Makefile question - how to do this?
4 posts / 0 new
Hi all,
I have what should be a simple question, but I just can't seem to fine the answer.
In a Makefile, I have the following line:
libdir=/usr/lib/x86_64-linux-gnu
I also wish to be able to compile the same code on a Raspberry Pi, so when I do I use this line instead:
libdir=/usr/lib/arm-linux-gnueabihf
However, I need to edit the Makefile by hand to do this.
Is there any way that I can get these strings (highlighted in red) automatically? I do rebuild the Makefile using autoconf.
I looked at uname and it's output isn't usable (even if I hack out pieces and concatenate them).
Thanks!
I believe you can check for the existence of the directories...
Edit: adding:
Something like this:  (may be gnu-make dependent?(
TESTDIR := $(firstword $(wildcard ../../../tools/*))
ifeq (,$(TESTDIR))
# no such directory  Try elsewhere...
endif
Additional edit:  An advantage (I think?) of this over the various suggestions used $(shell ...) is that it doesn't depend on having a unix-like "sh" available.
Use the ifeq command with the shell command (running uname -m to get the machine type) to conditionally set libdir:
https://www.gnu.org/software/make/manual/html_node/Conditional-Example.html
https://www.gnu.org/software/make/manual/html_node/Shell-Function.html
I went through an old book on libtool a few months back; programs like avrdude use it and can be compiled on many platforms.
https://www.gnu.org/software/libtool/
While looking at a different libc, I ran into the Meson build system, and that seems like it might be a better option, but I have not even read a book on it yet.
https://mesonbuild.com/
Finally, what I have done to find a serial port, you will have to spin it to fit the need.
detect_PORT := $(shell sh -c 'ls /dev/ttyAMA0 2>/dev/null || echo not')
ifeq ($(detect_PORT),/dev/ttyAMA0)
	UPDI_PORT = /dev/ttyAMA0
endif
detect_PORT := $(shell sh -c 'ls /dev/ttyUSB0 2>/dev/null || echo not')
ifeq ($(detect_PORT),/dev/ttyUSB0)
	UPDI_PORT = /dev/ttyUSB0
endif
UPDI_PORT ends up with /dev/ttyAMA0 on a R-Pi and /dev/ttyUSB0 on my Ubuntu machine that has an FTDI part connected.
