Reverse Eng. from Gerbers to boards/schematics for editing
6 posts / 0 new
Hai
All
I'm looking info's about how's to reverse the gerber files to boards/schematics to edit in the CAD/CAM Programs.
Kindly share information
Regards
JSB
www.tokopedia.com/madagang cheap and free worldwide shipping
I think that is called stealing IP or counterfeiting...........
Not sure if you want to go that route here.........
PCB - most decent PCB software can import Gerber files so that you can edit them.
Schematics - you can't. It is a manual process.
Yup - a Gerber is just a map of where the copper is, and therefore where the connections are. If you have a gerber or a pcb, it's a question of starting in one corner and working through all the connections until you have a rats nest schematic, which you need to shake up and make into something legible. In practical terms, this is effectively impossible without a huge expenditure of time and effort for anything with hidden layers. You might look up BigClive on YouTube; he tends to unwind some simple widgets that he investigates.
Neil
A Gerber is a file type that assumes that you are dragging a dot light source over an unexposed photo film.
It uses coded number instructions to do things like:
   select #1 light source width
   move the light source (with light off) to this X:Y co-ordinate.
   turn light source ON
   move to this co-ordinate in a straight or diagonal line
   turn light source OFF
   select #2 light source width
   ...etc
Look for a program that converts the Gerbers into a PCB board layout.
Then identify the components (what the ICs are) and then recreate the schematic.
Also, try looking at how CNC machines deal with this situation.
Hai All
Yes,Exactly unfortunedly had problems.
I'll separated the bottom layer and upper layer folders.
Regards
JSB
