Actual Radio Buttons.
11 posts / 0 new
Does anyone still sell actual radio buttons - ie, the interlocking, latching push switches ?
I can see some 2nd-hand, ex-equipment ones on ebay, etc - but does anywhere sell new ones?
My google searching is just getting swamped by references to the GUI metaphor.
frown
Hmm ... Amazon:
but only 3 of the 5 interlock - I think
https://www.amazon.co.uk/Latchin...
search for GANGED PUSHBUTTON SWITCH on Google   also, interlocking latching switches
also, take a look here, you will find many to like:
https://www.surplussales.com/swi...
also see:
https://electronics.stackexchang...
https://www.ebay.com/itm/1-E-Swi...
IF YOU WANT TO SEE NEW DATASHEETS FOR "radio/audio style" SWITCHES look here
http://www.farnell.com/datasheet...
https://www.alibaba.com/product-...
also table fan switches       exhaust fan switches
build your meat grinder
Seems to give results almost entirely at https://www.surplussales.com/ or https://www.westfloridacomponent...
also see:
Reports the same issue;
Transistor on Stack Exchange wrote:
They used to be called radio buttons but a search for those will return all software version for GUI applications
IF YOU WANT TO SEE NEW DATASHEETS FOR SUCH SWITCHES look here
I don't know about "new" - it says "ITT Industries"
I did see that one, but they don't seem to be a current line item
frown
EDIT
Although it does lead to this:
https://www.mouser.co.uk/Product...
which could be the thing ...
you want brand new...we got brand new:
https://tr.aliexpress.com/i/4000...
more brand new, with HARDCORE engineering specs:  (weel, it sounded good)
https://www.amazon.com/uxcell-In...
Alps still make them. RS have a few in stock.
I want to see a photo of what your fixing!
we can only guess
Is that the Jupiter II?
Yes; isn't that your hand? cheeky   Oh the pain of it all.
Me?
Not fixing anything - want a way to switch headphones between a number of sources. Possibly a different source in each ear.
"Radio buttons" seem more convenient that rotary selectors.
