The New AVRs. Dx and Ex Series Comparison.
16 posts / 0 new
Total votes: 2
I've been trying to get my head around the differences between the various new chip series and have scribbled out a crib sheet. Might be useful to someone else.
Updated to include...
OpAmps
MVIO
Adj Threshold Clarify HS Xtal
I had not really looked at this new series of AVR's, but the EA's look very interesting.
What do the numbers in the ADC row mean?  #of analog channels?
I'm interested in compiling a list of more subtle differences, i.e. DA has standard CMOS inputs while DB inputs can be individually set the TTL level inputs.
Yes.
Missing MVIO and op-amps.
Xtal needs to include low freq and high freq...
Will update
As far as I can see they all have low freq xtals. I was trying to highlight areas where they differ.
Fair enough.  Do they all do the "clock auto-tuning" thing?
They all mention it.
Top post updated to include missing features.
I'm intrigued by all the green "note triangles". Do you intend to make the XLS itself available so one can see the hidden bits?
I wouldn't get too excited. It's just Excel warning me that what it thinks is a date, eg '10-22' I have formatted as text.
I get the meme now!  I've only been using libreOffice and Google Sheets, and they're not nearly so bad.
I wish I could find a way to prevent Apple Notes from thinking a set of numbers is NOT a phone number, so Brian I feel you pain!
Now that we're into the weeds...
Does anybody else find it counter-intuitive how the DA/DB datasheets slice up their family?
Lumping chips by memory size rather than pin count and peripheral set doesn't fit my design process.
I know what the inputs and outputs are; And I have a good idea of what peripherals are needed.
I won't know how much flash or RAM I need until the code is done.
I usual develop on a large memory chip then, once the code is mostly baked, sub in a lower-mem, pin-compatible chip on the final BOM.
If the datasheets were published with the family sliced by pin-count rather than memory:
The IO Mux table would be simpler.
The vector table would be simpler.
The peripheral address map would be simpler.
Fewer package drawings would be included.
Am I daft?
I'm not entirely sure what you mean by "slice."
It's hard-core little-endian!  pinCount-family-memory-core.  48-DB-128-AVR; just read backwards, as usual!  :-)
Rejoice!  This is pretty much a more informative part numbering scheme than atmel has ever had before!
(I especially applaud putting the family in the middle of the part number, where it won't be confused with the packaging letters.)
It looks lack of CAN within all Dx series, so sad.......
