Having Some non specific Issues
45 posts / 0 new
Hi
AS7/MS7
2560 RobotDyn (non genuine 2560)
and using Xloader to program hardware.
other than a code indent highlighter addin a standard install of AS/MS7
Just after some opinions from the great unwashed!!!
Whilst I wait for MS7 to uninstall and hard drive checking to complete I thought I'd post a question here about some issues I am finding with MS7 and see if my issues are my naivety or an actual problem.
I am increasingly finding my code is not working properly when I upload it to my 2560 development board. Because I am new to C programming and the AS/MS7 environment I can't help think I am doing something wrong but I am beginning not to think this is not the case.
Now the first I noticed was that my serial port configuration and data transfer didn't seem to be that reliable. No matter how many times I power cycled nothing worked. Very often I would program the same code again and it would work as expected. Often if I copied my code into ArduinoIDE it proved to be more successful.
I did post a question recently and  a contributor suggested as I am an ISR I make sure the internal pull-ups where enabled OK but the issues still occasionally reoccur. Then was the situation that for 1 byte change in a while loop eg. 0xBf to 0xBC caused a 2K, 300B or 600B difference in compiled code. Then there was a situation that when I was simulating code the simulator dropped out of the normal look when at the end of a function and start stepping through the code in a disassembly window and all my watch variable didn't update.
The latest is that my previously working 'top half' of my code which included the standard _delay_ms(2) stopped working then started working with 2ms delays now 1ms. However if I changed them to _delay_us(2000) it would work once on than stop, change back to ms work again for a couple of runs. then stop or change the time base again to 1.5mS aarrgghh!!
Yes - the first line of my code specify the F_CPU 16MHz base speed.
I have 'repaired' AS7 a couple of times and it doesn't seem to help, Like I said I am now completely uninstalling/reinstalling like I said I'm just curious what others think - how many times can these be reprogrammed without beginning to fail? Are they like EEPROMs and only have a certain number of flash program cycles?
Ove rto you chaps and chapesses
Many!
It is extremely unlikely that you have hit hat limit.
Your post seems to mention two issues, one with the AS7 simulator, and another with the code for your M2560.
Reloading AS7 won't have any impact on a bug in your code!
For the code issue, with the delay function, you likely need to ignore your overall program and write a simple test program that uses the delay, (toggle an LED< or whatever).
Make sure that is working properly.
Then slowly add in other parts of your project.
Does a simple ISR work, or does adding the ISR initiate the failure?
What is the clock source for your board? internal R/C or external xtal?
Please post the fuse settings as read from the AVR.
Keys to wealth:
If you want something you've never had...
...you must be willing to do something you've never done!
Lets go Brandon!
What does this mean?   post a link to the board or post a clear picture.
Keys to wealth:
Lets go Brandon!
Hello all
Hope you're keeping your eye on Spacex's Starship & Labpadre (youtube) they are go for the second flight.
Right back to business
The reason why I stated non genuine is that it is VERY hard to see any markings on chip AND the designation (from memory) something like 16u or similar doesn't show up as a valid code on Microchip site.
Clock is external
LINK
Sorry - Could you explain how I can read the fuse settings directly
Heres a couple of screen grabs
Beginning of Prog - please ignore crap in F_CPU happen during screen grab
Beginning of Code - Just setting up USART registers using multiple SWITCHs and sending out 1Byte for calibration.
Please refer to resulting timing pic below
Resultant timing diagram. These timing have been spot on 2 & 4ms previously with same code.
Again with regards the simulator it did work fine - then it didn't. Surely I couldn't mess up the Simulator using my code- could I?
Lastly, reference writing a short timing delay - Before I posted here I did try Blink in Arduino (and programmed with ArduinoIDE) seems to work fine
Ok I see it's an Arduino Mega cloan, so what jtag debugger are you using?
Fuses should be set as in an Arduino Mega......   if you have a jtag debugger attached, then you use AS7 to read the fuses. But if your using the Arduino bootloader, it can not be read.
If you really want help with this, zip up your AS7 project directory and attach the zip file to a posting, then a freak who has a mega can dig into it and help you.  I do not.
Keys to wealth:
Lets go Brandon!
HI Jim
After making Google my new friend - I'm looking to knock up a basic Arduino ISP tomorrow and run Avrdude and see if will read the fuses - the other alternative is get a 328PB mini Xplained board. My code is portable enough to just load straight onto a 328PB as is. Anyway, I'm hitting too many strange problems so I think a debug board is long overdue. I really need to see what's going on an a hardware level.
Thanks you again for sparing some time to answer my post,  I will report back if I find anything of interest. Oh! are there any fuses in particular you want to know about?
G'night
Afernoon Jim,
Please find enclosed what fuse settings I could acquire
Programming mode off.
Atmega chip detector.
Written by Nick Gammon.
Version 1.20
Compiled on Jan 26 2021 at 12:46:25 with Arduino IDE 10812.
Attempting to enter ICSP programming mode ...
Entered programming mode OK.
Signature = 0x1E 0x98 0x01
Processor = ATmega2560
Flash memory size = 262144 bytes.
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xFF
Clock calibration = 0x85
Bootloader in use: Yes
EEPROM preserved through erase: No
Watchdog timer always on: No
Bootloader is 8192 bytes starting at 3E000
ADDITIONAL
Atmega fuse calculator.
Version 1.11
Compiled on Jan 26 2021 at 13:18:41 with Arduino IDE 10812.
Attempting to enter programming mode ...
LFuse = 0xFF
HFuse = 0xD8
EFuse = 0xFD
Lock byte = 0xFF
OCD Enable.............................. [ ]
JTAG Enable............................. [ ]
Enable Serial (ICSP) Programming........ [X]
Watchdog Timer Always On................ [ ]
Preserve EEPROM through chip erase...... [ ]
Boot into bootloader.................... [X]
Divide clock by 8....................... [ ]
Clock output............................ [ ]
Bootloader size: 8192 bytes.
Start-up time: SUT0: [ ]  SUT1: [ ] (see datasheet)
Clock source: low-power crystal.
Brownout detection at: 2.7V.
Edit  from Info on Nicks site concerning bugs in 2560 bootloader I have subsequently reflashed the bootloader with Nicks code
Consequently the new fuse settings are
Signature detector.
Compiled on Jan 26 2021 at 13:53:00 with Arduino IDE 10812.
Signature = 1E  98  01
Fuses
Low = FF High = D8 Ext = FD Lock = EF
Do you have test gear to measure your clock?  Most multimeters won't, some expensive ones will.  An oscilloscope would be even better.  Consider programming the 'clock out' pin.
Suggest you put in some startup time.
Have fun, and carry on!  S.
Hi Scroungre thank you for your suggestion.
Gawd I wish - unfortunately I don't. However I do think the basic logic analyser I have is accurate enough to gain some idea what's going on. For example I need a Baud rate of 9600 for calibration purposes to start negotiation with another chip. Now considering 9600 Baud is approx 166uS per bit, I am showing 104uS - I'm in the ball park considering margins of error with a non calibrated piece of kit also acknowledging @16MHz - 9600 Baud the 2560 has 0.2% error anyway according to data sheet.
I will do as suggested and report back
Ahh.  You may have slightly misunderstood the data sheet.  When the 2560 tells you that at 16MHz it has 0.2% error at 9600 baud (presuming you've set your UART registers correctly) it's not that the chip has 0.2% error - it's that the counters only have enough resolution to get within 0.2% of the desired clock speed.  If you wanted an exact baud rate speed, you should have chosen a crystal that gives you one - they're out there - it's not the chip's fault, it's your clock's fault.
Given that, I don't think 104uS when you're expecting 166uS is anywhere near 0.2% error.  More like 40%, no?  No wonder it doesn't work.  S.
What are you talking about? 104us is the well known bit width at 9600 baud. If you are observing 104 you are seeing exactly the right thing.
Think about it 1/9600 = 1.0416666666666666666666666666667e-4 (Windows calculator!) that sure looks a whole lot like 104us to me!
104 is the correct bit time for 9600 baud, not sure where the 166 came from.....
Perhaps you were dividing by 8 instead of 10 (start and stop bits count for a total of 10bits per byte)
Keys to wealth:
Lets go Brandon!
I'm not going to give you the equation - you can Google it just fine, but I will give you a litl' rule o' thumb.
Imagine if you wanted 100uS per bit.  Then 0.2% allowed error would say you can have 99.8uS per bit, or 100.2uS per bit.
If you wanted 200uS per bit, 0.2% allowed error would be 199.6uS or 200.4uS.
Halfway in between, 150uS per bit would therefore allow (ish) 150.3uS or 149.7uS.
In absolutely no way would 166uS per bit allow 104uS per bit.
Follow?  S.
PS - Strictly technically, the metric unit for seconds is a lower-case s, not upper-case; that's Siemens - but given that I typed 'u' for 'micro' all the time and you like using the upper-case S, I felt like speaking your language was more important than being strictly technically correct.  You're welcome.  cheeky  S.
aaarrghh
Typos and brain farts gentlemen - I feel suitably chastised!!!!blush (should have been 106) and yes I was thinking about 10bit frame blah blah. I've just searched SI unit for second  - lets move on eh! I wont mention that when I just wrote micro second (see what I did there cough cough) on a piece of paper I used a lower case S. (if someone could point me in the direction of a middle finger emoticon I would be grateful LOL)
Ok so I have reinstalled MS7 did a small blink with various delays values and they where all spot on as displayed with LA.
I've just rerun my original code and the timings are even worse than they were before. I haven't changed the fuse settings yet to output clock  - can this be done within the compiled code with Atmel?
Let me do some digging there's something strange going on somwehere.
even more strictly, it's the SI unit
https://www.nist.gov/pml/weights-and-measures/metric-si/si-units
https://www.nist.gov/pml/weights-and-measures/writing-metric-units
cheeky
Right  an update
Latest screen grab
Now here's what I am facing:-
Putting the following code :-
                                 DDRD |= (1 <<(DDD3));
                                        while (1)
                                                          PORTD ^= (1<<(PD3));
                                                         _delay_ms(2);
into my software in various locations around my software the resulting pulses are correct (as can be seen above).
My pulse width per bit via USART for 9600 Baud is spot on.
However, it seems when I put _delay_ms(2) where I need it, be it inside a function or between function calls, it does not produce 2ms delays that I require.
Why does it work in one place and not the other?
Where would you guys look to find out what and why is going on here - I remind you all this was working fine until it wasn't - I wonder if the 2560 is faulty.
I'm at a loss
If you ask for 2ms and get 1ms (roughly) then it suggests you have given the wrong F_CPU value to <util/delay.h>. It should be double what delay.h is currently seeing.
That's actually a bit odd as this thread seems to suggest that you are specifying 16000000UL which would rather seem to suggest the CPU might be running at 32MHz. Try setting the CKO fuse and look at the CKO pin with your scope - what clock speed does it see?
Could a recent windows10 update have broken MS7??
This all started after an update when the simulator started dropping into disassembly mode randomly at the end of one of my functions and it's been down hill ever since.
The following was always rock solid,  now I can't even get the code to complete in the simulator.
Would someone please simulate the following at see if it completes - I can't get the simulator to reach i = 0x4.
Now I might have cocked something up during cutting and pasting but I can't see for looking.
#define F_CPU 16000000UL	// Define MCU clock speed (for delays only)
#include <stdint.h>		// Needed for uint8_t
#include <avr/io.h>		// AVR Pin and Register Names
#include <avr/interrupt.h>	// AVR Interrupt Vectors
#include <util/delay.h>		// Usage -> milli seconds  = '_delay_ms(50);' micro seconds = '_delay_us();'
//////////////////////    USART Definitions	  //////////////////////
//	USART Ports
#define USART0				0x01
#define USART1				0x02
#define USART2				0x03
#define USART3				0x04
//	Baud Rates
#define baud_4800			0x00	//	0xCF	UBRR Value used in Usart_Speed_Setup
#define baud_9600			0x01	//	0x67	UBRR Value used in Usart_Speed_Setup
#define baud_19200			0x02	//	0x33	UBRR Value used in Usart_Speed_Setup
#define baud_28800			0x03	//	0x21	UBRR Value used in Usart_Speed_Setup
#define baud_38400			0x04	//	0x19	UBRR Value used in Usart_Speed_Setup
#define baud_57600			0x05	//	0x10	UBRR Value used in Usart_Speed_Setup
#define baud_76800			0x06	//	0x0C	UBRR Value used in Usart_Speed_Setup
#define baud_115200			0x07	//	0x07	UBRR Value used in Usart_Speed_Setup
#define baud_2500000		        0x08	//	0x03	UBRR Value used in Usart_Speed_Setup
//  Baud Rate Array
const uint8_t BaudArry[9] = {0xCF, 0x67, 0x33, 0x21, 0x19, 0x10, 0x0C, 0x07, 0x03};	// Declare a 9 way array called 'BaudArry'
																					// and put in the UBRR values from above
//  Initial USARTs Setup - Asynchronous, 8 Data, Stop, no Parity
#define	UCSRnC_Val			0x06			//	UCSRnC_Val = 0b00000110  	'n' indicates Port Number - 0,1,2,3
#define TxRxEn				0x18			// 	Enable TXENn and RXENn Bits in UCSRnB Register
//  Function Declarations
void Usart_Init_Setup(void);				       // AVR USART configuration [All 8:n:1]
void Usart_Speed_Setup(uint8_t, uint8_t );	               // Format [Port, Speed] - Used for setting Port and Baud Rate
	uint8_t i=0;
		Usart_Init_Setup();
		Usart_Speed_Setup(USART0,baud_9600);
		Usart_Speed_Setup(USART1,baud_9600);
		Usart_Speed_Setup(USART2,baud_9600);
		Usart_Speed_Setup(USART3,baud_9600);
      i = 0x42; // debug in Simulator
    while (1)
	// Basic 8,n,1 configuration of the 4x MCU ports of the AtMega2560 and enable Transmitting & Receiving
	// UCSRnC_Val = 0x06	    8 Bit Data	  (UCSZn1 and UCSZn0 = 1)
	// TxRxEn =				Tx and Rx Enabled (0x18)
		DDRJ &= ~(1<<0); // configure PBJ as an input
		PORTJ |= (1<<0); // enable the pull-up on PBH
		DDRH &= ~(1<<0); // configure PBJ as an input
		PORTH |= (1<<0); // enable the pull-up on PBH
		DDRD &= ~(1<<3); // configure PBD as an input
		PORTD |= (1<<3); // enable the pull-up on PBD
		UCSR0B = TxRxEn;		// USART 0
		UCSR0C = UCSRnC_Val;
		UCSR1B = TxRxEn;		// USART 1
		UCSR1C = UCSRnC_Val;
		UCSR2B = TxRxEn;		// USART 2
		UCSR2C = UCSRnC_Val;
		UCSR3B = TxRxEn;		// USART 3
		UCSR3C = UCSRnC_Val;
	return;
void Usart_Speed_Setup(uint8_t Port, uint8_t Speed)
	// Function to Write Baud Rate of the 4x Serial Ports of the AtMega2560
	switch (Port)
					case 1:
						UBRR0L = BaudArry[Speed];
					break;
					case 2:
						UBRR1L = BaudArry[Speed];
					break;
					case 3:
						UBRR2L = BaudArry[Speed];
					break;
					case 4:
						UBRR3L = BaudArry[Speed];
					break;
	return;
I'm beginning to think that you might be right about AS7. Perhaps a recent update has broken something. I tried pasting your code into an existing project, setting it to 2560 then building and simulating. But when I try to do one of my standard things which is to start simulation, break at main and then "goto disassembly" it says there is on accessible code. Which is most odd.
In case I broke something in that existing project I created a whole new one but had the same thing.
Not sure what's going on ?!
That's possible or instead a .NET update (Microchip Studio 7 is from Visual Studio Isolated Shell 2015 which is heavily dependent on .NET)
Atmel Studio 7.0 new install on Windows 10 2004 - not starting | AVR Freaks
Another Win_10 rant of frustration-part 2 | Page 3 | AVR Freaks
More curious still - just tried it again and if I dismiss the alert when it happens then try a second time it DOES go to the Asm ?!?
Will try 2560 and the code above now..
EDIT: Wow I had to dismiss the spurious dialog three times before it would let me see the Asm code but then it showed:
and I was able to step it all easily. as you'll see a large proportion has been optimised away - that function with the switch to set 4 baud rates has simply turned into four precalculated STS opcodes but the code certainly seems to follow the execution sequence I would expect.
Thank you clawson for trying.
Would you be kind enough to manually step though the code and see if it hits i=0x42 in a watch window. Also, randomly comment out one or more of the following and see what happens of your system
I am still new to this and not 100% confident in the code I write - all this has knocked my confidence somewhat and would like to know if my code is OK.
Hello GChapman,
Just to be clear are you suggesting I act on the post (first one) concerning updating .NET or did you post them for informational purposes?
For completeness I am running 7.0.2542 & Windows10 Pro 1909 - I delay the damn updates as long as I can and it looks like there's one pending know.
You edited when I was replying
My simulation hangs randomly at the end of a Usart_Speed_setup(*****,***) usually, but not always, at the last one of however many setups were not commented out. (Bad English I know, but on the up side I now use small s's for seconds when I type)
Does this happen to you?
information; once you're certain the defect is in Windows 10 or .NET then create your action (one has ten days to roll-back an update)
Windows 10 1909 is good to go (broadly deployed)
Delaying (Home) or deferring (Pro and sub) Windows 10 and .NET updates is prudent; ones at Microsoft need a few weeks to correct defects (only a relative few security updates are recommended to be immediate)
Release of Microchip Studio 7.0.2542 | AVR Freaks
Windows 10, version 1909 and Windows Server, version 1909 - Windows Release Information | Microsoft Docs
Well it's never going to hit that. Surely you saw when the compiler said:
		.././main.cpp: In function 'int main()':
D:\test\newtest\main.cpp(45,10): warning: variable 'i' set but not used [-Wunused-but-set-variable]
		  uint8_t i=0;
There's going to be nothing called "i" and no code accessing it in the code that you are building. If you really want "markers" that you can break on I personally prefer:
asm("nop");
but someone will be along in a minute to point out that you don't need to type that as _NOP(); is available. But you need a #include of <avr/cpufunc.h> to use it (so just typing asm("nop") could be easier!!)
Yes I saw that but at this stage I just don't trust anything from AS7 which is why, at least in part, I asked you to step through.
Further to your statement, I don't fully understand why it is not used!  If I declare a variable then later write to that variable surely I have used that variable.
Do I have to buy the compiler dinner or get a letter from it's mum to say it can come out to play???
I swear it's harder learning 'compiler' than it is C
You probably need to read:
GCC is an aggressive optimising compiler and will discard anything that looks pointless at the earliest opportunity. If you write:
int main(void) {
    int i = 123;
this will basically compile to "RET" and nothing else. At build time the compiler will warn "i is set but never used". As it's never used the compiler will be thinking "why would I bother wasting space or run time machine cycles to create a variable that has no apparent use?" So it doesn't,
The way to over-ride this is to make the variable "volatile" which says to the compiler "you and I can both see this is entirely pointless but just do it anyway - create some code for no reason whatsoever".
It'll be the difference between:
000000fa <main>:
int main(void) {
    int i = 123;
  fa:	80 e0       	ldi	r24, 0x00	; 0
  fc:	90 e0       	ldi	r25, 0x00	; 0
  fe:	08 95       	ret
and
000000fa <main>:
int main(void) {
  fa:	cf 93       	push	r28
  fc:	df 93       	push	r29
  fe:	1f 92       	push	r1
 100:	1f 92       	push	r1
 102:	cd b7       	in	r28, 0x3d	; 61
 104:	de b7       	in	r29, 0x3e	; 62
    volatile int i = 123;
 106:	8b e7       	ldi	r24, 0x7B	; 123
 108:	90 e0       	ldi	r25, 0x00	; 0
 10a:	9a 83       	std	Y+2, r25	; 0x02
 10c:	89 83       	std	Y+1, r24	; 0x01
 10e:	80 e0       	ldi	r24, 0x00	; 0
 110:	90 e0       	ldi	r25, 0x00	; 0
 112:	0f 90       	pop	r0
 114:	0f 90       	pop	r0
 116:	df 91       	pop	r29
 118:	cf 91       	pop	r28
 11a:	08 95       	ret
(but if you are worried about filling up your limited AVR with cycle wasting, flash space wasting code you would presumably prefer the former?).
No, you haven't.
If all you do is write to it, then nothing ever reads what you wrote, the effect of the program is exactly as if that variable never existed.
It would be impossible to distinguish a program with that variable from one without.
So the Optimisation gives you the one without - because it saves both data & code space.
See: Nine ways to break your systems code using volatile - in particular, the section "What does a C program mean?".
EDIT
Typo - "never"
Understand! It hit home when you made these statements
.......the effect of the program is exactly as if that variable never existed.
and
 Oh Gawd more reading
So in the following should I or should I not see a value in simulator
thnaks
You could, if you wanted to, write it in assembler from scratch!  S.
No, as you code gets optimized too:
UDR0 = 0x42*2;
so i and k are optimized away.  For debugging, use -g optimization level, it's not as aggressive and it may work better for you.
Keys to wealth:
Lets go Brandon!
Actually, it's all about understanding 'C'.
The all-too-common misconceptions about optimisation arise from failing to understand, or misunderstanding, what a 'C' program is actually about.
As  John Regehr  said in that linked article:
the C program can be thought of as a specification of desired effects, and the C implementation decides how to best go about making those effects happen
https://blog.regehr.org/archives...
And sometimes the implementation screws it up, and you're better off writing the machine code to start with. laugh  S.
and sometimes that paradigm does mean that 'C' is not the language to do what you need to - and your really should write it in assembler
This is interesting and a little confusing so unfortunately I have to plead the novice card and ask what might be going on or where do I start to look for my problem and more specifically where do I put the -g?
So top clarify:-
I have a piece of C code from a manufacturers Application Note that was written for Windows and I need part of it to run on a MCU. Now I have reproduced all the relative windows functions that I need BreakCOM, WriteCOM, ReadCOM, SetBaudCOM and reproduced them to MCU equivalent Functions. I was able to read and write at various speeds to any USART port I wanted and detect serial data via ISR and interrogate the data.
Then out of the blue my _delay_ms()_  just stopped working! When I tried to simulate my previous working code,  AS7 didn't step through the code cleanly but reverted to a disassembly listing at the end of a couple of functions, instead of return properly to the origianal calling function. I then extracted the most minimalist amount code I could and put it in a new project to try an debug what was going on. Still the same problem as above. (this is roughly the point I started posting here).
I have uninstalled reinstalled MS7, uninstalled AS7. Forced windows updates, uninstalled windows updates. I have recently uninstalled all and installed VS Code. I've put my expected received responses in an array commented out the UDR calls and it simulated as expected. I included Stdio.h and using printf I produced an output that was loosely in line (subject to a few minor issues) with what I would expect.
I commented out the printf and copied my code over to MS7. Simulation again started dripping off the end of functions etc. So my code works in VS code but not in AS7 or MS7.
It was working one day then didn't the next -literally!
My code does not use any 'fancy' C 'stuff' - just delays, decisions, Switch-Case and I/O and one Serial Rx ISR (yes I used volatile)
What would you do in my situation? I don't have the money to buy £100 of microchip debug tools. The only thing I can think of is an ATmega328PB-XMINI board for a tenner but would this be enough?
So, where is my place of known good to build from? Is it a compiler issue, Hardware (AVR) or Software (AS7/MS7)
Sorry for the rant and my life story
Edit :- Don't worry found location - it was already set to -Og  (what confused me was -g instead of -Og)
Almost certainly.
You said you had  BreakCOM, WriteCO, etc working - so build from there
You must have done something to break it.
This is where some sort of "version control" system is invaluable - even if you're just a lone hobbyist:
https://www.avrfreaks.net/forum/program-help-me-roll-back-older-versions-my-code
A common mistake with _delay_ms() is to forget the requirement that its parameter must be a compile-time constant.
Also, the Studio simulator runs vastly slower than real time, so simulating _delay_ms() takes forever - which can give the impression that your simulation has "died".
If you have a small project for one of the IDEs that can be built and that will demonstrate the issue you are seeing then unless it contains private/proprietary code ZIP it up and attach it here so we can try to replicate.
Docara wrote:
... and ask what might be going on ...
Uncertain or unknown (hypothesis, design of experiments, formal methods when required though relatively rare, intuition, experience)
Docara wrote:
... or where do I start to look for my problem ...
Where the problem isn't then move (unit tests, integration tests, divide the problem space)
Compiler defects are sometimes identified during unit testing; otherwise, one operates a debugger and such.
Docara wrote:
... and more specifically where do I put the -g?
Toolchain
Stack frame clobbered?
Operate linters (I, a mangler of C), add asserts.
Splash another tenner (logic analyzer)
  • Windows 8.1 is the most reliable Windows
  • Visual Studio Code has GDB
  • fyi, AVR is in LLVM
  • there's a certified C compiler [though not for AVR, the issue may be in GCC front-end (parser) or middle (intermediate representation)]
scientific hypothesis | Definition, Formulation, & Example | Britannica
Compiler and Toolchain Options | Microchip Studio
[bottom]
Debug options
Adding Automatic Debugging to Firmware for Embedded Systems
Troubleshooting real-time software issues using a logic analyzer - Embedded.com
AVR Studio On Mac & Linux? | AVR Freaks
debugWIRE via USB UART | AVR Freaks
AVR LLVM released | AVR Freaks
CompCert - Main page
Hi Just popped back to post an update
cli() & sei() seem to have now stopped working in simulator.
I used to clearly see the 'I' flag in SREG register get set now I don't. If I omit sei() and put in cli() for debugging purposes if I manually set 'I' cli() does not clear it additionally if I put cli() inplace of my sei() and upload then my RX ISR still ruts on hardware.
Thank you al so much for the replies it is so appreciated.  So in order
awneil:-
Correct I have reproduced these for my needs and they work.
OK what sort of things could break this - interrupts?  I did have cli() as the first line of main whilst I was setting up USARTs then when done configuring I then ran sei() before continuing. I thought perhaps cli() WAS messing with delays so I commented it out - but no change.
All I have ever used was this     _delay_ms(2);
I stepped through a search and replace using _del and manually replaced all my delays with _delay_us(2000); this worked for one build, simulate cycle then didn't work again. Changed back to _delay_ms(2); still didn't work.
Yes I was aware if this. This 'hang' was when I first it delays didn't run because that 'go for a coffee' screen didn't appear. I have a basic logic analyser which also showed no delay in my serial data. On occasion when delays did some times work the they were wrong period.
clawson:-
I am reluctant to because I think I have found a little niche I could use financially in the future. In the UK due to the lockdown the Government has pretty much decided to completely screw the economy in case someone over 80 dies. I am an electrician who is now out of work, who might be able to go self employed and start up again if I could get this code working.
I have had large swathes of my code working in an online C compiler site which is what is confusing me. But it is not suitable for attached hardware or is AVR pins  aware. Delays work there, I can use printf and display 'things' but not in MS7. I also had the same code working in Codeblocks when I cut and paste. I uninstalled CB in case it was causing my issues with MS7.
To be fair the 'falling' of the end of a function only happens in code I have copied over from an Application Note and have tweaked. It uses a recursive function and pointers soo yeah!
However if these sections are removed I am still left with delays not working and now (today) sei cli, not functioning as expected based on simulator or as seen on hardware - Global Interrupts disabled Serial ISR still fires.
gchapman:-
I'm sorry I don't understand
My functions worked (as seen on hardware and MS7 simulator) I've been adding, subtracting or moving code to try and find a pattern. I don't post to forums unless I'm completely buggered or it might be a quick clarification type of question
Please look above at screen grabs - I have been using one
If I had another box I could use / have Win7 or Win8.1  there would already be a clean install on it for comparison purposes and 'place of known good, fault finding
What relevance is 'Visual Studio has GDB' please explain
what is LLVM?
What relevance is a certified compiler in this situation? MS7 is used by thousands of people presumably without an issue- my problems have to be something I'm doing right?
It seems SO strange that after working on the same code for months, only moving forward to new function when the previous code works as anticipated, then one day bang problems!
(apologies if I have messed up responses to poster hope you don't take offence)
As you get closer to 80 you may begin to learn that life is just as precious however old you are.
Won't be helping you again.
Have a happy life (while you can).
The C standard has a lot of ambiguities some of which are resolved as implementation-defined; a linter identifies usage of ambiguities and known defects (pattern matching)
Assertions make visible constraints and are one way to identify a possible defect in a file (or indirectly in an associated file) (defect -> fault -> failure)
Visual Studio Code has GDB extensions.
AVR GDB is another AVR debugger though mega2560 JTAG is "expensive" other than MPLAB Snap; MPLAB Snap's AVR GDB proxy is in atbackend.exe (Microchip  Studio 7)
Docara wrote:
what is LLVM?
LLVM is another compiler or interpreter backend; one of several LLVM frontends is Clang (C, C++, etc.)
When a defect is evident via GCC and not evident via a verified compiler.
Maybe not; defects in Windows 10 and .NET updates have caused Atmel Studio 7 malfunctions.
Defective PC DRAM will cause anomalies.
AMD CPU have ECC; Intel server CPU have ECC.
LINT
by Jack Ganssle
[mid-page]
But much more powerfully, lints can look at how multiple C files interact. ...
MPLAB Snap | AVR Freaks
The LLVM Compiler Infrastructure Project
The LLVM Project is a collection of modular and reusable compiler and toolchain technologies.
Clang C Language Family Frontend for LLVM
Slow compiling - win10 update issue maybe? | AVR Freaks via Another Win_10 rant of frustration-part 2 | Page 3 | AVR Freaks
gchapman wrote:
Maybe not
But probably yes.
I'm sorry you feel that way
Both my parents died from Covid related complications this year and they were furious that "the country me and my friends died for" is being decimated and "run by fools" and that they couldn't hug their grand children for a year when they were well and able to do so. They were 88 and 93. The (last) big family Christmas that was planned didn't happen, we weren't allowed to travel to care for them when my mother had a fall, - so it was out-sourced to 'carers' who guess what carried the virus. Please don't lecture me about how life is precious I have lost more than I am prepared to say here - but have no illusion I KNOW LOSS and it's why I'm practical not sentimental about it - you see enough death you know life is about living.
From Government statistics average life expectancy in the UK is 81. Average age Covid related deaths is 83.
STATISTICALLY they are trying to keep people alive longer than the STATISTICAL average natural death age. Should this be at the expense of everyone else's financial suffering? - Where is the money going to come from for benefits because everyone is out of work? Your grandchildren will be paying for this by having debt hanging over their heads or decades to come - great legacy. As you are, presumably, from the 'baby boomer' generation you know the fantastic opportunities you have had in your life, sad and selfish to think the same type of opportunities should not be afforded to the up and coming generation(s).
And yes I am very angry and bitter about what happened. Vulnerable people should have been protected. Whilst pubs, clubs cinema and the like should have been closed, we (young people especially) should have been allowed to acquire herd immunity to help protect the vulnerable by proxy (Swedish model) until a vaccine came along. Do not forget the reason we are going through this crap is "to protect the NHS" the same NHS that Government has robbed blind and underfunded for years so now they can't cope when a (long predicted) pandemic. We had a national bed occupancy rate of 95% before the pandemic how were we going to ever deal with a blip in the populations health so the country was closed!!! No official body has commented on the effectiveness of nasal antivirals (like Vicks First Defense) tablet based decongestants to limit sputum build up on the chest or even antihistamines as a preventative measure to stop the body over reacting to the infection if contracted. No proper instructions on how to use PPE - double gloving when in supermarkets discarding out pair when leaving,  using isopropyl alcohol to wipe all purchased item before bringing into the home etc etc etc so yes I'm angry!!
Covid is NOT Ebola  - The current measures are not appropriate for 'flu with a chance of a chest infection' and yes I am being glib! Being alive and living is also about death and dying BUT ALSO being allowed to die with dignity all of which is being taken from us.
F*** you!
I am currently waiting on the results of suspected (the family curse) Liver/ Pancreatic Cancer biopsy which, guess what, had to be postponed for 9 months because of lock down - it would be nice if I could see 60 let alone live to be in my 80's like you. More people have died through late diagnoses of cancer than Covid.
Thank you for your help when you gave it - some of it was useful.
