Timer overflow ISR execution is delayed - precise timing needed.
121 posts / 0 new
Pages
Ok, first of all thank you for taking the time to do something like this! This is an awesome explanation.
So, I think I prefer 3b because I have many  "slots of work" to spare and I primarily am trying to push main code execution away from the ISR calls so that the ISR's periodic execution is not threatened.
Since I am using direct digital synthesis ISR timing is the most important thing here. If and when a case 3 happens I would rather waste a whole interval waiting than start a delayed execution of a main code segment (3A) and risking next ISR delayed execution.
I also try to limit case 3 in my code by using the simulator.
TO THE FINDER... THE ISLE OF KOHOLINT, IS BUT AN ILLUSION... HUMAN, MONSTER, SEA, SKY... A SCENE ON THE LID OF A SLEEPER'S EYE... AWAKE THE DREAMER, AND KOHOLINT WILL VANISH MUCH LIKE A BUBBLE ON A NEEDLE... CAST-AWAY, YOU SHOULD KNOW THE TRUTH!
NULL
OK, as long as you understand the tradeoffs, choose the approach that makes the most sense for you.  And good luck with the project.
Thanks again! You're awesome
Hello friends! You helped me complete my project and I wanted to post my results here:
Code
 *  ZNEAR - note producing controlled by potentiometer - DDS technique used
 *  Author	: WindFish
 *	Rel Date: 7/11/2020
 *	OUTPUT of DDS at pin 12 - OC0A. Sample rate approximately 39KHz
 *	chip ATMega328P
#define F_CPU   20000000 //CPU speed in Hz for use with util/delay library and Serial communication
#define BUAD    9600	//For Serial communication
#define BRC     ((F_CPU/16/BUAD) - 1) //For Serial communication
#define RAND_MAX 255 //for random generation (not actually used)
#define INPsize   32 //for rolling mean filtering of the ADC input
//C++ libraries
#include <stdint.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <util/atomic.h>
#include <stdio.h>
#include <stdlib.h>
#include <avr/pgmspace.h>
#include <math.h>
#include <avr/eeprom.h>
#include "helping_functions.h"
//Imporetd C libraries
extern "C"
	#include "nokia5110.h"
	#include "nokia5110_chars.h"
//Welcome screen bitmap
const uint8_t wf_Width    = 84;
const uint8_t wf_Height   = 48;
const uint8_t PROGMEM wf_Bitmap[] = {
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x40, 0x40, 0x60, 0x20, 0x20, 0x20, 0x10, 0x90, 0xd0, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xc0, 0x60, 0x30, 0xf8, 0x80, 0x00, 0x00, 0x80, 0xc0, 0x40, 0x60, 0x20, 0x30, 0x10, 0x18, 0x0c, 0x04, 0x06, 0x02, 0x03, 0x01, 0x01, 0x00, 0x80, 0xe0, 0x30, 0x1c, 0x06, 0x02, 0x03, 0x01, 0x01, 0x00, 0x00, 0x80, 0xc0, 0x60, 0x30, 0x18, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0xc0, 0x40, 0x60, 0x20, 0x20, 0x30, 0x10, 0x10, 0x18, 0x08, 0x08, 0x0c, 0x04, 0x04, 0x06, 0x82, 0x83, 0x41, 0x61, 0x30, 0x18, 0x08, 0x0c, 0x1f, 0xf2, 0x83, 0xe1, 0x38, 0xfc, 0x00, 0x00, 0x00, 0xfc, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x7c, 0x07, 0x00, 0x80, 0x80, 0xc0, 0x60, 0x30, 0x18, 0x0c, 0x06, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x20, 0x30, 0x18, 0x0c, 0x06, 0x02, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x37, 0x1f, 0x80, 0x80, 0xb1, 0xef, 0xbe, 0xc3, 0x41, 0x3f, 0xf0, 0x90, 0x10, 0x08, 0x08, 0x04, 0x07, 0x3e, 0xf2, 0x01, 0x01, 0x00, 0x08, 0x08, 0x08, 0x78, 0xc0, 0x80, 0xc0, 0xc0, 0x80, 0xe0, 0x38, 0x00, 0xd0, 0x00, 0xc0, 0x80, 0x80, 0x00, 0xc0, 0x40, 0xf8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0xc0, 0x40, 0x60, 0x20, 0x30, 0x10, 0x10, 0x18, 0x08, 0x08, 0x08, 0x08, 0x0c, 0x04, 0x04, 0x04, 0x04, 0x04, 0x06, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x0e, 0x18, 0x30, 0x20, 0x20, 0x30, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0xc0, 0x79, 0x49, 0x48, 0x08, 0x00, 0xd1, 0x00, 0x41, 0x20, 0xa1, 0x00, 0xf1, 0x41, 0xc1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x04, 0x04, 0x06, 0x02, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0x01, 0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
// 'legendOSCbitmap', 11x48px
const uint8_t leg_Width    = 11;
const uint8_t leg_Height   = 48;
const uint8_t PROGMEM leg_Bitmap[] = {
	0xfe, 0xff, 0x03, 0x03, 0x03, 0xff, 0xfe, 0x00, 0x00, 0x33, 0x44,
	0xc1, 0xe3, 0x63, 0x6b, 0x63, 0x63, 0x61, 0x00, 0x00, 0xe7, 0x08,
	0x63, 0x67, 0x66, 0x66, 0x66, 0x7e, 0x3c, 0x00, 0x80, 0xb9, 0x42,
	0xf8, 0xfc, 0x0c, 0x0d, 0x0c, 0x1c, 0x18, 0x00, 0x01, 0x9d, 0x42,
	0x07, 0x0f, 0x0c, 0x0c, 0x0c, 0x0e, 0x06, 0x00, 0x00, 0xe7, 0x10,
	0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xcc, 0x22
// 'legend1', 7x9px
const uint8_t leg1_Width    = 7;
const uint8_t leg1_Height   = 10;
const uint8_t PROGMEM leg1_Bitmap[] = {
	0x00, 0x00, 0x06, 0xff, 0xff, 0x00, 0x00,
	0x00, 0x00, 0x03, 0x03, 0x03, 0x03, 0x00
// 'legend2', 7x9px
const uint8_t leg2_Width    = 7;
const uint8_t leg2_Height   = 10;
const uint8_t PROGMEM leg2_Bitmap[] = {
	0x0e, 0x8e, 0xc3, 0xe3, 0x73, 0x3e, 0x1e,
	0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03
const uint8_t wave_Width    = 15;
const uint8_t wave_Height   = 8;
const uint8_t PROGMEM rand_Bitmap[] = {
	0x40, 0x06, 0x21, 0x10, 0x42, 0x20, 0x0c, 0x42, 0x10, 0x22, 0x09, 0x44, 0x40, 0x12, 0x44
const uint8_t PROGMEM square_Bitmap[] = {
	0x40, 0x40, 0x40, 0x40, 0x7f, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x7f, 0x40, 0x40, 0x40
const uint8_t PROGMEM saw_Bitmap[] = {
	0x7f, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x7f, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20
const uint8_t PROGMEM triangle_Bitmap[] = {
	0x08, 0x04, 0x02, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02
const uint8_t PROGMEM sin_Bitmap[] = {
	0x40, 0x40, 0x60, 0x30, 0x1c, 0x06, 0x03, 0x01, 0x01, 0x03, 0x06, 0x1c, 0x30, 0x60, 0x40
//wave tables
PROGMEM const unsigned char waveTable[5][256]  ={
	//Random numbers wave
	{156,164, 53, 27,167,174,146, 99,157, 61, 85, 46, 80, 79, 58,159,
	56,115,234,119,182,127,150,170,133,173,219, 66,227,249,  6, 57,
	203,255, 45,229, 29, 30, 19, 91,202,158,201, 98,172, 63, 69,235,
	106, 95,220, 35,131, 59,248, 81,154, 86, 31,243, 62,238,242,171,
	90,147,109, 60, 94,130, 43,103,122,132, 84,143, 22,247,105, 15,
	169,187,  3, 51,254,251,110,114,108, 49, 36, 13,181,225,188,104,
	230, 41,144,168,183,  9,252, 93,124,107,141,177,140,  1,175, 28,
	26,233,138,231,185,  8,221,214,  4, 89,208, 47,  0,237, 34,176,
	40,120,212,  2,236, 64,153,134,224,209, 44, 97, 16,218,200,165,
	178,180,102,137,118,125,161,245,226, 48, 12, 65, 83,101,190,116,
	217,198,142,192,199,155, 38,126,184, 25,189, 17,151,232,207,240,
	96,186, 74,128,196,211,129,163, 21, 73,117,135,197, 14, 24,179,
	20,113, 10,152, 77,160, 70,149,121, 33, 75,112, 88,195,194, 42,
	136,100, 78, 32,191,193, 68, 55,223,204,  7,215,162, 11, 52, 92,
	250,239, 23, 87,  5,205, 54,139, 71,228,222, 37,241,206,210,213,
	148,244, 67,253, 50, 76, 82, 18,246,166, 72, 39,111,216,145,123,},
	//square wave
	{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
	0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,30,45,60,75,90,105,120,135, 150,165,180,195,210,225,240,
	255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
	255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
	255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
	255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,240,225,210,195,180,165,150,135,120,105,90,75,60,45,30,15},
	//left saw (negative slope)
	{255,254,253,252,251,250,249,248,247,246,245,244,243,242,241,240,239,238,237,236,235,234,233,232,231,230,229,228,227,226,225,224,223,222,221,220,219,218,217,216,215,214,213,
	212,211,210,209,208,207,206,205,204,203,202,201,200,199,198,197,196,195,194,193,192,191,190,189,188,187,186,185,184,183,182,181,180,179,178,177,
	176,175,174,173,172,171,170,169,168,167,166,165,164,163,162,161,160,159,158,157,156,155,154,153,152,151,150,149,148,147,146,145,144,143,142,141,
	140,139,138,137,136,135,134,133,132,131,130,129,128,127,126,125,124,123,122,121,120,119,118,117,116,115,114,113,112,111,110,109,108,107,106,105,104,103,102,101,100,99,98,97,96,95,94,93,92,91,90,
	89,88,87,86,85,84,83,82,81,80,79,78,77,76,75,74,73,72,71,70,69,68,67,66,65,64,63,62,61,60,59,58,57,56,55,54,53,52,51,50,49,48,47,46,45,44,43,42,
	41,40,39,38,37,36,35,34,33,32,31,30,29,28,27,26,25,24,23,22,21,20,19,18,17,16,15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0},
	//triangle wave
	{1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31,33,35,37,39,41,43,45,47,49,51,53,55,57,59,61,63,65,67,69,71,73,75,77,79,81,83,85,
	87,89,91,93,95,97,99,101,103,105,107,109,111,113,115,117,119,121,123,125,127,129,131,133,135,137,139,141,143,145,147,149,151,153,155,157,159,161,163,165,167,169,171,173,175,177,179,181,183,185,187,189,191,193,195,
	197,199,201,203,205,207,209,211,213,215,217,219,221,223,225,227,229,231,233,235,237,239,241,243,245,247,249,251,253,255,255,253,251,249,247,
	245,243,241,239,237,235,233,231,229,227,225,223,221,219,217,215,213,211,209,207,205,203,201,199,197,195,193,191,189,187,185,183,181,179,177,
	175,173,171,169,167,165,163,161,159,157,155,153,151,149,147,145,143,141,139,137,135,133,131,129,127,125,123,121,119,117,115,113,111,109,107,
	105,103,101,99,97,95,93,91,89,87,85,83,81,79,77,75,73,71,69,67,65,63,61,59,57,55,53,51,49,47,45,43,41,39,37,35,33,31,29,27,25,23,21,19,17,15,
	13,11,9,7,5,3,1},
	//sine wave
	{0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,
	70,73,76,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124,127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,
	221,223,225,227,229,231,233,234,236,238,239,240,242,243,244,245,247,248,249,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,
	253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,221,219,217,215,212,210,208,205,
	203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,
	102,99,96,93,90,87,84,81,78,76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,
	3,2,2,1,1,1,0,0,0} };
//Note frequencies but in TWORD values
PROGMEM uint16_t const twordNotes[88] = {
	46, 49, 52,																	//Octave 0
	55, 58, 62, 66, 69, 74, 78, 82, 87, 92, 98, 104,							//Octave 1
	110, 116, 123, 131, 138, 147, 155, 164, 174, 184, 195, 207,					//Octave 2
	219, 232, 246, 261, 276, 293, 310, 328, 348, 368, 390, 414,					//Octave 3
	438, 464, 492, 521, 552, 585, 619, 661, 695, 735, 779, 826,					//Octave 4
	875, 927, 982, 1040, 1102, 1168, 1237, 1311, 1389, 1470, 1558, 1651,		//Octave 5
	1749, 1853, 1963, 2080, 2203, 2334, 2473, 2620, 2776, 2940, 3115, 3301,		//Octave 6
	3497, 3704, 3925, 4158, 4405, 4667, 4945, 5238, 5550, 5880, 6230, 6600,		//Octave 7
	6993																		//Octave 8
volatile uint16_t	refclk=39185;			// refclk=3906 = 20MHz / 510 ... increase to compensate for higher pitch
											// 510 comes from formula for calculating phase correct PWM frequency
volatile uint16_t	phaccu[2] = {0, 0};		//These variables are used for
volatile uint16_t	tword[2] = {0, 0};		//outputting them with DDS
uint16_t			twordcalc[2] = {0, 0};	//
uint8_t				osc[2] = {0, 0};		//
uint16_t	dutyCycle;						//Variables for rollingMeanADC calculation
uint16_t	ADCinputs[INPsize];				//
uint8_t		inputsi;						//
uint32_t	rollingMeanADC;					//
bool	inputActive = false;				//When true rollingMean is being used to input values to an INPUT setting variable
uint8_t				smallTimer = 0;			//Counts 1/40ms - every timer0 overflow interrupt - starts at 0
volatile uint8_t	wait = 1;				//A part of note calculations is done once after every small timer tick. After the calculation this is set to 0
volatile uint8_t	millisecs = 0;			//Counts 1 ms every 40 smallTimer clicks
uint16_t	millisecsAutoButton = 0;		//Counts ms - used for AutoButton function
uint16_t	millisecsSerial = 0;			//Counts ms - used for timing some serial debugging commands
bool		serialGO = false;					//Starts the serial out
uint8_t	notePlaying[2] = {0, 0};		//Boolean  - enables oscillators if a note is playing
uint8_t	notePlayingSum = 0;				//Sum of notes that play
uint8_t		volume[2] = {0, 0};				//Current oscillator volume - calculated in envelope
uint8_t		volumecalc[2] = {0, 0};			//Used for calculations before assigning it to volume
uint8_t		volumeRelease[2] = {0, 0};		//Used for envelope calculations
uint8_t		waveKind[10] = {4,4, 4,4, 4,4, 4,4, 4,4};						//INPUT - oscillator wave used - for every button
uint8_t		phase0[10] = {0,0, 0,0, 0,0, 0,0, 0,0,};						//INPUT - beginning phase of a wave - for every button
uint8_t		key[10] = {57,57, 55,55, 52,52, 50,50, 48,48};					//INPUT - main note key - for every button
uint16_t	noteADC[10] = {550,550, 550,550, 550,550, 550,550, 550,550, };	//INPUT - main note ADC - for every button
bool		noteSource[10] = {1,1, 1,1, 1,1, 1,1, 1,1};						//INPUT - note source (key or ADC) - for every button
uint8_t		fine[10] = {127,127, 127,127, 127,127, 127,127, 127,127};		//INPUT - fine - for every button
uint8_t		oscVolume[10] = {255,255, 255,255, 255,255, 255,255, 255,255};	//INPUT - oscillator volume - for every button
uint8_t*	pwaveKind = waveKind;			//points to setting in use
uint8_t*	pphase0 = phase0;				//points to setting in use
uint8_t*	pkey = key;						//points to setting in use
uint16_t*	pnoteADC = noteADC;				//points to setting in use
bool*		pnoteSource = noteSource;		//points to setting in use
uint8_t*	pfine = fine;					//points to setting in use
uint8_t*	poscVolume = oscVolume;			//points to setting in use
uint8_t		attack[10] = {50,50, 50,50, 50,50, 50,50, 50,50};				//INPUT - Envelope attack - for every button
uint8_t		decay[10] = {190,190, 190,190, 190,190, 190,190, 190,190};		//INPUT - Envelope decay - for every button
uint8_t		sustain[10] = {70,70, 70,70, 70,70, 70,70, 70,70};				//INPUT - Envelope sustain - for every button
uint8_t		release[10] = {150,150, 150,150, 150,150, 150,150, 150,150};	//INPUT - Envelope release - for every button
uint8_t		releaseMode[10] = {1,1, 1,1, 1,1, 1,1, 1,1};					//INPUT - Release mode (0->linear or 1->nonlinear) - for every button
uint8_t*	pattack = attack;				//points to setting in use
uint8_t*	pdecay = decay;					//points to setting in use
uint8_t*	psustain = sustain;				//points to setting in use
uint8_t*	prelease = release;				//points to setting in use
uint8_t*	preleaseMode = releaseMode;		//points to setting in use
uint8_t		sweepSpeed[10] = {0,0, 0,0, 0,0, 0,0, 0,0};				//INPUT - Sweep speed (0->one semi a second, 255->fast!) - for every button
uint8_t		sweepDirection[10] = {0,0, 0,0, 0,0, 0,0, 0,0};			//INPUT - Sweep direction (0->down, 1->up, 2->from down, 3->from up) - for every button
uint8_t*	psweepSpeed = sweepSpeed;								//points to setting in use
uint8_t*	psweepDirection = sweepDirection;						//points to setting in use
bool		sweepStop[10] = {0, 0};									//Sweep should stop when 0 or 20KHz are reached
uint16_t	millisecsSweep[10] = {0, 0};							//Timer for the sweep incremented in ms
uint16_t			vibratoSpeed[10] = {0,0, 0,0, 0,0, 0,0, 0,0};				//INPUT - Vibration speed - for every button
uint8_t				vibratoDepth[10] = {35,35, 35,35, 35,35, 35,35, 35,35};		//INPUT - Vibration intensity - for every button
uint8_t				vibratoWaveKind[10] = {4,4, 4,4, 4,4, 4,4, 4,4};			//INPUT - Vibration wave kind - for every button
uint16_t*			pvibratoSpeed = vibratoSpeed;		//points to setting in use
uint8_t*			pvibratoDepth = vibratoDepth;		//points to setting in use
uint8_t*			pvibratoWaveKind = vibratoWaveKind;	//points to setting in use
uint16_t			vibratoPhacc[2] = {0, 0};			//Vibrato phase accumulator
volatile uint8_t	millisecsVibrato[2] = {0, 0};		//Vibrato millisecs
#define BTNno 9 //Number of buttons
volatile uint8_t*	buttonPort[BTNno] = {&PIND, &PIND, &PIND, &PIND, &PINC, &PINC, &PINC, &PINC, &PINC};	//Port of buttons in IC
uint8_t				buttonPin[BTNno] = {PIND0, PIND2, PIND3, PIND4, PINC0, PINC1, PINC2, PINC3, PINC4};		//Pin of buttons in IC
bool				buttonState[BTNno] = {0, 0, 0, 0, 0, 0, 0, 0, 0};										//Button states
uint8_t				millisecsButton[BTNno] = {0, 0, 0, 0, 0, 0, 0, 0, 0};									//Timers for muttons in ms for software debouncing
uint8_t		envelopeStage[2] = {4, 4};		//Tracks the current stage of the envelope
bool*		pEnvButton = &buttonState[0];	//The button envelope tracks for releasing
uint16_t	millisecsEnvelope[2] = {0, 0};	//Timer for the envelope incremented in ms
//Display stuff
uint8_t			millisecsFPS=0;						//Timer for 20FPS
bool			doRefresh = true;					//One frame refreshes after a button press and during the next silence
uint8_t			itemSelected[7]={0,0,0,0,0,0,0};	//Keeps track of selections across pages
const uint8_t   pageItems[7]={2,3,4,4,1,2,0};		//Number of page items is +1 of the value of this variable. pageItems[0] has a value of 1 - therefore page 0 has 2 items
uint8_t			page=0;								//Current page
bool EEPROMsaved = false;	//Turns true after save
inline void setupSerial() //serial for buade rate 9600 (UART)
	UBRR0H = (BRC >> 8);
	UBRR0L =  BRC;
	UCSR0B = (1 << TXEN0);
	UCSR0C = (1 << UCSZ01) | (1 << UCSZ00);
inline void setupPINS() //Sets DDRs and PORT registers
	DDRB  = 0b00101111;
	PORTB = 0b11010000;
	DDRC  = 0b00000000;
	PORTC = 0b00011111;
	DDRD  = 0b01000000;
	PORTD = 0b00011101;
inline void setupTIMERS() //Sets up TIMER0 overflow interrupt and PWM
	OCR0A  = 0;
	TIMSK0 = (1 << TOIE0);   //overflow interrupt - timer0
	TCCR0A = (1 << COM0A1) | (1 << WGM00);   //PWM and timer modes - timer0
	TIMSK1 = (0 << TOIE1);   //overflow interrupt - timer1
	TCCR1A = (0 << WGM10);   //timer mode - timer1
	TCNT0 = 0x00;
	TCNT1 = 0xff;
	TCCR0B = (1 << CS00);   //clock source = CLK, start PWM - timer0
	TCCR1B = (0 << CS10);   //clock source = CLK, start PWM - timer1
inline void setupADC() //Sets up ADC for and conversion complete interrupt. Then the first conversion starts. In the interrupt the ADC output is read and a new conversion is started
	ADMUX = (1 << REFS0) | (1 << MUX0) | (1 << MUX2);
	ADCSRA = (1 << ADEN) | (1 << ADIE) | (1 << ADPS0) | (1 << ADPS1) | (1 << ADPS2);
	DIDR0 = (1 << ADC5D);
inline void startConversion() //Sets the bit that starts a new ADC conversion
	ADCSRA |= (1 << ADSC);
void uint8toSerial(uint8_t gg) //Sends a uint8 to serial
	static uint8_t level = 0;
	if (millisecsSerial > 20)
		switch (level)
			case 0:
			UDR0 = gg/100+48;
			break;
			case 1:
			UDR0 = (gg%100)/10+48;
			break;
			case 2:
			UDR0 = gg%10+48;
			break;
			case 3:
			UDR0 = '\n';
			break;
		level > 3? level = 0 : ++level;
inline void waitForSample() //Pauses execution until next sample output
	wait = 1;
	while (wait);
void readEEPROMsettings() //Reads all settings from EEPROM and uses them
	eeprom_read_block((void*)waveKind, (const void*)20, 10);
	eeprom_read_block((void*)oscVolume, (const void*)30, 10);
	eeprom_read_block((void*)key, (const void*)40, 10);
	eeprom_read_block((void*)fine, (const void*)50, 10);
	eeprom_read_block((void*)phase0, (const void*)60, 10);
	eeprom_read_block((void*)attack, (const void*)70, 10);
	eeprom_read_block((void*)decay, (const void*)80, 10);
	eeprom_read_block((void*)sustain, (const void*)90, 10);
	eeprom_read_block((void*)release, (const void*)100, 10);
	eeprom_read_block((void*)releaseMode, (const void*)110, 10);
	eeprom_read_block((void*)sweepDirection, (const void*)120, 10);
	eeprom_read_block((void*)sweepSpeed, (const void*)130, 10);
	eeprom_read_block((void*)vibratoWaveKind, (const void*)140, 10);
	eeprom_read_block((void*)vibratoDepth, (const void*)150, 10);
	eeprom_read_block((void*)vibratoSpeed, (const void*)160, 20);
void updateEEPROMsettings() //Writes all settings in use to the EEPROM
	eeprom_update_block((const void*)waveKind, (void*)20, 10);
	eeprom_update_block((const void*)oscVolume, (void*)30, 10);
	eeprom_update_block((const void*)key, (void*)40, 10);
	eeprom_update_block((const void*)fine, (void*)50, 10);
	eeprom_update_block((const void*)phase0, (void*)60, 10);
	eeprom_update_block((const void*)attack, (void*)70, 10);
	eeprom_update_block((const void*)decay, (void*)80, 10);
	eeprom_update_block((const void*)sustain, (void*)90, 10);
	eeprom_update_block((const void*)release, (void*)100, 10);
	eeprom_update_block((const void*)releaseMode, (void*)110, 10);
	eeprom_update_block((const void*)sweepDirection, (void*)120, 10);
	eeprom_update_block((const void*)sweepSpeed, (void*)130, 10);
	eeprom_update_block((const void*)vibratoWaveKind, (void*)140, 10);
	eeprom_update_block((const void*)vibratoDepth, (void*)150, 10);
	eeprom_update_block((const void*)vibratoSpeed, (void*)160, 20);
inline void incrementTimers() //Increments all timers in use and push another input in the queue for the rolling mean of the ADC
	waitForSample();
	uint8_t ms = millisecs;
	millisecs = 0;
	for (uint8_t i=0; i < BTNno; ++i)
	millisecsButton[i] += ms;
	millisecsAutoButton += ms;
	millisecsSerial += ms;
	millisecsFPS += ms;
	millisecsEnvelope[0] += ms;
	millisecsEnvelope[1] += ms;
	millisecsSweep[0] += ms;
	millisecsSweep[1] += ms;
	millisecsVibrato[0] += ms;
	millisecsVibrato[1] += ms;
	ADCinputs[inputsi] = dutyCycle; //INPsize amount of inputs for the rolling mean
	inputsi > INPsize? inputsi=0 : inputsi++;
	startConversion();
void silenceOsc(uint8_t oscillator) //Silences one oscillator
	volumecalc[oscillator] = 0;
	while (volume[oscillator])
		--volume[oscillator];
		_delay_us(32);
void silenceOscs() //Silences all oscillators
// 	volumecalc[0] = 0;
// 	volumecalc[1] = 0;
	while (volume[0] + volume[1])
		if (volume[0]>0) --volume[0];
		if (volume[1]>0) --volume[1];
		_delay_us(160);
void play() //Starts playing a tone with the settings in use
	silenceOscs();
	waitForSample();
	notePlayingSum = 0;
	for (uint8_t i=0; i<2; ++i)
		phaccu[i] = pphase0[i] << 8;
		vibratoPhacc[i] = 0;
		millisecsSweep[i] = 0;
		sweepStop[i] = false;
		millisecsEnvelope[i] = 0;
		volumeRelease[i] = 0;
		volume[i] = 0;
		volumecalc[i] = 0;
		notePlaying[i] = 1;
		envelopeStage[i] = 0;
		millisecs = 0;
void doInput() //Does all the Potentiometer inputs depending on menu item selected
	if (inputActive)
		if (page==2)
			switch (itemSelected[2])
				case 0:
				if (rollingMeanADC < 200) pwaveKind[itemSelected[0]] = 0;//WAVE KIND INPUT
				else if (rollingMeanADC < 400) pwaveKind[itemSelected[0]] = 1;
				else if (rollingMeanADC < 600) pwaveKind[itemSelected[0]] = 2;
				else if (rollingMeanADC < 800) pwaveKind[itemSelected[0]] = 3;
				else pwaveKind[itemSelected[0]] = 4;
				break;
				case 1:
				poscVolume[itemSelected[0]] = rollingMeanADC >> 2;		//OSCILLATOR VOLUME INPUT
				break;
				case 2:
				pkey[itemSelected[0]] = (rollingMeanADC) * 87 / 1024;	//NOTE INPUT
				//twordcalc[0]=0x10000/refclk*( rollingMeanADC << 4 );// *16384/1024; Sweeps from 0 to 16384Hz
				break;
				case 3:
				pfine[itemSelected[0]]	= rollingMeanADC >> 2;			//FINE INPUT
				break;
				case 4:
				pphase0[itemSelected[0]] = rollingMeanADC >> 2;			//phase0 INPUT
				break;
		else if (page == 3)
			switch (itemSelected[3])
				case 0:
				(rollingMeanADC >> 2) < 1? pattack[itemSelected[0]] = 1 : pattack[itemSelected[0]] = (rollingMeanADC >> 2);		//ATTACK INPUT
				break;
				case 1:
				pdecay[itemSelected[0]] = (rollingMeanADC >> 2);			//DECAY INPUT
				if (pdecay[itemSelected[0]] < 2) pdecay[itemSelected[0]] = 2;
				break;
				case 2:
				psustain[itemSelected[0]] = (rollingMeanADC >> 2);			//SUSTAIN INPUT
				if (psustain[itemSelected[0]] < 2) psustain[itemSelected[0]] = 0;
				break;
				case 3:
				prelease[itemSelected[0]] = (rollingMeanADC >> 2);			//RELEASE INPUT
				if (prelease[itemSelected[0]] < 5) prelease[itemSelected[0]] = 5;
				break;
				case 4:
				preleaseMode[itemSelected[0]] = rollingMeanADC >> 9;		//RELEASE MODE INPUT
				break;
		else if (page == 4)
			switch (itemSelected[4])
				case 0:
				psweepDirection[itemSelected[0]] = rollingMeanADC >> 8;		//SWEEP DIRECTION INPUT
				break;
				case 1:
				psweepSpeed[itemSelected[0]] = rollingMeanADC >> 2;		//SWEEP SPEED INPUT
				break;
		else if (page == 5)
			switch (itemSelected[5])
				case 0:
				if (rollingMeanADC < 200) pvibratoWaveKind[itemSelected[0]] = 0;			//VIBRATO WAVE KIND INPUT
				else if (rollingMeanADC < 400) pvibratoWaveKind[itemSelected[0]] = 1;
				else if (rollingMeanADC < 600) pvibratoWaveKind[itemSelected[0]] = 2;
				else if (rollingMeanADC < 800) pvibratoWaveKind[itemSelected[0]] = 3;
				else pvibratoWaveKind[itemSelected[0]] = 4;
				break;
				case 1:
				pvibratoDepth[itemSelected[0]] = rollingMeanADC >> 2;		//VIBRATO DEPTH INPUT
				break;
				case 2:
				pvibratoSpeed[itemSelected[0]] = rollingMeanADC;			//VIBRATO SPEED INPUT
				break;
void doButtonPointers(const uint8_t button) //Changes pointers in use to one of the 5 sets of pointers for each "note button"
	pwaveKind = waveKind + button * 2;
	poscVolume = oscVolume + button * 2;
	pkey = key + button * 2;
	pfine = fine + button * 2;
	pphase0 = phase0 + button * 2;
	pattack = attack + button * 2;
	pdecay = decay + button * 2;
	psustain = sustain + button * 2;
	prelease = release + button * 2;
	preleaseMode = releaseMode + button * 2;
	psweepDirection = sweepDirection + button * 2;
	psweepSpeed = sweepSpeed + button * 2;
	pvibratoWaveKind = vibratoWaveKind + button * 2;
	pvibratoDepth = vibratoDepth + button * 2;
	pvibratoSpeed = vibratoSpeed + button * 2;
	pEnvButton = &buttonState[button + 4];
void action(uint8_t actionNum) //Every different button press action is in this function
	switch (actionNum)
		case 0: //button up
		//UDR0 = 'U';
		doRefresh = true;
		if (itemSelected[page] > 0) --itemSelected[page];
		break;
		case 1: //button down
		//UDR0 = 'D';
		//EEPROMsaved = false;
		doRefresh = true;
		if (itemSelected[page] < pageItems[page]) ++itemSelected[page];
		break;
		case 2: //button right
		//UDR0 = 'R';
		doRefresh = true;
		if (page == 0)
 			if (itemSelected[0] < 2)
				page = 1;
 			else if (EEPROMsaved == false)
				updateEEPROMsettings();
				EEPROMsaved = true;
		else if (page == 1)
			switch (itemSelected[page])
				case 0:
				page = 2;
				break;
				case 1:
				page = 3;
				break;
				case 2:
				page = 4;
				break;
				case 3:
				page = 5;
				break;
		else if (page <= 5)
			inputActive ^= true;		//Toggle input!
		break;
		case 3: //button left
		//UDR0 = 'L';
		doRefresh = true;
		if (page == 1 || page == 6)
			page = 0;
		else if (page >= 2 && page <=5)
			page = 1;
		break;
		case 4: //button 0
		//UDR0 = '0';
		if (pwaveKind != waveKind)
			doButtonPointers(0);
		play();
		break;
		case 5: //button 1
		//UDR0 = '1';
		if (pwaveKind != waveKind + 2)
			doButtonPointers(1);
		play();
		break;
		case 6: //button 2
		//UDR0 = '2';
		if (pwaveKind != waveKind + 4)
			doButtonPointers(2);
		play();
		break;
		case 7: //button 3
		//UDR0 = '3';
		if (pwaveKind != waveKind + 6)
			doButtonPointers(3);
		play();
		break;
		case 8: //button 4
		//UDR0 = '4';
		if (pwaveKind != waveKind + 8)
			doButtonPointers(4);
		play();
		break;
void buttonAction(volatile const uint8_t* PINX, const uint8_t PINXno) //Links microcontroller buttons to their actions
	for (uint8_t i=0; i<BTNno; ++i)
		if (PINX == buttonPort[i] && PINXno == buttonPin[i])
			action(i);
void buttonCheck(bool& bState, uint8_t& timer, volatile const uint8_t* PINX, const uint8_t PINXno, const uint8_t msDebounce = 50) //Software debounced button check
	waitForSample();
	if (((*PINX & (1 << PINXno))) == 0)
		if (!bState && timer > msDebounce)
			bState = 1;
			timer= 0;
			//UDR0 = 'P';
			buttonAction(PINX, PINXno);
		if (bState && (timer > msDebounce))
			bState = 0;
			timer = 0;
inline void CalcRollingMeanADC() //Calculating rolling mean for filtering(Low Pass) the potentiometer ADC input
	rollingMeanADC=0;
	for (uint8_t i = 0; i < INPsize; ++i)
		rollingMeanADC += ADCinputs[i];
	rollingMeanADC = rollingMeanADC >> 5;
int16_t fineAdj(uint8_t oscillator) //adjust the notes Fine
	if (pkey[oscillator] == 0)
		if (pfine[oscillator] <= 120)
		return (-48 * (120 - pfine[oscillator]))/120;
		else if (pfine[oscillator] < 135)
		return 0L;
		return (48 * (pfine[oscillator] - 135))/120;
	else if (pkey[oscillator] < 87)
			return -static_cast<int16_t>(pgm_read_word(&(twordNotes[pkey[oscillator]+1])) - pgm_read_word(&(twordNotes[pkey[oscillator]]))) * (120 - pfine[oscillator]) / 120;
			return 0L;
			return (pgm_read_word(&(twordNotes[pkey[oscillator]+1])) - pgm_read_word(&(twordNotes[pkey[oscillator]]))) * (pfine[oscillator] - 135) / 120;
			return (-420 * (120 - pfine[oscillator]))/120;
			return 0L;
			return (420 * (pfine[oscillator] - 135))/120;
uint16_t ADCtoTWORD(uint16_t ADC10bit) //Converts from ADC note to TWORD note
	if (ADC10bit < 93)
		return ( ADC10bit * 26 ) / 93;//
	else if (ADC10bit < 186)
		return ( ADC10bit * 52 ) / 186;
	else if (ADC10bit < 279)
		return ( (ADC10bit-93) * 104 ) / 186;
	else if (ADC10bit < 372)
		return ( (ADC10bit-186) * 207 ) / 186;
	else if (ADC10bit < 465)
		return ( (ADC10bit-279) * 414UL ) / 186;
	else if (ADC10bit < 558)
		return ( (ADC10bit-372) * 826UL ) / 186;
	else if (ADC10bit < 651)
		return ( (ADC10bit-465) * 1651UL ) / 186;
	else if (ADC10bit < 744)
		return ( (ADC10bit-558) * 3301UL ) / 186;
	else if (ADC10bit < 837)
		return ( (ADC10bit-651) * 6600UL ) / 186;
	else if (ADC10bit < 930)
		return ( (ADC10bit-744) * 13200UL ) / 186;
		return ( (ADC10bit-838) * 26400UL ) / 194;
uint16_t TWORDtoADC(uint16_t TWORD16bit) //Converts from TWORD note to ADC note
	if (TWORD16bit < 26)
	return ( TWORD16bit * 93 ) / 26;
	else if (TWORD16bit < 52)
	return ( TWORD16bit * 186 ) / 52;
	else if (TWORD16bit < 104)
	return ( (TWORD16bit * 93) / 52 ) + 93;
	else if (TWORD16bit < 207)
	return ( (TWORD16bit * 93) / 104) + 186;
	else if (TWORD16bit < 414)
	return ( (TWORD16bit * 93) / 207) + 279;
	else if (TWORD16bit < 826)
	return ( (TWORD16bit * 93UL) / 414) + 372;
	else if (TWORD16bit < 1651)
	return ( (TWORD16bit * 93UL) / 826) + 465;
	else if (TWORD16bit < 3301)
	return ( (TWORD16bit * 93UL) / 1651) + 558;
	else if (TWORD16bit < 6600)
	return ( (TWORD16bit * 93UL) / 3301) + 651;
	else if (TWORD16bit < 13200)
	return ( (TWORD16bit * 93UL) / 6600) + 744;
	return ( (TWORD16bit * 93UL) / 13200) + 838;
void doMainNote(uint8_t oscillator) //Uses key and fine settings to define the primary tuning word - this tword might be altered by sweep and vibrato effects before finally being output
	waitForSample();
// 	if (pnoteSource[oscillator])
		twordcalc[oscillator] = pgm_read_word(&(twordNotes[pkey[oscillator]])) + fineAdj(oscillator);
// 	else
// 		twordcalc[oscillator] = ADCtoTWORD(0x10000/refclk*( pnoteADC[oscillator] << 4 )) + fineAdj(oscillator);
void doSweep(uint8_t oscillator) //Sweep effect
	waitForSample();
	if (psweepSpeed[oscillator] > 0 && !sweepStop[oscillator])
	switch (psweepDirection[oscillator])
		case 0:
		if ((static_cast<uint32_t>(millisecsSweep[oscillator]) * psweepSpeed[oscillator] >> 7) > TWORDtoADC(twordcalc[oscillator]))
			silenceOsc(oscillator);
			envelopeStage[oscillator] = 4;
			notePlaying[oscillator] = 0;
			sweepStop[oscillator] = true;
		twordcalc[oscillator] = ADCtoTWORD( TWORDtoADC(twordcalc[oscillator]) - (static_cast<uint32_t>(millisecsSweep[oscillator]) * psweepSpeed[oscillator] >> 7) );
		break;
		case 1:
		if (TWORDtoADC(twordcalc[oscillator]) + (static_cast<uint32_t>(millisecsSweep[oscillator]) * psweepSpeed[oscillator] >> 7) > 1024)
		twordcalc[oscillator] = ADCtoTWORD( TWORDtoADC(twordcalc[oscillator]) + (static_cast<uint32_t>(millisecsSweep[oscillator]) * psweepSpeed[oscillator] >> 7) );
		break;
		case 2:
		if (93 - (millisecsSweep[oscillator] * psweepSpeed[oscillator] >> 8) > TWORDtoADC(twordcalc[oscillator]))
			twordcalc[oscillator] = 0;
		else if ((millisecsSweep[oscillator] * psweepSpeed[oscillator] >> 8) < 93)
			twordcalc[oscillator] = ADCtoTWORD( TWORDtoADC(twordcalc[oscillator]) - 93 + (millisecsSweep[oscillator] * psweepSpeed[oscillator] >> 8));
		break;
		case 3:
			twordcalc[oscillator] = ADCtoTWORD( TWORDtoADC(twordcalc[oscillator]) + 93 - (millisecsSweep[oscillator] * psweepSpeed[oscillator] >> 8));
		break;
void doVibrato(uint8_t oscillator) //Vibrato effect
	waitForSample();
	if (pvibratoSpeed[oscillator] > 1)
		uint8_t ms = millisecsVibrato[oscillator];
		millisecsVibrato[oscillator] = 0;
		if (pvibratoSpeed[oscillator] < 160)
		vibratoPhacc[oscillator] += ((pvibratoSpeed[oscillator] >> 4)) * ms;
		else if (pvibratoSpeed[oscillator] < 352)
		vibratoPhacc[oscillator] += (((pvibratoSpeed[oscillator] - 160) >> 3) + 10) * ms;
		else if (pvibratoSpeed[oscillator] < 512)
		vibratoPhacc[oscillator] += (((pvibratoSpeed[oscillator] - 352) >> 2) + 34) * ms;
		else if (pvibratoSpeed[oscillator] < 680)
		vibratoPhacc[oscillator] += (((pvibratoSpeed[oscillator] - 512) >> 1) + 74) * ms;
		else if (pvibratoSpeed[oscillator] < 850)
		vibratoPhacc[oscillator] += (((pvibratoSpeed[oscillator] - 680) << 2) + 158) * ms;
		vibratoPhacc[oscillator] += (((pvibratoSpeed[oscillator] - 850) << 3) + 838) * ms;
		twordcalc[oscillator] = ADCtoTWORD( TWORDtoADC(twordcalc[oscillator]) + (((pgm_read_byte( &waveTable[ pvibratoWaveKind[oscillator] ][ vibratoPhacc[oscillator] >> 8 ] ) - 128) * pvibratoDepth[oscillator]) / 255));
void doEnvelope(uint8_t oscillator, bool* bState) //Envelope
	waitForSample();
	switch (envelopeStage[oscillator])
		case 0:
		if ((*bState) && ((millisecsEnvelope[oscillator] << 4) / pattack[oscillator] < 255))
			volumecalc[oscillator] = (millisecsEnvelope[oscillator] << 4) / pattack[oscillator];		// millisecsEnvelope[oscillator] / (attack/16)
		else if (*bState)
			volumecalc[oscillator] = 255;
			++envelopeStage[oscillator];
			millisecsEnvelope[oscillator] = 0;
		break;
		case 1:
		if ((*bState) && (volumecalc[oscillator] > psustain[oscillator]) && (psustain[oscillator] > 0))
			volumecalc[oscillator] = 255 - ((millisecsEnvelope[oscillator] * 16) / pdecay[oscillator]) ;	// 255 - millisecsEnvelope[oscillator] / (decay/16);
		else if ((*bState) && (psustain[oscillator] > 0))
			volumecalc[oscillator] = psustain[oscillator];
		break;
		case 2:
		if (!(*bState) || (psustain[oscillator] == 0))
		break;
		case 3:
		if (volumecalc[oscillator] <= 1)
		else if (release[oscillator] > 253)
			break;
			if (!volumeRelease[oscillator]) volumeRelease[oscillator] = volumecalc[oscillator];
			if (!preleaseMode[oscillator])
				if (volumeRelease[oscillator] > ((millisecsEnvelope[oscillator] << 4) / prelease[oscillator]))
					volumecalc[oscillator] = volumeRelease[oscillator] - ((millisecsEnvelope[oscillator] << 4) / prelease[oscillator]); //Linear release
				else volumecalc[oscillator] = 0;
				volumecalc[oscillator] = (volumeRelease[oscillator] * prelease[oscillator]) / ((millisecsEnvelope[oscillator] >> 1) + prelease[oscillator]) - (millisecsEnvelope[oscillator]/1000); //Non linear release
		break;
inline void updateNotes() //Updates note in use for the sampler
	waitForSample();
	tword[0] = twordcalc[0];
	volume[0] = volumecalc[0] * poscVolume[0] / 510UL;
	tword[1] = twordcalc[1];
	volume[1] = volumecalc[1] * poscVolume[1] / 510UL;
	notePlayingSum = 0;
	notePlayingSum += notePlaying[0];
	notePlayingSum += notePlaying[1];
bool BitmapXYaccess(const uint8_t* bitmap, const uint8_t& bwidth, const uint8_t& x = 0, const uint8_t& y = 0) //Returns the 0 or 1 of the bitmap on its x,y position
	return (pgm_read_byte( &bitmap[x + (y >> 3) * bwidth] ) >> (y % 8)) & 0x01;
void nokia_lcd_write_bitmap(const uint8_t* bitmap, const uint8_t& bwidth, const uint8_t& bheight, const uint8_t& x = 0, const uint8_t& y = 0) //Writes a bitmap of dimensions bwidth,bheight on the display, starting at x,y
	for (uint8_t i = 0; i < bwidth; ++i)
		for (uint8_t j = 0; j < bheight; ++j)
			nokia_lcd_set_pixel(i+x,j+y, BitmapXYaccess(bitmap, bwidth, i, j) );
uint16_t _map(uint16_t X, uint16_t A, uint16_t B, uint16_t C, uint16_t D) //Standard mapping function
	uint16_t Y = 0;
	if (X < A)
		C < D? Y = C : Y = D;
	else if (X > B)
		C < D? Y = D : Y = C;
		Y = (X-A)*(D-C)/(B-A) + C;
	return Y;
inline void introDisplay() //Does the intro of the display after power on
	nokia_lcd_clear();
	nokia_lcd_write_bitmap(wf_Bitmap, wf_Width, wf_Height);
	nokia_lcd_render();
	_delay_ms(3000);
	nokia_lcd_clear();
	nokia_lcd_set_cursor(0, 0);
	nokia_lcd_write_string("ZNEAR", 3);
	nokia_lcd_set_cursor(5, 23);
	nokia_lcd_write_string("Synth", 3);
	nokia_lcd_render();
	_delay_ms(3000);
void drawCursor(uint8_t xpos, uint8_t fontSize) //Draws the cursor on the display
	nokia_lcd_set_cursor(xpos, itemSelected[page] * (8 * fontSize));
	if (inputActive) nokia_lcd_write_char(0x80 , fontSize); //20- ,80-?, 81-? void
	else nokia_lcd_write_char(0x81 , fontSize); //20- ,80-?, 81-? void
void drawLegend() //Draws the oscillator legend
	nokia_lcd_write_bitmap(leg_Bitmap, leg_Width, leg_Height);
	if (itemSelected[0] == 0)
		nokia_lcd_write_bitmap(leg1_Bitmap, leg1_Width, leg1_Height, 0, 38);
		nokia_lcd_write_bitmap(leg2_Bitmap, leg2_Width, leg2_Height, 0, 38);
void drawNote(const uint8_t& oscillator) //draws the note in use in the NTE field
	if (pkey[oscillator] < 3)
		nokia_lcd_write_char('0', 1);
		nokia_lcd_write_char(((pkey[oscillator] - 3)/12 + 1)+48, 1);
	switch (pkey[oscillator]%12)
		case 0:
		nokia_lcd_write_string("A",1);
		break;
		case 1:
		nokia_lcd_write_string("A#",1);
		break;
		case 2:
		nokia_lcd_write_string("B",1);
		break;
		case 3:
		nokia_lcd_write_string("C",1);
		break;
		case 4:
		nokia_lcd_write_string("C#",1);
		break;
		case 5:
		nokia_lcd_write_string("D",1);
		break;
		case 6:
		nokia_lcd_write_string("D#",1);
		break;
		case 7:
		nokia_lcd_write_string("E",1);
		break;
		case 8:
		nokia_lcd_write_string("F",1);
		break;
		case 9:
		nokia_lcd_write_string("F#",1);
		break;
		case 10:
		nokia_lcd_write_string("G",1);
		break;
		case 11:
		nokia_lcd_write_string("G#",1);
		break;
void draw8bitBar(const uint8_t& oscillator, const uint8_t* target) //Draws a bar for certain setting on the menu
	nokia_lcd_write_char(0x84, 1);
	for (uint8_t i=0; i<6; ++i)
		if (target[oscillator] > i*42+21)
			nokia_lcd_write_char(0x83, 1);
			nokia_lcd_write_char(0x82, 1);
	nokia_lcd_write_char(0x85, 1);
inline void drawRmo(const uint8_t& oscillator) //Draws the release mode used
	if (preleaseMode[oscillator])
		nokia_lcd_write_string("NON-LIN", 1);
		nokia_lcd_write_string("LINEAR", 1);
inline void drawSweepDir(const uint8_t& oscillator) //Draws the sweep direction used
		case 0:
		nokia_lcd_write_string("<--", 1);
		nokia_lcd_write_char(0x86, 1);
		break;
		case 1:
		nokia_lcd_write_string("-->", 1);
		break;
		case 2:
		break;
		case 3:
		break;
void drawWaveKind(const uint8_t& oscillator, const uint8_t* target) //Draws the wave kind used
	switch (target[oscillator])
		case 0:
		nokia_lcd_write_char(' ', 1);
		nokia_lcd_write_bitmap(rand_Bitmap, wave_Width, wave_Height, 42, 0);
		break;
		case 1:
		nokia_lcd_write_bitmap(square_Bitmap, wave_Width, wave_Height, 42, 0);
		break;
		case 2:
		nokia_lcd_write_bitmap(saw_Bitmap, wave_Width, wave_Height, 42, 0);
		break;
		case 3:
		nokia_lcd_write_bitmap(triangle_Bitmap, wave_Width, wave_Height, 42, 0);
		break;
		case 4:
		nokia_lcd_write_bitmap(sin_Bitmap, wave_Width, wave_Height, 42, 0);
		break;
inline void drawFine(const uint8_t& oscillator) //Draws the fine adjustment used in the FIN field
		if (i<3)
			if (i==2 && pfine[oscillator] <= 120)
			else if (pfine[oscillator] < i*42+21)
			if (i==3 && pfine[oscillator] >= 135)
			else if (pfine[oscillator] > i*42+21)
	for (uint8_t i=0; i<7; ++i)
		nokia_lcd_set_pixel(59, 24 + i, 1);
void drawPhase(const uint8_t& oscillator) //Draws the initial phase of the wave that is used in the field PHA
	uint16_t temp = pphase0[oscillator] * 360UL / 255;
	nokia_lcd_write_char(temp/100+48, 1);
	temp %= 100;
	nokia_lcd_write_char(temp/10+48, 1);
	temp %= 10;
	nokia_lcd_write_char(temp+48, 1);
#define MENU_X 18
void doDisplay() //Draws on the display depending on what page it is on
	waitForSample();
	nokia_lcd_clear();
	switch (page)
		case 0:
		nokia_lcd_set_cursor(12, 0);
		nokia_lcd_write_string("OSC1", 2);
		nokia_lcd_set_cursor(12, 16);
		nokia_lcd_write_string("OSC2", 2);
		nokia_lcd_set_cursor(12, 32);
		if (EEPROMsaved)
			nokia_lcd_write_string("OK", 2);
			nokia_lcd_write_string("SAVE", 2);
 		drawCursor(1, 2);
		break;
		case 1:
 		drawLegend();
		nokia_lcd_set_cursor(MENU_X,0);
		nokia_lcd_write_string("NOTE", 1);
		nokia_lcd_set_cursor(MENU_X,8);
		nokia_lcd_write_string("ENVELOPE", 1);
		nokia_lcd_set_cursor(MENU_X,16);
		nokia_lcd_write_string("SWEEP", 1);
		nokia_lcd_set_cursor(MENU_X,24);
		nokia_lcd_write_string("VIBRATO", 1);
 		drawCursor(13, 1);
		break;
		case 2:
		drawLegend();
		nokia_lcd_write_string("WAV", 1);
		drawWaveKind(itemSelected[0], pwaveKind);
		nokia_lcd_write_string("VOL", 1);
		draw8bitBar(itemSelected[0], poscVolume);
		nokia_lcd_write_string("NTE ", 1);
		drawNote(itemSelected[0]);
		nokia_lcd_write_string("FIN", 1);
		drawFine(itemSelected[0]);
		nokia_lcd_set_cursor(MENU_X,32);
		nokia_lcd_write_string("PHA ", 1);
		drawPhase(itemSelected[0]);
		nokia_lcd_write_string("deg", 1);
 		drawCursor(13, 1);
		break;
		case 3:
		drawLegend();
		nokia_lcd_write_string("ATK", 1);
		draw8bitBar(itemSelected[0], pattack);
		nokia_lcd_write_string("DEC", 1);
		draw8bitBar(itemSelected[0], pdecay);
		nokia_lcd_write_string("SUS", 1);
		draw8bitBar(itemSelected[0], psustain);
		nokia_lcd_write_string("REL", 1);
		draw8bitBar(itemSelected[0], prelease);
		nokia_lcd_write_string("Rmo", 1);
		drawRmo(itemSelected[0]);
 		drawCursor(13, 1);
		break;
		case 4:
		drawLegend();
		nokia_lcd_write_string("DIR  ", 1);
		drawSweepDir(itemSelected[0]);
		nokia_lcd_write_string("SPE", 1);
		draw8bitBar(itemSelected[0], psweepSpeed);
 		drawCursor(13, 1);
		break;
		case 5:
		drawLegend();
		drawWaveKind(itemSelected[0], pvibratoWaveKind);
		nokia_lcd_write_string("DEP", 1);
		draw8bitBar(itemSelected[0], pvibratoDepth);
		uint8_t temp = (pvibratoSpeed[itemSelected[0]]) >> 2;
		draw8bitBar(itemSelected[0], &temp-itemSelected[0]);
 		drawCursor(13, 1);
		break;
// 		case 6:
// 		break;
nokia_lcd_render();
 	setupSerial();
 	setupPINS();
	setupADC();
	startConversion();
	setupTIMERS();
	nokia_lcd_init();
	introDisplay();
	readEEPROMsettings();
	sei();
	doDisplay();
		incrementTimers();
		if ((millisecsFPS > 200 && (inputActive || (!notePlayingSum))) || doRefresh)
			millisecsFPS = 0;
 			doDisplay();
			doRefresh = false;
			buttonCheck(buttonState[i], millisecsButton[i], buttonPort[i], buttonPin[i]);
		CalcRollingMeanADC();
		//ADCtoSerial();      //For Debugging purposes
		doInput();
		doMainNote(0);
		doMainNote(1);
		doEnvelope(0, pEnvButton);
		doEnvelope(1, pEnvButton);
		doSweep(0);
		doSweep(1);
		doVibrato(0);
		doVibrato(1);
		updateNotes();
		//uint8toSerial(notePlaying[0]);  //Debugging purpose
ISR (TIMER0_OVF_vect) //This is the interrupt routine for the DDS and after calculations it occupies almost 1/3 of the total CPU time
  	if (notePlayingSum)
 		phaccu[0] += tword[0];
 		osc[0] = (pgm_read_byte( &waveTable[ pwaveKind[0] ][ phaccu[0] >> 8 ]));
		phaccu[1] += tword[1];
 		osc[1] = (pgm_read_byte( &waveTable[ pwaveKind[1] ][ phaccu[1] >> 8 ]));
		OCR0A = (( osc[0] * volume[0] ) >> 8) + (( osc[1] * volume[1] ) >> 8);
	smallTimer++; //increment small timer
	if(smallTimer > 40)
		smallTimer = 0;
		++millisecs; //increment milliseconds every 40 small timer ticks
	wait = 0;
ISR(ADC_vect) //Interrupt subroutine for extracting the ADC converted value every time the conversion is completed
	dutyCycle = ADC;
Photo of synth:
My first composition using it:
https://soundcloud.com/ilias-cha...
(although it sounds as though the synth has a polyphony >2 in this recording, it is only because I overlaped some samples from the synth in my DAW)
Sorry for no schematic I never drew one. If someone is curious I could try drawing one out
Nice use of comments ;-)
I would stay away from any other than timer ISR, and pull the adc in that ISR.
for sound small jitter is ok, but you can hear small clicks.
Yeah I had some thoughts about that ADC ISR too. Maybe I'll try putting it in the main, timer-incrementation section.
Are you referring to the clicks the bells make at their start?
sorry for nor being clear:
clicks would be that the DDS stop when in the other (ADC) ISR.
But it's a very short (read fast) ISR so perhaps it's ok.
Though little used these days it seems, there is a projects section where you can post your completed projects for others to view and learn from on this site.
Congratulations on a job well done!
Keys to wealth:
The pin output is done by the hardware on a compare match.
The ADC is not going to interfere with DDS.
More likely the timer interrupt will delay reading ADC.
Not sure whether it matters.
the ADC interrupt will delay the timer interrupt => delayed DDS update
Here is how I understand it (correct me if I am wrong)
If the execution is inside the ADC ISR when the TOVF flag is set the TOVF ISR could be delayed
but if the execution is in main when somehow both ISR flags are set, the TOVF ISR is prioritized
It would probbaly be better to get rid of the ADC ISR then.. I could try reading it every 1ms
The timer interrupt ISR does not update the pin.
That is done by a compare match the hardware when the overflow occurs, regardless of when the ISR is taken.
There is wiggle room.
If it's more than 30 cycles, the ADC interrupt will never interfere with DDS updates.
Such wiggle room is one reason to use compare
match the hardware instead of directly modifying a pin.
I am actually using a timer overflow interrupt and not a compare match isr. In my program the timer 0 overflow isr is used to update the pin OCR0A. Could you explain what you mean more thoroughly?
First I guess that it's as good it gets without using a DAC.
I just fear that the time it takes to make both ISR's can be to long, and the ADC ISR don't add anything, just place it in the other ISR down in the smalltimer part.
a bigger click problem could be that
needs to be atomic, (I'm not 100% sure of the flow but guess that tword get updated while playing).
Yep it does! Could this simple assignment be stopped mid execution by an interrupt? That would definitely be a no no
Oops.
The principle still holds: the hardware flips the bit or not regardless of when the ISR is taken.
it's a 8 bit micro, so 16 bit calculation values (at least in C) has to be atomic if used in both ISR and main, else you can be out of sync of high and low byte.
I believe it's still in  <util/atomic.h>
So I just simulated this segment
	waitForSample();
	notePlayingSum = notePlaying[0] + notePlaying[1];
I am not using atomic but in stead I use this waitforsample function that makes sure the execution will continue only after a return from the timer overflow ISR.
After the return from the ISR there are about 300 clock cycles until the next timer overflow which is enough for all 5 lines of code to be executed.
I just checked it out using the simulator. It is fine
Pages
