I can't apply a programm to my arduino
7 posts / 0 new
What`s that failure code mean:
avrdude.exe: error at C:\Users\Kabel Eddy\Documents\Atmel Studio\7.0\AVRdude\avrdude.conf:1133: programmer type jtagice3_updi not found
I don`t want the jtagice3_updi
sorry for my bad english if there is any german speaker here
What was the avrdude command you used?
edit: anyway, the most likely cause is that you are using an old version of avrdude that doesn't support that programmer. Use the one that comes with the Arduino IDE.
To get it, search for "avrdude" inside this file:  https://github.com/arduino/Arduino/blob/master/hardware/package_index_bundled.json
Inside this file, you will find the download link for the correct one for the OS you are using.
Welcome to AVRFreaks!
What arduino are you attempting to program?   Uno or other?
Do a screen capture of your Tools menu expanded so we can see how it is configured, please.
Sorry it has been way too long since my high school german class to attempt it!
But it seems that avrdude thinks you have configured it to use one
Here is a German forum: https://www.mikrocontroller.net/
I'd be taking a good look at what you have set in the Arduino tools menu...
Have you set anything on this list to anything other than the default (or rather the values you require for the type of Arduino you are trying to contact).
It seems very unlikely that "jtagice3_updi" is the right setting.
BTW which model of Arduino is this anyway? There are not (m)any that would be programmed by any form of UPDI.
What's wrong with leaving the standard Arduino Bootloader intact and using that to upload your program ?
I had the same problem when I assumed that avrdude 6.3 was the same version as released with Arduino 1.8.13.
The source code to avrdude 6.3 in the downloadable ZIP file at http://savannah.nongnu.org/proje... is not the same as that used by Arudino.
The ZIP file version shows the following when the command 'avrdude -v' is given on a command line:
 avrdude: Version 6.3, compiled on Dec 14 2020
But the version released with Arduino 1.8.13 shows a different version:
avrdude: Version 6.3-20190619
Version 6.3 will generate this error with the command 'avrdude -C [path to Arduino config file]/avrdude.conf' :
error ... avrdude.conf:1133: programmer type jtagice3_updi not found
That error occurs because Version 6.3 does not support the jtagice3_updi entry in the avrdude.conf file for Version 6.3-20190619
If I use the git command to get the latest version of avrdude 6.3, and then compile it, I get the same version as that with Arduino:
avrdude: Version 6.3-20190619   [Note that no compile date is inserted with this build].
This version (6.3-20190619) does not generate the above error when run with the Arduino avrdude.conf file.
Also, the avrdude.conf file obtained from the git download is identical to the avrdude.conf file delivered with Arudino 1.8.13.
Here are the commands used to obtain  and build Version 6.3-20190619:
 git clone https://github.com/facchinm/avrdude.git avrdude-6.3-20190619 --depth 1
 cd avrdude-6.3-20190619
 ./bootstrap
 ./configure
 make
 ./avrdude -v
 ./avrdude -C /usr/local/arduino-1.8.13/hardware/tools/avr/etc/avrdude.conf -v
Using this git version of avrdude, I get the same error-free result as using the Arduino version:
/usr/local/arduino-1.8.13/hardware/tools/avr/bin/avrdude -C /usr/local/arduino-1.8.13/hardware/tools/avr/etc/avrdude.conf -v
This was a hard bug to trace, because there is a mismatch between the ZIP version of 6.3 that one can download vs. the Arduino 6.3 version obtained with git.
