Help on Debugger and Programmer Options
22 posts / 0 new
Hello everyone,
I'm just working on my first major project and also using it as a learning experience. I have decided to go down the Atmel Studio route but pop into Arduino to test basic principles.
I am using an ATmega 328PB, ATMega2560(I think U4) designation.
Anyway, I am increasingly  finding I need some form of hardware debugger and ideally a programmer. Now, I am getting really confused with all the terms used for various options and pieces of hardware from both Atmel and forums when I search what's out there - from JTAG to debugwire, dragon, ICE, SDK500, etc etc.
Unfortunately the cost of the genuine Atmel kit is prohibitive for me what with losing job and Covid,  but even if I DID have the required pennies I still cannot work out what I would buy too many options   ..... Help!!!!
Oh, it would be nice to have high voltage programming for fuses so which rabbit hole do I go down.
An  ATmega 328PB XPlained Mini is under a tenner - and includes a debugger and programmer.
https://www.microchip.com/DevelopmentTools/ProductDetails/atmega328pb-xmini
You buy something which supports the chip(s) you're interested in.
Microchip list relevant tools on the Product Page for each chip.
you only need HV to recover if you've really messed up the fuses - otherwise, a normal debugger/programmer will do
EDIT
XPlained Mini link
EDIT 2
Recovering from fuse "mistakes": https://www.avrfreaks.net/forum/tutsoft-recovering-locked-out-avr
You probably want to look at "Snap" as the cheap option:
https://www.microchip.com/develo...
Another way to go is to buy "Xplained Pro" or "Xplained Mini" boards. They have a programmer/debugger on board together with some model of AVR. In some cases the same debugger can be used "off board" to debug other targets.
Don't base your decision on that alone - everyone has a "chip accident"  that might require HVPP once in their lives. Usually the "cheap" solution is to discard the chip, learn by the experience and move on. Tying yourself to something that can do HVPP (like Dragon) will severely limit your options (in fact the tools that could do HVPP - STK500, Dragon, etc all seem to be obsolete anyway)
Welcome to AVRFreaks!
Good choices!  As others have suggested, the Xplained modules give you a programmer/debugger for that type of AVR, as each family has its own way of doing things, one cheap solution will not work for all, but at
least for now, the Atmel ICE will work for all when you can afford one.
Learn to look for opportunities to serve others and a world will open up to you! Good luck with your search.
Let us know where your located, a freak may be near by that can help.
Indeed.
For an example of how to "hack" an ATmega328P XPlained Mini  to do this, see:
https://www.avrfreaks.net/forum/low-cost-debugger-xplained-kits
You can program fuses using ISP.  You do not need HVPP for that.
As others have said HVPP is a 'last resort' and for the cost of a programmer to support this:
Just toss the part(resoldering a fresh one is your teacher to NOT screw up LOL)
Cheers,
JIm
I was looking at:
8bit dev boards
and it seems to me that something like the 328PB one at £6.84 (I guess that means $10) seems to be a very good place to start:
https://www.microchip.com/Develo...
A 328PB is a modern/utilitarian AVR and would be a good place to start learning about AVR and that on-board debugger will help a LOT!
EDIT: should pay more attention to 1st post - you already said 328PB (I was too focussed on 2560) so this Xmini should be perfect shouldn't it?
(but also take a look at Nanos and Unos on ebay from about £3 upwards (less if you can bulk buy) - sure there's no debugger but you can achieve a lot with serial printing that such boards make very easy).
Hi
Thank you all for all the replies.
I think I will look over the Xplained boards, based on the feedback here with one or two £2 ebay 'specials' to fill in the gaps.
I think my issue is that technology is moving soo quickly these days and I no longer have an '18yr olds brain' ... I don't know which is more difficult keeping up with the new terms, different manufacturer terms for the same thing or learning the technology itself.
Thanks again :-)
Two days ago I was using a Dragon that has got to be 10+ years old and STK500 which is 15+ so I wouldn't worry too much about things going out of fashion. While Atmel/Microchip do discontinue things they seem to have a habit of supporting them for some time after their demise and even give firmware updates to support new debug/program interfaces from time to time.
Two main choices:
1.  Buy a SNAP, Pickit4, ATMEL-ICE.   Will debug all AVR and ARM devices.   SNAP is cheap.
2.  Buy a XMINI or XPRO board.   Do everything with one USB cable.
I like the idea of everything on one USB cable.
The SNAP, ... solution involves extra USB cable and ribbon connector.   (you have to make your own ribbon for the SNAP)
And is more future proof.
Hi David
I like the look of the Xmini, I don't suppose you know if this could be used with other devices with a bit of 'Heath Robinson esq'  work? I'm thinking akin to the way STM developments do
Note that includes a (virtual) COM port.
It can be used with other devices which use the debugWire connection - see #5
Not quite sure what you're alluding to there?
If you're talking about STM32, they are ARM Cortex-M - so they use the ARM standard SWD connection
debugWire is an Atmel (now Microchip) proprietary connection; it is used on only some AVR products - and not on any other manufacturer's products.
Yes,  you can use an Xmini-328 on another debugWIRE target.   But it is a bit of f*rting about.   And the Xmini debug chips are SLOW.
The XPRO debug chips are FAST.   I don't know if they handle all ARM SWD, JTAG, PDI, UPDI, ... protocols or just the protocol used by the specific target board.
SNAP, PK4, ATMEL-ICE handle all protocols and are all fast.   Have input voltage protection.
If you use XMINI on an external target you must be more careful with wiring,  voltages etc.
Yeah some STM development boards have what seems to be a breakoff section that can be used as a standalone programmer.
XMINI PB 329PB - £7 directly from Microchip free postage delivered Monday - sold!
If you are in the UK and have a Farnell account,   your order would arrive tomorrow.  (if you order before 20.00 today)
Yes,  you can use the SWD debugger from an ST Nucleo on different manufacturer Arm Cortex chips.
But proprietary software like AS7.0 will not support it.
Keil, Rowley, ... will let you use the ST debugger on Microchip/Atmel ARM chips.
Obviously none of this applies to an AVR with debugWIRE.
Docara wrote:
(I think U4)
A USB megaAVR?  (ATmega32U4 are popular and in several Arduino)
If yes then factory or Arduino or PJRC bootloaders; so, loaders therefore no programmer required and can debug by other means.
AVR simulator in Atmel Studio is complete so can debug some (most?) AVR code on a Microsoft Windows.
Docara wrote:
Unfortunately the cost of the genuine Atmel kit is prohibitive for me ...
The ones at Waveshare recognize that issue and have repackaged Atmel-ICE with extras.
MPLAB PICkit 4 has 12V programming, has been tested for most AVR including mega328PB and mega2560, and is in Atmel Studio 7 though I haven't tried that debugger (yet to acquire a MPLAB PICkit 4)
P.S.
Docara wrote:
... what with losing job and Covid, ...
Similar pain here due to USA/STATE OF/CITY OF COVID-19 responses; if one has an essential job then usually good to go otherwise a struggle.
Microchip - USB DFU via Atmel FLIP (loader)
New and Noteworthy | Atmel Studio 7
Atmel Studio 7.0.582
  • Support for Flip-compatible bootloaders in atprogram and programming dialogue. The connected device appears as a tool.
Arduino - USB CDC
PJRC - USB HID, HalfKay bootloader :
HalfKay Communication Protocol | PJRC
Atmel-ICE - Waveshare Wiki
East :
Atmel ICE C Kit Powerful development tool for debugging and programming Atmel SAM and AVR microcontrollers ATMEL ICE PCBA inside-in Demo Board from Computer & Office on Aliexpress.com | Alibaba Group
West :
Cost Effective Original Atmel-ICE-C Kits PCBA Inside Debugger Supports JTAG SWD | eBay
MPLAB PICkit 4 In-Circuit Debugger
PICkit 4 - Waveshare Wiki
also listed with MPLAB X.
Unaware of such for Atmel Studio though the data is in the XML.
Device Support | MPLAB X IDE v5.40
         <device Dname="ATmega328PB">
                  <at:interface type="isp" name="ISP"/>
                  <at:interface type="hvpp" name="HVPP"/>
                  <at:interface type="dw" name="debugWIRE"/>
                  <at:tool id="com.atmel.avrdbg.tool.medbg"/>
                  <at:tool id="com.atmel.avrdbg.tool.atmelice"/>
                  <at:tool id="com.atmel.avrdbg.tool.pickit4"/>
                  <at:tool id="com.atmel.avrdbg.tool.avrdragon"/>
                  <at:tool id="com.atmel.avrdbg.tool.ispmk2"/>
                  <at:tool id="com.atmel.avrdbg.tool.jtagicemk3"/>
                  <at:tool id="com.atmel.avrdbg.tool.snap"/>
                  <at:tool id="com.atmel.avrdbg.tool.edbgc"/>
                  <at:tool id="com.atmel.avrdbg.tool.edbg"/>
                  <at:tool id="com.atmel.avrdbg.tool.avrone"/>
                  <at:tool id="com.atmel.avrdbg.tool.jtagice3plus"/>
                  <at:tool id="com.atmel.avrdbg.tool.powerdebugger"/>
                  <at:tool id="com.atmel.avrdbg.tool.stk600"/>
                  <at:tool id="com.atmel.avrdbg.tool.jtagicemkii"/>
                  <at:tool id="com.atmel.avrdbg.tool.stk500"/>
                  <at:tool id="com.atmel.avrdbg.tool.simulator"/>
                  <at:property name="com.atmel.avrdbg.tool.simulator.key" value="ATmega328PB"/>
                  <at:property name="com.atmel.avrdbg.tool.simulator.model.win32" value="simulator/win32/libatmegakpb.dll"/>
                  <at:property name="com.atmel.avrdbg.tool.simulator.model.linux64" value="simulator/linux64/libatmegakpb.so"/>
copied from http://packs.download.atmel.com/#collapse-Atmel-ATmega-DFP-pdsc (unzip the download, open .pdsc)
https://www.avrfreaks.net/forum/come-join-us-mplab-now-supports-avrs?page=6#comment-3020136
STK500 is still in production; STK600 likewise.
STK500 | Microchip Technology
ISP Programming | STK600 AVR® Flash MCU Starter Kit User's Guide
awneil wrote:
debugWire is an Atmel (now Microchip) proprietary connection; ...
debugWIRE has been "reversed".
awneil wrote:
it is used on only some AVR products - ...
The follow-on to debugWIRE is UPDI; both have inexpensive third party tools.
debugWIRE via USB UART | AVR Freaks
dwire-debug has an AVR GDB server; the GDB client in Atmel Studio 7 is mostly complete with significantly more coverage soon.
MPLAB Snap and atbackend | AVR Freaks
Standalone mEDBG UPDI programmer and issues with Avrdude | AVR Freaks
A quick whinge, if I may. Farnell UK have recently increased their minimum order value for free delivery from £20 to £30 +VAT for non-trade accounts. Having avoided RS, Mouser and Digikey for the last few years, I am now regularly comparing my baskets, although today's order still went to Farnell. I s'pose it couldn't last forever and I'll just have to be a little more organised from now on.
I would recommend the OP also look at AVR-DA, now that there is a AVR128DA48 Curiosity Nano board available (£9 +VAT). There is also a working Arduino core, and it's a luxury not having to jump through hoops to fit code into 2K of SRAM.
On a trade account, it's easy to set up an alternative delivery address.
If you want to drop me a PM, maybe I could order for you - for delivery to your address ... ?
Similarly RS.
As someone with very limited hardware needs I don't even bother to look at the big distros like Farnell, Arrow, Element14, RS, etc because of things like min order. I find companies like BitsBox, CoolComponents, Pimroni, PiHut (yup even for AVR!), HobbyTronics to be far better prospect even if things are a few pennies more. You can make a lowly £2.73 order, pay about £1 postage and have it arrive the following day from most of these (1st class post is actually pretty good).
