ATtiny1616 -> Comparator Latch Hack
5 posts / 0 new
My LUT's are all used up and I'm trying to get creative with a latch and the event system.
In the diagram below the comparator is one of the three internals, so there are three pins used; vIn, compOut, evntOut.
Maybe it would work if I could invert the comparator signal though the EVSYS...
You should be able to invert EVOUT using the PINxCTRL register for the IO pin.
I forgot to point out, the comparator output is inverted for the PMOS. I believe you're right it can be inverted again via PINCTRL however looking at the spec the chip doesn't feature open drain outputs.
Well, I don't know exactly why or in what conditions you want the comparator to latch, but you can sometimes emulate open drain using a diode (in this case between the AC input and EVOUT).
Yeah I'm now against it, it means a diode and an additional NMOS. I'll live with servicing the interrupt as fast as the CPU can instead.
