Microchip studio crashes and restarts when I try to re-configure atmel start project within Microchip studio
8 posts / 0 new
I downloaded Microchip studio from microchip and installed it over atmel studio v7.
Now I can not configure my project from atmel start.
Anyone having same problem?
Do other things work ?
I have done a clean reinstall it did not solve the problem.
I have atmel ICE connected to my costum pcb, so far yes.
Also I created a new example atmel start project it did not crash, then I changed some configurations within microchip studio via re-configuring atmel start it did not crash.
I think it has something to do with projects which were created by atmel studio.
I recreated atmel start file from microchip studio and imported my header and source files to this new project folder.
For now everything seems to be ok I can program with atmel ice and reconfigure using atmel start withing microchip studio.
I had the same issue and that was my only solution, to rebuild a new and drop in the code I wrote.
I am also having trouble enabling the 32kHz oscillators
Max_TMP: If you are using one of the newer Tiny/Mega chips, starting or stopping 32KHz oscillator requires dealing with change protection. Check out something like:
_PROTECTED_WRITE(CLKCTRL.XOSC32KCTRLA,CLKCTRL_RUNSTDBY_bm | CLKCTRL_ENABLE_bm);
Same problem here. 7.0.2542 kills atmel START for pre-existing projects.
Sehnsucht
