I am using Atmel Studio 7 and want to setup a new Project with Atmel Start,
for SAME54 Xplain board. Now I've experienced bugs in Atmel Start:
- when configuring the source of any clock generator to be "Generic clock generator input pad",
the output frequency is always 0Hz - despite having defined "external pad frequency" to 4000000.
Is this a known "feature"?
- when trying to set an external 4MHz as input to an XOSC it states 8MHz minimum.
Although having not activated "Crystal connected". This limt is true for a crystal, but should not apply for an external frequency input.
In data sheet I found no minimum limit for that...
Thanks for help.
