main function of an AVR program
33 posts / 0 new
What happens when the main method of an AVR program returns? Is it possible to have your application function solely on interrupts?
It disables interrupts and goes into an infinite loop.
You can check using "avr-objdump -d file.elf" on the elf file for your program.   See code starting at (byte) address 0xac below.
Disassembly of section .text:
00000000 <__vectors>:
   0:	0c 94 50 00 	jmp	0xa0	; 0xa0 <__ctors_end>
   4:	0c 94 5a 00 	jmp	0xb4	; 0xb4 <__bad_interrupt>
000000a0 <__ctors_end>:
  a0:	11 24       	eor	r1, r1
  a2:	1f be       	out	0x3f, r1	; 63
  a4:	cf ef       	ldi	r28, 0xFF	; 255
  a6:	cd bf       	out	0x3d, r28	; 61
  a8:	df e3       	ldi	r29, 0x3F	; 63
  aa:	de bf       	out	0x3e, r29	; 62
  ac:	0e 94 5c 00 	call	0xb8	; 0xb8 <main>
  b0:	0c 94 5f 00 	jmp	0xbe	; 0xbe <_exit>
000000be <_exit>:
  be:	f8 94       	cli
000000c0 <__stop_program>:
  c0:	ff cf       	rjmp	.-2      	; 0xc0 <__stop_program>
Thats very good to know! So I guess if I want an interrupt based application I need to loop infinitely rather than exiting the main function
That sounds like good practice (you are in control).   Try writing a main with loop and see that assembly comes out.
There is also the option of putting the CPU to sleep.  The infinite loop would have a sleep inside.
All embedded (non OS) micro programs should remain in main() even if this just means an empty while(1). While avr-gcc does have the catch all that Matt showed there was one version of this compiler+library that did not do this and it caused absolute havoc among the many programs that had been written to rely on a catch-all that now did not exist!
Obviously if your C code is in a "hosted" environment you will want to return from main() at some stage and even return an int value to say if it worked (0) or the reason why not (1.. MAX_INT).
One option that you can use if you don't want to do anything in main() but don't want to just "spin your wheels" endlessly, is to use one of the sleep modes.  If you enter sleep in main it will remain there until an interrupt occurs.  The CPU will wake from sleep and service the interrupt.  Then the control will return to main() where it will again hit the sleep function and go back to sleep.
This can also save considerable power if that's an issue in your design.
But that still needs a while(1) loop.
Yes, that's true.  Although if you really don't like while, you can always use a for loop...  ;-)
If there is nothing else, what would the interrupt be interrupting? Then sounds more like a wake/sleep/wake...
As I recall, "running off the end of the code" in assembler causes a processor reset when it enters unprogrammed flash space.  S.
Edited to add:  Probably because 0xFFFF (unprogrammed space) is interpreted as 0x0000 (NOP), and then the PC just runs until it wraps the counter back to 0x0000 (reset vector).  S.
The 'C' language specification wrote:
The effect of program termination [ie, exiting main] in a freestanding environment is implementation-defined
in other words, it depends on what toolchain you are using.
As already noted, GCC has a loop to "catch" any exit from main - but other toolchains may not ...
Just to be pedantic but it actually behaves as SBRS R31,7 so, unlike a NOP, if bit 7 of R31 is set it will execute every second 0xFFFF not every single 0xFFFF as would be the case if were really behaving like NOP.
Now when we are " pedantic " then the instruction 0xffff is NOT SBRS R31,7 but undefined, it's correct that original AVR's did that instruction because it made a incomplete instruction decoding, (there is only one 0), but in the future (perhaps some of the newer AVR's already have a instruction there I have not checked it).
which is why I very deliberately used the word " behaves as" because I'm well aware it is not actually SBRS R31,7 ;-)
And if bit 7 of R31 is not set it behaves as NOP.  So there.  devil   S.
Are you sure that the newer AVR designs also behave that way ? ( 0-series and 16 register AVR's etc. )
BTW the default for avr-gcc is hosted.
The reason for the choice is documented somewhere.
You can declare main as "no return" it will save some space in flash, __attribute__ ((noreturn))
This does not prevent the function from returning - it remains up to you to ensure that it really does not return.
There are also some other provisos - see:
https://gcc.gnu.org/onlinedocs/g...
Interestingly, I didn't catch in that linked discussion where noreturn is related to main().
All the while the Kingston Trio runs through my head...
Well did he ever return, no he never returned
And his fate is still unlearned (what a pity)
He may ride forever 'neath the streets of Boston
He's the man who never returned
o/~  Did it ever return?
No it never returned
And its value is still unlearn'd
It will run forever
Down in the Flash RAM
It's the main() that never returned...  o/~   S.
(eta: and theusch beat me to it, too)
(apologies to the Kingston Trio et. al.)
The link doesn't specifically mention main() at all - but some things seem applicable; eg,
The GCC documentation wrote:
The noreturn keyword tells the compiler to assume that [the function] cannot return.
The OP question was, "What happens when the main method of an AVR program returns?" - so use of noreturn really doesn't address that question.
Perhaps  12oclocker has misunderstood, and thought that noreturn would prevent main from returning?
The GCC documentation also wrote:
It does not make sense for a noreturn function to have a return type other than void.
But GCC also insists that main() have a return type of int.
awneil wrote:
But GCC also insists that ...
That should have been the emphasis in the first responses --  what toolchain are you using?  ... it will vary among toolchains and options ... what do you expect to happen? ... and similar.
To void main(), or not to void main(),
That is the question,
Is it nobler to return from main or not!
Personally in an embedded app, I have always used:
#define forever 1
void main(void)
    while(forever)
        //do some thing useful!
as a starting point, the usual standard return(0) never made sense to me in an embedded app.  I do acknowledge the origin of the standard, and which ever way you prefer is ok with me.
Indeed - #11 was my first response.
Sorry I was not clear, I did not misunderstand, I was simply stating, in your main loop, since you should never allow main to return anyway, declare it void with no return attributes, and save some flash space.
Not just gcc: C standards insist that main have return type int.
The exit function in avr-gcc is a weak function, so if you prefer to pretend you are running a pc you can return into a black hole of your own creation. Since the exit function is declared as a noreturn function in stdlib.h, you would simply be moving your endless loop from main to exit along with any other code that could have simply stayed in main. In other words, what I just said is useless information (not unusual) except to point out you do have a choice if you wish. The other side of main in an mcu is like a black hole- observe/understand all you want, but there is no reason to enter.
actually not:
The C language specification wrote:
In a freestanding environment (in which C program execution may take place without any benefit of an operating system), the name and type of the function called at program startup are implementation-defined.
For a Hosted environment, the C language specification wrote:
The function called at program startup is named main ... It can be defined with no parameters:
int main( void )
ISO/IEC 9899:201x
[top of page 32]
5.1.2.2.3 Program termination
If the return type is not compatible with int, the termination status returned to the host environment is unspecified.
due to Main function - cppreference.com (mid-page, third special property)
ISO/IEC JTC1/SC22/WG14 - C: Approved standards
#define forever 1
void main(void)
    while(forever)
My preferred (mis)use of the preprocessor is:
#define ever (;;)
    for ever {
        // something useful
How about:
#define forever while(1)
do
    // stuff
} forever;
or even
forever
    // stuff
christop wrote:
#define ever (;;)
I like it!!!
