tiny104 xplained cannot connect
15 posts / 0 new
I can't get the xplained 104 to connect. I have tried 3 different xplained boards, 4 different computers (Intel and AMD), 5 different usb leads, 2 different operating systems (win7 and win 10 - with latest updates), in a pc usb port and on a powered hub,  and in both studio7 and studio 6. It (nEDBG) doesn't show up in device manager so I suspect a windows usb driver issue. I also tried an xplained mini and that wouldn't connect either.
Is there a spell or incantation I can use to make it work? Or failing that a set of drivers I can download?
You mean when you go to studio 7  selection:  TOOLS/DEVICE PROGRAMMING  you don't see something like
note (at least for me), the Xplained328pb shows up  as a composite (it goes away/reappears ) with my xplained removed/installed.  Mine has a serial  port  (maybe they all do?), which also shows up.
No, just the simulator. And it doesn't appear in the 'Ports' in Device Manager. Btw, I bought these kits when they first came out but I need to use them for a project now.
Have you tried installing the MPLAB X ide?
Question for other freaks, does the OP need to download any other support files after loading AS7 to get 104 support?
FF = PI > S.E.T
How do I get my Tool to be recognized by Atmel Studio? | Atmel Studio 7
kevinkirk wrote:
Btw, I bought these kits when they first came out ...
IIRC, some instances of EDBG had updates; EDBG should be an auto-update by atfw.exe though can be done manually.
Automatic Firmware Upgrade Detection | Atmel Studio 7
Should be in recent Atmel Studio 7 though can check the packs.
http://packs.download.atmel.com/#collapse-Atmel-ATtiny-DFP-pdsc
Device Pack Manager | Atmel Studio 7
atfw cannot find them - the mini xplained is the 817 version btw.
Nothing appears in device manager so I can't update the drivers. These modules are fresh out of the box btw so they haven't been damaged.
Have you tried different USB cables, perhaps you are using a charging only USB cable!
FF = PI > S.E.T
That is an EXCELLENT point  ...I got some mixed in with other (good) cables & went zany wondering why something  wasn't working....There should be a law that such cable be so marked.
I found all of those I had and "permanently marked" them with my wire cutters...no more confusion.
Yes I tried a number of USB cables. They work fine with the Attiny416nano I've got.
I still think it's a firmware/driver issue can I get old versions?
Wise advice.
