Error 'object instance' does not name a type
12 posts / 0 new
Hello everybody!
OK, I got stuck with this stupid error, and I need someone's fresh glance at my code!
I am trying to compile my c++ program in Atmel Studio 7 which uses my own EncDRV class. Here is the short code.
EncDRV.h
#ifndef __ENCDRV_H__
#define __ENCDRV_H__
class EncDRV
public:
	EncDRV();
	static void (*callback)();
}; //EncDRV
#endif //__ENCDRV_H__
EncDRV.cpp
#include <EncDRV.h>
// default constructor
EncDRV::EncDRV(void)
} //EncDRV
main.cpp
#include <EncDRV.h>
EncDRV encoder;
encoder.callback = encHandle;   //               <-- here I get 'encoder' does not name a type error
void encHandle(void)
The error occurs in the main.cpp file at the line "encoder.callback = encHandle;".
Nothing depends on the variable I am trying to reach in the instance, the problem stays the same. Please, help!
Just to let you know...
You can't access a static member variable through an instance of a class. Use:
A static member variable can't be accessed through an instance of a class. Use:
EncDRV::callback = encHandle;
Some more issues:
  • encHandle is being used before it has been defined. Either provide a prototype or move the assignment to after the definition of encHandle.
  • callback has been declared in the EncDRV class body, but it has not been defined in the source file. With C++17 or later static member variables can be declared inline to avoid having to define them in a source file.
void ( * EncDRV::callback )() = encHandle; // in source file if pre C++17 or not using inline
inline static void ( * callback )() = encHandle; // in class body if C++17 or later
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
Well, in Arduino IDE it worked somehow. Thanks for the hint! Corrected.
OK, I added it to the EncDRV.cpp file and now it's the same error but for the callback: 'callback' in 'class EncDRV' does not name a type
P.S. And more to say: I can't access even nonstatic members of other classes from the file scope of main.cpp with the same error.
The below assumes this code is pre C++11. Could be simplified and improved for C++11 and later.
Header:
class EncDRV {
    public:
        typedef void ( * Callback )();
        EncDRV()
        static Callback callback;
void encHandle();
#endif // __ENCDRV_H__
Source:
#include <cstddef>
#include "EncDRV.h"
EncDRV::Callback EncDRV::callback = NULL;
void encHandle()
Main:
#include "EncDRV.h"
int main()
The above compiles just fine. However, I'm guessing that you aren't actually trying to initialize callback to encHandle, but rather assign to it later on:
Header:
class EncDRV {
    public:
        EncDRV()
Source
#include <cstddef>
#include "EncDRV.h"
Main:
#include "EncDRV.h"
void encHandle()
int main()
Another note: leading underscores shouldn't be used in symbol names since names beginning with leading underscores are reserved for the compiler's and standard library's use.
Isn't that only for C? C++ copes with namespaces much better - probably because it actually implements them.
There seems to be two common ways to identify member variables in C++. either _var or mVar
OK, I solved it for now.
The only thing that helped me was your hint that encHandle has to be declared before I pass it into callback. In fact
doesn't work only in the file scope for some reason. So I moved it to main and it all works fine, and the class static members are all accessible via encoder instance. No typedef and null pointers magic required here.
Thanks a lot! :-)
main.cpp
#include <EncDRV.h>
EncDRV encoder;
The indicated line of code does not exist within a function. Of course you'll get an error.
Sorry, I don't understand within which particular function it doesn't exist. It exists in the file scope and supposed to serve as a global variable so the interrupt service routines could call encHandle when required.
C only allows '=' outside of a function body when specifying initialisers during object instantiation. You can't assign a value to an existing object (a run time action) outside a function. Surely what you want is something more like:
class EncDRV {
    public:
        EncDRV(Callback initCallback = NULL) :
           callback(initCallback)
then at the point of instantiation:
EncDRV encoder(encHandle);
int main(void) {
    yada yada yada
This will make the assignment in the c'tor.
As I made it a default parameter then:
EncDRV encoder();
int main(void) {
    yada yada yada
is also possible - in which case it will be set to NULL by default.
Note: Arduino 'fixes' the forward references for you.
Which may make for "simplicity" when using Arduino but teaches very bad habits!
Indeed! Thanks to everybody!
