Latest posts:
Four_Bytes_To_Unpacked-BCD_V1.asm AVG 164.08 Cycles and 146 words length
Three_Bytes_To_Unpacked-BCD_V5.asm AVG 102.45 Cycles and 92 words length
Two_Bytes_To_Unpacked-BCD_v4.asm AVG 47.86 Cycles and 43 words length
Divide by 10 is time consuming.
I'm using divide by 1000. That is a divide by 4,
followed by a divide by 250. (a)
Divide by 250 starts with a divide by 256.
The Quotient on divide by 256 is multiplied by 6; (256-250)=6.
Next, we add the division remainder (a), and divide again; same way.
The main.asm attachment is a AVG=146 Clks Three Bytes conversion to BCD. <-- this was first posted
Long program, but may be shortened (with lose of speed).
Four bytes(or many) can be similarly converted, but I will not upload untested cumbersome work.
Added Two_Bytes_BCD.asm, better comments, and hope a better way to understand the algorithm; AVG=72.3 Cycles
Added Two_Bytes_BCD_v2.asm, 52 to 66clk as MACRO and not counted INPUT; AVG. from 0 to 65535 = 54.53 Cycles
Added Two_Bytes_BCD_v3.asm tested min 49 to max 52 clks AVG=49.86 Cycles
Added Two_Bytes_BCD_v4.asm tested min 47 to max 50 clks AVG= 48 Cycles
Added Three_Bytes_To_Unpacked-BCD_V2.asm tested min 110 to max 135 clks AVG=119 Cycles; 135 Words(cseg)
Added Three_Bytes_To_Unpacked-BCD_V4.asm tested min 121 to max 127 clks AVG=122.5 Cycles; 110 Words(cseg)
Added Three_Bytes_To_Unpacked-BCD_V5.asm tested min 102 to max 105 clks AVG=102.5 Cycles; 92 Words(cseg) <-- last modified on 02/24/21
Added Four_Bytes_To_Unpacked-BCD_V1.asm tested min 164 to max 167 clks AVG=164.08 Cycles; 146 Words(cseg)
