Simple timer with 20mHz clock
14 posts / 0 new
Hi Guys,
I'm trying to implement a simple counter to generate an interrupt every 2ms (roughly) so I can monitor pin change speed based on the counter.
I've looked at some of the online calculators and read some of the tutorials on timers, but my head's starting to spin a little I have to say.
Using one of the calculators i've come out with some figures but I'm not sure if these are suitable
Timer1
F_CPU 20000000UL
prescaler CLK/32
real time: 0.002 seconds
total timer ticks: 1250
Frequency: 500Hz
remainder ticks: 1250
overflow:0
All the ISR will do is increment a value
Am I on the right track?
regards
20M / 32 is 625k so the length of one "tick" is 1/625000 which is 1.6us. If you count 1250 of these the timer period will be 2,000us which is, indeed 2ms :-)
Thank you.
My question then is, how do I get the timer to generate an interupt at 1,250? and would a prescaler of CLK/64 be better? (625 ticks)?
regards
Remember that to get 1250 total ticks you set the compare-match value to 1249 since 0 is counted.
Remember 1250/64 isn't 625.
Remember that an 8-bit timer can only count to 255.
All of this and much more is covered, and in a much better fashion, by articles on timers in the Tutorials forum.
...and more.
However all the examples have a prescaler of 64
ie
// set up timer with prescaler = 64 and CTC mode
TCCR1B |= (1 << WGM12)|(1 << CS11)|(1 << CS10);
I cannot figure out, which part of the above sets that value.  In my case I want a prescaler of 1, where would that be set?
regards
What does that data sheet say?  Did you search for prescaler
Since you said (roughly) every 2ms, don't waste a valuable 16-bit timer.  Use an 8-bit timer that gets you close enough.  You can use either a prescale of 256 and a count of 156, or a prescale of 1024 and a count of 39.  Either one will give you a tick every 1.9968ms, or 0.16% off.
Ah, thank you, I assumed it was a standard formula
Atmega324PB -  for no prescaler, CS11 is not set. so
TCCR1B |= (1 << WGM12)|(1 << CS10);
should do the trick I guess
regards
Good point, though I have 3 16bit timers in the Atmega324PB
regards
I would also recommend using an 8-bit timer with a prescaler of 256.   I always use the overflow interrupt with timers, for no other reason than it works and I know how to do it.
 Load the timer with a value of 100 (256-156):100.   After 156 counts the 8-bit timer will overflow and cause an interrupt.  In the IRQ routine, set a flag for the main code that lets the main code know that a 2mS interval has passed.   Use a bool variable that has been declared 'volatile'.   Then reload the 8-bit timer with the value:100, and exit the IRQ  In the main code, poll for this flag being set.   When it is, do the 2mS activity and don't forget to clear the boolean flag.
I might be wrong, but with a clock speed of 20mHz, I don't think an 8bit timer would work would it?
regards
Note: mHz is milliHertz.  MHz is MegaHertz. :)
The question is, what is the biggest division that an 8-bit timer can produce.  Assuming a prescaler setting of 1024, an 8-bit timer can divide the clock by 1024*256 or 2^18 (262,1440).  20 MHz divided by 262,144 = 76.3 ticks/sec, or a max tick interval of 13.1ms.
Note that this requires the timer to be reloaded within 256 clocks (which is very relaxed timing, should be trivial to do).  Similarly, a prescale of 1024 needs to have the timer reloaded within 1024 clocks.  This only gets to be an issue when using much smaller prescale values.
BTW, in the bad old days, this was the only way most timers worked.  We are so much more fortunate in today's timer universe.
The slowest you can run a timer is /1024 so on 20MHz that means 19,531Hz. At that speed 1 "tick" is therefore 1/19531 = 51.2us. The most of these an 8 bit timer can count is 256 so 256 * 51.2us is 13,107us which is 13.107ms. So if you are looking for 2ms then it is in range. Even if you'd been looking for 250ms (out of range) it's still do-able. You'd actually set the timer to some fraction of this (maybe 10ms) then only take action each time you have counted 25 of these.
