I can't write to terminal window from called subroutine
6 posts / 0 new
This is just puzzling.  I am using Atmel Studio 7 with an Arduino Uno.  I want to display data on the terminal window.  It works just fine as long as the STS UDR0, R20 command is in the main line of processing.  If I put that command into a called subroutine, the terminal display fills with the first character, repeated over and over.  I can code the same thing over and over if needed, but it is irritating.  Yes, I am coding in Assembler.  I am using lines copied from the Atmega 328p datasheet.  I am setting the UBRR0 to 00:67 hex.  That is a little bit of Kentucky windage there.  The manual had suggested 66 for an mpu running at 11.8 mhz.  The Uno has a 12 mhz crystal.
As I say, it works just fine as long as all my writes to terminal happen in the main portion of the program.
Suggestions?  Comments?  Questions
I'm serious about pinball. Everything else is just for fun.
Perhaps... show the code? Show the subroutine and how it is called.
/Jakob Selbing
You must wait for the UART to be ready to accept the next character---are you monitoring the status bit before trying to send each character?
There's really not much to the whole thing, so you are prob making some simple code mistake...show a copy.
Also some terminals can get overloaded (can't keep up), depending on baudrate, PC settings, etc.  So you may want to put some delay between characters, a few ms is plenty.   Bray's  terminal
will goof up if you give it a long blast of characters without rest.  See, computers get tired too.
Mark this one closed.  I still don't know what I was doing wrong.  I opened up a new program with just the code to access the terminal window as a called subroutine.  With just that code in place, the program ran perfectly.   I had left out a call to a routine that read from EEPROM that had been in the program.  I do not know if that was the conflict or not
Anyway, all is well that ends well.
Thanks for your responses.
You do that by marking the solution - see Tip #5 in my signature, below, for instructions:
Thank you.  I think it is marked.  I clicked on the mark button and now it says 'unmark.'
