I am using Arduino Uno
I read the analog input and compare it to a value that I want.
I also use hysteresis and delay to run two pwm controlled motors.
When I run the program below, everything works fine if I turn the encoder slowly, any value is left in any of its output when I turn the encoder a little fast.
Is the logic in the program completely wrong?
int val;
int val2;
int buttonState;
int Mode = 0;
enum PinAssignments
encoderPinA = 2,
encoderPinB = 3,
clearButton = A4,
switchPin = A5,
volatile unsigned int encoderPos = 320; // degree celcius
volatile unsigned int encoderPos_time = 5;
volatile unsigned int encoderPos_hyst = 6;
unsigned int lastReportedPos = 0;
static boolean rotating = false;
boolean A_set = false;
boolean B_set = false;
#define COLD 11
#define HOT 10
long int coldout = 0;
long int hotout = 0;
long int analog_input = 0;
long int analog_input_1 = 0;
unsigned int count_two = 0;
unsigned int num = 0;
unsigned int count_time = 0;
unsigned int count_hyst = 0;
void setup()
pinMode (COLD, OUTPUT);
pinMode (HOT, OUTPUT);
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
pinMode(clearButton, INPUT_PULLUP);
pinMode(switchPin, INPUT_PULLUP);
buttonState = digitalRead(switchPin);
attachInterrupt(0, doEncoderA, CHANGE);
attachInterrupt(1, doEncoderB, CHANGE);
void loop()
val = digitalRead(switchPin);
delay (10);
val2 = digitalRead(switchPin);
if (val == val2) {
if (val != buttonState){
if (val== LOW ) {
if (Mode == 0) {
Mode = 1;
if (Mode == 1) {
Mode = 2;
if (Mode == 2) {
Mode = 0;
buttonState = val;
if (Mode == 0) {
if (lastReportedPos != encoderPos)
lastReportedPos = encoderPos;
if (Mode == 1){
if (Mode == 2){
rotating = true; // reset the debouncer
if (digitalRead(clearButton) == LOW ){
encoderPos = 328;
encoderPos_time = 1;
encoderPos_hyst = 0;
for (int i=0;i<500;i++)
analog_input = analog_input + analogRead(A0);
delay (1);
analog_input = analog_input / 501 ; // testing purpose
int converted = map((analog_input*0.963), 0, 1023, 0,5000);
analog_input_1 = (analog_input/2.1258);// testing purpose
//-- CHECK FROM HERE
double gap = abs((encoderPos-encoderPos_hyst) - analog_input_1);
double gap2 = abs((encoderPos+encoderPos_hyst) - analog_input_1);
if (analog_input_1 >= (encoderPos-encoderPos_hyst))
if (analog_input_1 >= (encoderPos+encoderPos_hyst))// **
coldout = gap2 ;
coldout = coldout*25; // testing purpose
coldout = min(coldout,250); // testing purpose
hotout == 0;
coldout == 0;
analogWrite(COLD,coldout);
if (analog_input_1 <= (encoderPos-encoderPos_hyst))
if (analog_input_1 <= (encoderPos+encoderPos_hyst))// **
hotout = gap;
hotout = hotout*25; // testing purpose
hotout = min(hotout,250); // testing purpose
coldout == 0;
hotout == 0;
analogWrite(HOT,hotout);
unsigned char i=0;
unsigned int k = 0;
while(number)
k = ( k ) | ((number%10) << i*4);
number = number / 10;
i++;
return(k);
void doEncoderA() // with debounce
if ( rotating ) delay (2);
if ( digitalRead(encoderPinA) != A_set )
A_set = !A_set;
if ( A_set && !B_set )
if (Mode == 0) {
encoderPos += 1;
if (Mode == 1) {
encoderPos_time += 1;
if (Mode == 2) {
encoderPos_hyst += 1;
rotating = false; // no more debouncing until loop() hits again
void doEncoderB() //with DEBOUNCE
if ( digitalRead(encoderPinB) != B_set )
B_set = !B_set;
if ( B_set && !A_set )
if (Mode == 0) {
encoderPos -= 1;
if (Mode == 1) {
encoderPos_time -= 1;
if (Mode == 2) {
encoderPos_hyst -= 1;
rotating = false;
