Make a menu with an LCD screen in ATMega328p
13 posts / 0 new
Hello everyone, I am new here and I hope I am not in the wrong category.
I have a problem and it is that I have been trying to develop a menu for an LCD screen with a shield keypad.
The idea is to do it in Atmel 7 but I still can't find an answer.
If anyone could give me an orientation or a brief answer, I would be grateful.
Here is a brief summary of what I plan to do.
I have a 16x2 LCD and Shield Lcd Keypad
I need the buttons of the arduino shield to be able to enter a menu and select a category and a value, and with that I would activate or deactivate a sensor.
Thank you very much and see you later
If there’s Arduino code available, why not use that? It is only c/c++. At a minimum, you could use that code as a basis for your own interpretation.
You mean Atmel Studio 7 (now called Microchip Studio 7) ?
As far as doing the menus goes, there's nothing specific to the IDE or the microcontroller - so don't confine your googling to those
There are plenty of examples available.
A common approach is to have a structure which defines the menu texts, and the functions to be used to action menu choices
You could model that on a PC ...
Thanks to both of you for answering, I am also trying to draw similarities between the arduino and avr language, it is my first project and I still do not know how to look for things, I leave a video that I found and the result is similar to what I am looking for.
Thanks a lot
Take a look at Dean's well-regarded setup.
https://github.com/abcminiuser/m...
I often use an approach that is much better in some ways (in terms of space efficiency & ease of use), but this is suitable.
Thanks for responding so quickly, yes, I think I mean the same software, but I found it as Atmel Studio 7.
Could you recommend a place to see examples? This is my first project and I still don't know where to get reliable information
Thanks a lot
Thanks, I'll check it right away
Before you start any programming of menus you need to use this programming language first: ENGLISH
Think thoroughly and describe in detail what you want it to do & then approaches will start to appear & you should describe those possible approaches.  Come up with at least 3 or 4 ways, so you can compare pitfalls & benefits.
Be detailed in your use of ENGLISH programming & the rest will follow nicely.
Total votes: 2
There is no 'Arduino' or 'AVR' language - they are both C/C++ and the Arduino tools and AS7 use the same compiler. The main difference is the Arduino tools manage the libraries and the build for you.
AS7 can import Arduino projects if you so desire.
Indeed.
Hence the suggestion:
It is the same C or C++ language - so you can forget about the details of LCDs and buttons, and concentrate on designing the menu functionality ...
the AVR butterfly code has a nice menu, although the LCD display is different, the concepts for the up/down/left/right/select buttons would be the same.
A menu is a state machine, see the tutorial forum for how state machines work.
Edit : added SM text
Arguably Dean then made a "better" version of that...
Thanks, I did not know that, I'll take a look and download a copy! smiley
