ATSAMD21G18 and PWM output
6 posts / 0 new
Hi All
This is the first time I am using a SAM device(ATSAMD21G18 ). From my understanding, each pin on the device has associated with PWM channel and a specific timer.
I am reading the datasheet  SAM D21 Family Data Sheet (microchip.com)
In relation to PWM what the difference between  "TC/Waveform Output Channels per TCx Instance"( 5/2 )and " Waveform Output Channels per TCCx Instance" (8/4/2)  is? This is shown on page 14
Regards
DJ
The TC and TCC peripherals are different. Each TC has 2 waveform outputs and the ATSAMD21G18 has 3 TC hence 3/2 for your device on page 14. The TCC instances don't all have the same configuration, ATSAMD21G18 has 3 and they have 8, 4 and 2 waveform outputs respectively. There is more detail about the TCC instances in section  7.2.5, including this which is important to know:
The number of CC registers (CC_NUM) for each TCC corresponds to the number of compare/capture channels, so that a TCC can have more Waveform Outputs (WO_NUM) than CC registers.
So look at CC_NUM there for the number of unique PWM outputs each  TCC supports.
There are actually a few pins that are not possible to use with any TC/TCC outputs.
/Lars
What is the difference between the TC and TCC?
So its best to use TCC for PWM?
So if a TCC pin has 8 waveform output, that means it can be output 8 different PWM? So why would it be necessary to have 8 output on a single pin? Can you not just adjust the firmware to adjust to the waveform.
Regards
DJ
Regards
DJ
TC outputs its 2 PWMs on 2 different pins, and TCC  outputs its 8 PWMs on 8 different pins
John Malaugh
Ok,
So what is the difference between the TC and TCC interms of pwm output?
Regards
DJ
You will have to check the datasheet but the TCC (depending on the instance) have a lot of PWM related advanced features (Table 7-7. TCC Configuration Summary).
/Lars
