I wrote some simple SPI slave code a while back that has worked fine for some time. I use an atmega32u4 and have it wired to a harness. This Harness connects to a master SPI device. I had to remake my harness as I lost the old one. Now the pair will not communicate. So logically, I broke out my analyzer to have a look. I have attached a screen shot showing this.
The code I run matches what we see here..
command=Spi_read(1, 0xff); Spi_read(1, 0x41); Spi_read(1, 0x5a); Spi_read(1, 0xF1); Spi_read(0, 0xF2);
Here is the SPI function for reference.
unsigned char Spi_read(char ack, unsigned char data) { SPDR = data; while(!(SPSR & (1<<SPIF))) if (ack) { ATT_ON(); _delay_us(1); ATT_OFF(); } return SPDR; }
When I debug out my command I get 0xff. If I put my command= on the next line
i.e. command=Spi_read(1, 0x41);
I get 0x41 and same for the other 3 lines of code. Command should not be the data I'm sending. It should be the reply but it for some reason is showing the data sent to the mater. I verified the SPI function is waiting for the communication to end. So the SPI function seems to be running successfully. I can see its sending the right data so the miso/mosi are not swapped and I have checked that harness many times over. From a practical sense it almost has to be the code, but it never changed. I reverted from my SNV.... What on earth would make it echo back what I send where the analyzer clearly shows that's not what comes back? IS there anything that would make the SPDR register not load the data from the temporary register?
