. :-(
I dislike defines/macros as much as anyone, but the wrench in the gears for any of this is the ISR. The easy part is setting up the pcint, and can be easily done in any language without defines but you are still left with what to do about the isr, and will be doing something less than ideal no matter what language.
https://godbolt.org/z/cW8T5K
(notice lack of defines, and using C)
The original #if method is fine (and probably easiest/best) until you want to also use another pcint. Now what to do. Then you probably do something like the above which uses functions, and you also get all the vectors in use which is harmless and the unused code optimizes away (bare/minimal vector code remains when isr not used).
If you are writing the problem macro yourself,
the answer is to improve your organization.
#define the answers to the desired questions.
Use conditionals to select #define-s for others.
If you are low on control, another technique if to make guesses.
Write some code that will fail to compile if you guess wrong.
