Hey guys, I've been playing with a WWVB clock receiver and so far have not been able to correctly receive the time code.
I'm ~500mi as the crow flies from Ft Collins so I would think I should be able to receive day or night, although night should be better.
I have two of the receivers, one with the long stick loop, and one with the short stick loop antenna, both have fairly short leads to the receiver board.
Has anyone here tried one of these with success?
If so which sketch did you use? I've tried 3 or 4 I've found on github, but so far no dice.
edit: https://www.amazon.com/CANADUINO...
this is the short stick receiver I have, the long stick is similar and I think is made by the same company.
