Fun & Games with Fixed-point Arithmetic [solved]
55 posts / 0 new
Pages
are you positive about that ?
Scroungre wrote:
This is also why you never do financial math in floating-point, because nobody's going to cash a check for (e.g.) $10.00000037... **
I thought the financial math was performed in decimal (versus binary).  At least in the early days, HP hand calculators worked in decimal, IIRC.
BCD ?
IIRC (circa '80 and undergrad assembly language), IBM 360 has decimal arithmetic.
IBM Archives: System/360 Model 50
Pages
