Simple coding question ATTINY402
12 posts / 0 new
So... I'm used to PORTA = 0xAA;  for example.
Now I seem to need to use PORT SET AND PORT CLEAR  type operations with bit specifiers
So here's the simple question,  how do I simply write to PORTA from a  variable or byte because PORTA = 0xAA doesn't compile anymore.
I guess the same question applies to the DDR.
You should read this first.
http://ww1.microchip.com/downloa...
Compared to traditional tiny/mega
DDRx = PORTx.DIR
PINx = PORTx.IN
PORTx = PORTx.OUT
If you want to keep it simple you could just stick to those three. All your CLR, SET, TGL, etc are just bells and whistles that ice the cake.
I had found the getting started doc, and it says..
.. "The instances of the PORT peripheral registers control the I/O pins of the device.."
What on earth is an instance of a port register when its at home??
And " Portx.Dir" doesn't look like an actual register address to me,more like accessing a structure.
What am I missing?
PORTA is an instance of Port;
PORTB is an instance of Port;
PORTC is an instance of Port;
etc ...
What am I missing?
You are accessing a structure which is mapped onto the port registers:
all the registers in all the ports are contiguous, and have the same layout - so a 'C' struct models that precisely
EDIT
From iotn402.h, the struct is:
/* I/O Ports */
typedef struct PORT_struct
    //          Register Name     Offset  Description
    register8_t DIR;           /* 00      Data Direction */
    register8_t DIRSET;        /* 01      Data Direction Set */
    register8_t DIRCLR;        /* 02      Data Direction Clear */
    register8_t DIRTGL;        /* 03      Data Direction Toggle */
    register8_t OUT;           /* 04      Output Value */
    register8_t OUTSET;        /* 05      Output Value Set */
    register8_t OUTCLR;        /* 06      Output Value Clear */
    register8_t OUTTGL;        /* 07      Output Value Toggle */
    register8_t IN;            /* 08      Input Value */
    register8_t INTFLAGS;      /* 09      Interrupt Flags */
    register8_t reserved_1[6]; /* 0A..0F  */
    register8_t PIN0CTRL;      /* 10      Pin 0 Control */
    register8_t PIN1CTRL;      /* 11      Pin 1 Control */
    register8_t PIN2CTRL;      /* 12      Pin 2 Control */
    register8_t PIN3CTRL;      /* 13      Pin 3 Control */
    register8_t PIN4CTRL;      /* 14      Pin 4 Control */
    register8_t PIN5CTRL;      /* 15      Pin 5 Control */
    register8_t PIN6CTRL;      /* 16      Pin 6 Control */
    register8_t PIN7CTRL;      /* 17      Pin 7 Control */
    register8_t reserved_2[8];
} PORT_t;
note that you do still have the old-style definitions, if you prefer; eg,
/* PORT (PORTA) - I/O Ports */
#define PORTA_DIR  _SFR_MEM8(0x0400)
#define PORTA_DIRSET  _SFR_MEM8(0x0401)
#define PORTA_DIRCLR  _SFR_MEM8(0x0402)
#define PORTA_DIRTGL  _SFR_MEM8(0x0403)
#define PORTA_OUT  _SFR_MEM8(0x0404)
#define PORTA_OUTSET  _SFR_MEM8(0x0405)
#define PORTA_OUTCLR  _SFR_MEM8(0x0406)
#define PORTA_OUTTGL  _SFR_MEM8(0x0407)
#define PORTA_IN  _SFR_MEM8(0x0408)
#define PORTA_INTFLAGS  _SFR_MEM8(0x0409)
#define PORTA_PIN0CTRL  _SFR_MEM8(0x0410)
#define PORTA_PIN1CTRL  _SFR_MEM8(0x0411)
#define PORTA_PIN2CTRL  _SFR_MEM8(0x0412)
#define PORTA_PIN3CTRL  _SFR_MEM8(0x0413)
#define PORTA_PIN4CTRL  _SFR_MEM8(0x0414)
#define PORTA_PIN5CTRL  _SFR_MEM8(0x0415)
#define PORTA_PIN6CTRL  _SFR_MEM8(0x0416)
#define PORTA_PIN7CTRL  _SFR_MEM8(0x0417)
But note how its much easier to set up the struct-style - you only need to define the structure once, and then the "instances" are just one-liners
Also in iotn402.h is
#define PORTA                (*(PORT_t *) 0x0400) /* I/O Ports */
So that the expression PORTA.IN does the right thing.  I like this convention.
and it makes this easy: https://www.avrfreaks.net/commen...
Well on "bigger" chips in the 402 family like 404/406 you have:
where there are two "instances" of the PORT_t that Andy showed above. But the situation with Tiny402 is possibly a little confusing as it only has:
so it only has the one instance - in which case the utility of first defining a common port structure (or UART structure or SPI structure or whatever) and then being able to instantiate a load of the same thing is possibly lost a little when a tiny402 only as ONE of each thing.
But when you trade up to a mega4809 (say) then you have things like:
So 6 ports with a common structure, 4 UARTs with a common structure and four Timer-Bs with a common structure.
Now you can develop code like:
UART_init(USART_t * pUART, int baud, etc);
then that single code can be used for the multiple instances like:
UART_init(&USART0, 9600, ...);
UART_init(&USART3, 19200, ...);
etc
On "traditional" AVR you would have needed separate:
UART0_init(9600, ...);
UATR3_init(19200, ...);
etc
so you'd actually be maintaining four different copies of UART_init() etc.
Of course, with Tiny402 you basically just get "only one instance of each thing" so the utility of this is possibly a little lost there.
indeed.
The same convention is used in SAM-D - and by many (most? all?) other Cortex-M implementations ...
awneil wrote:
indeed.
Me too. +1
Not sure why they don't go to the next step, but I suspect they feel tied down by the asm #define counterparts.
https://godbolt.org/z/WjK1q6
Well, sometimes if you have some legacy code you want to "upgrade" this kind of thing works reasonably well:
#define PORTA VPORTA.OUT
#define DDRA VPORTA.DIR
#define PINA VPORTA.IN
VPORTx closely resembles legacy ports. One difference is that you can't control the pull-up resistors from VPORTx.OUT, so that part of the code needs further changes.
