Getting started with SAMD21J18A? Compiler choice
5 posts / 0 new
Hi All
I am thinking about using the  SAMD21J18A  for a new project with the ATWINC3400.
Can I use the JTAG IC3, with SAM devices?
I am to use ASF to get the project up and running quickly.
I have noticed there is a choice of compilers, you have the standard GCC and XC8, what is the difference does it affect the ASF library?
Regards
DJ
ASF came from Atmel - it assumes GCC, AKAIK.
djoshi wrote:
Can I use the JTAG ICE
What does the documentation tell you: http://ww1.microchip.com/downloa... ?
As the name suggests, looks like it's JTAG only - so that's a no.
To start with SAMD21 I would strongly suggest that you gat a SAMD21 XPlained Pro:
https://www.microchip.com/Develo...
That gives you a built-in debugger and will be recognised by Atmel Microchip Studio - which will give you a load of ready-to-go examples
https://www.microchipdirect.com/... - there seems to be a 15% coupon code at the moment
Yes, I have seen that offer, I will place an order tomorrow.
I am using the JTAG ICE 3(small typo), will that not work?
Regards
DJ
Again, what does its documentation tell you ?
djoshi wrote:
XC8
Doesn't the 8 indicate that it's for 8-bit targets ... ?
