same 70 with max30102
3 posts / 0 new
hi everyone....
   i am new in arm cortexM7. i am using atsame70q21 controller for measure spo2(max30102/max30105). but i dont know how to use it.
can anyone help me for the same with example code.
Thanks in advance >.....
Find some examples for Arduino. That should give you some ideas.
Do you have any experience with any other microcontroller(s) ?
Do you have any experience with programming in general ?
Then you need to refer to the manufacturer's documentation - it has nothing to do with Microchip:
https://www.maximintegrated.com/en/products/interface/sensor-interface/MAX30102.html
Look under 'Design Resources' ...
See also: https://maximsupport.microsoftcrmportals.com/en-US/support-center/
And: https://maximsupport.microsoftcrmportals.com/en-US/knowledgebase/
