MISRA C Rules
15 posts / 0 new
After a bit of curiosity about what the MISRA C rules are, I found one that really puzles me. I a pretty sure there is a logical explanation but I have no clue what it might be. To wit:
MISRA C 2012 Amendment 2:
Rule 21.21
The Standard Library function system of <stdlib.h> shall not be used
OK, many of us (including me) don't really know what is in stdlib.c, or where the particular implementation for our compiler of choice might have originated. That much is fairly clear. But, for me, the BIG question is: What is one to do instead of using stdlib.h ?
I have a copy of MISRA in my cupboard somewhere - I'll have to see if I can find it. But the fact is that the proper MISRA book (when you buy it) not only gives the rules but each has a detailed explanation of why it was implemented by the MISRA committee.
Equally if you have a paid for MISRA checking tool like Klockwork, QAC or similar then not only do they scan and flag your code but for each, when you select it they, equally, will have chapter and verse from the MISRA guide as to why the restriction exists.
Just out of interest where are you seeing your MISRA list of requirements anyway? If you found it on the internet "for free" then it almost certainly is not sanctioned by MISRA because you don't normally get to see this stuff without paying MISRA some money!
EDIT: just googling myself it seems that while the rule says <stdlib.h> should not be used it's really just one thing within it that they have an objection to and that is the function system() which is how you invoke OS commands on operating systems like Windows and Linux. The "command" you pass can actually be mutiple (piped) commands. This is (obviously) a security vulnerability.
(usually when trying to achieve MISRA compliance you and the customer can agree some "waivers" for specific instances where you must break the MISRA rules as there's no alternative)
EDIT2: Actually the Klockwork site is pretty good at explaining rationale. If you search "Misra.stdlib" on this page:
https://bullwhip.physio-control....
then you will see that most things in stdlib.h were already blocked anyway. For example:
So you can't use atof(), atoi(), atol() anyway - the rationale is "These functions have undefined behaviour associated with them when the string cannot be converted. ". Also in stdlib is malloc/free. One of the biggest MISRA rules is:
The identifiers calloc, malloc, realloc and free shall not be used and no macro with one of these names shall be expanded.
Rationale
Use of dynamic memory allocation and deallocation routines provided by The Standard Library can lead to undefined behaviour, for example:
  • Memory that was not dynamically allocated is subsequently freed;
  • A pointer to freed memory is used in any way;
  • Accessing allocated memory before storing a value into it.
The fact is that when you start to remove the atoX() functions and malloc()/free() (and other rules) from stdlib what are you actually left with anyway?
Apart from the 'C' standard itself, my first point of reference would be:
https://en.cppreference.com/w/c/header
Don't be put off by the "cpp" in the domain name - it covers plain 'C'.
Specifically: https://en.cppreference.com/w/cpp/header/cstdlib
Also good ol' Wikipedia:
https://en.wikipedia.org/wiki/C_standard_library#Header_files
As this is about AVRs I'd start here:
https://www.nongnu.org/avr-libc/...
A single user copy of MISRA C:2012 is £12 these days, so well worth a copy ka7ehk.
On the issue of implementation-defined behavior, note also one of the required directives, Dir 1.1, reads "Any implementation-defined behavior on which the output of the program depends shall be documented and understood", further increasing the documentation requirements.
Note the implementation-defined documentation pack is in addition to the waiver pack, of course.
Copy what's needed.
P.S.
ka7ehk wrote:
... or where the particular implementation for our compiler of choice might have originated.
That may be an issue with proprietary C toolchains.
C's namespace is wide open ... invoke the function ... specify the directory where the function's object code is stored.
http://svn.savannah.gnu.org/viewvc/avr-libc/trunk/avr-libc/libc/stdlib/?sortby=file&pathrev=2551
http://svn.savannah.gnu.org/viewvc/avr-libc/trunk/avr-libc/include/stdlib.h?revision=2524&view=markup&sortby=file&pathrev=2551
AVR Libc Home Page
This is an important point; note the toolchain is not excluded from the requirements of MISRA C. The document contains specific guidelines on how to claim compliance in the areas of compilers/toolchains; the most realistic option being use an ISO 26262 (and similar industry standards) functional-safety certified toolchain.
I'd suggest you'd be in for much less pain ($$$ aside...) using the MPLAB XC toolchain, rather than avr-gcc -  MPLAB Development Ecosystem for Safety Applications | Microchip Technology
jtw_11 wrote:
($$$ aside...)
Not as expensive as other toolchains with a functional safety rating.
Part Number: SW006021-FS - MPLAB XC8 Functional Safety License via MPLAB® XC Compilers | Microchip Technology
Indeed, perpetual licensing too!
Copy what's needed.
Better is to not invoke that which is an issue.
#include <stdlib.h>
typedef double longF;
void out(longF value);
int main() {
    longF it = atof("3.14");
    out(it);
    srand(25);
Enabling MISRA in a kind of static analyzer flagged only
PC-lint Plus Online Demo - Gimpel Software - The Leader in Static Analysis for C and C++ with PC-lint Plus
Yeah, even with the 2012 update I only see the rules about some (many!) of the functions in <stdlib.h> being verbooten - not that the entire header file is. I wonder if this was simply a proposal. I can't find reference to a "21.21" either.
(If I could find my printed copy then, because it is 10+ years old, I suspect it will have no knowledge either!)
I found that reference on a site that appears to be promoting a static analyzer: https://www.perforce.com/resourc...
Was just looking to see what the general rules are. Seems to me that if one of our coding goals is (execution) reliability, that those rules ought to be more readily available for even us grunts. Some of them, I see, could be considered "style" (quite a few around structuring if(), while(), and other looping constructs). To me, most of those appear to be simply "good practice", having gotten caught, a number of times, with loops that looped differently than what I thought I was writing. That is one of the things that I like about the code editor I use (TextWrangler, though I am sure others also offer it), where it marks out where IT thinks that the loops loop (it can also collapse loop blocks, which is useful).
I was a bit dismayed that such an important set of rules is available only by payment. But, I guess that is the way the world is, these days.
Well the above says that these days the entrance price for writing quality/reliable code is now just £12 (I think the books used to be £25+) so it seems cheap to me!
Be warned about what it says things about things like the C preprocessor!
I have to agree with Jim: if there is a generally accepted set of standards to writing better code (note that MISRA doesn't stop you getting things completely screwed up, but it mostly forbids methods and structures that have been shown in the past to result frequently in disaster) it would seem sensible to make them freely available to encourage their use. On the other hand, the people doing the work need to be paid!
In a similar manner, BSI or ISO or EN standards are often *requirements* and they are expensive... BSI 3103 (Method for preparation of a liquor of tea for use in sensory tests) costs £110 for non members and £55 for members, though the main points can be seen here: https://neatorama.com/trivia/201...
I can't help feeling that tax payer funded standards, particularly where they are legal requirements, should be freely available to the tax payers. But it seems its considered a cost of doing business. I suppose they're tax deductible, along with membership of the standards organisation.
Neil
barnacle wrote:
...(note that MISRA doesn't stop you getting things completely screwed up, but it mostly forbids methods and structures that have been shown in the past to result frequently in disaster)...
Just like ISO9001...as long as your manual says that the products you make are utter rubbish, and you make them consistently rubbish, then you can hold 9001 certification.
