SAME70 XDMAC on PIO
6 posts / 0 new
Hi
I'm working on a project using SAME70 microcontroller.
I'd like to send a stream of data on PIO Port D as fast as possible using DMA controller.
Someone know if is possible with this CPU to use ad DMA channel destination address a PIO register ? ( in my specific case PIOD->ODSR )
Thank you
why shouldn't that work? Simply configure a memory to memory DMA channel. The source is wherever the data is located that you want to send and the destination is the PIOD->ODSR. The transfer speed should be up to the maximum of the internal AHB bus - that is to my knowledge up to 150MHz. Any other DMA transfer may delay it.
There is an application note that is explaining quite well how to use XDMAC.
Best Regards
Markus
I thought the same, but on my preliminary test seem that this is not true. I reconfigured a working mem to mem working example changing destination address and destination increment mode, but at least from debugger seems that out register doesn't change at all.
I'll retry with the scope connected to the port to see what really happens.
There is another post that affirm that this is not possible on this controller:
This:  AN_42761 - AT17417: Usage of XDMAC on SAM S/SAM E/SAM V  ?
via: https://www.microchip.com/wwwproducts/en/ATSAME70Q21 - 'Documents' tab
That app note distinguishes memory-to-memory from memory-to-peripheral - so did you also try setting it up as memory-to-peripheral ?
I received today the reply from Microchip's FAE that follows my area and confirm me that this option is not available on SAME70.
Oh well, at least that answers the question.
Please mark the solution - see Tip #5 in my signature, below, for instructions:
