SAMD21 basic pwm not working (no ASF)
4 posts / 0 new
I'm trying to setup PWM on certain pin as basic test. I downloaded this example to setup correct clock (getting 48MHz on clk gen 0 as input for PWM timer): DFLL48M 48 MHz Initialization
Then I call:
void init_pulse(void)
     PM->APBCMASK.reg |= PM_APBCMASK_EVSYS;           // Switch on the event system peripheral
     // Genric Clock Initialisation
     GCLK->CLKCTRL.reg = GCLK_CLKCTRL_CLKEN |         // Enable the generic clock...
     GCLK_CLKCTRL_GEN_GCLK0 |                          // ....on GCLK0 at 48MHz
     GCLK_CLKCTRL_ID_TCC2_TC3;                          // Feed the GCLK0 to TCC2 and TC3
     while (GCLK->STATUS.bit.SYNCBUSY);               // Wait for synchronization
     // TCC2 Initialisation - generate pulse every 100us (10kHz) on port pin PA16
     // Enable the port multiplexer on port pin PA16
     PORT->Group[PORTA].PINCFG[16].bit.PMUXEN = 1;
     // Set-up the pin as a TCC2/WO[0] peripheral on PA16
     PORT->Group[PORTA].PMUX[16 >> 1].reg |= PORT_PMUX_PMUXE_E;
     TCC2->WAVE.reg = TCC_WAVE_WAVEGEN_NPWM;            // Set the TCC2 timer to normal PWM mode (NFRQ)
     while(TCC2->SYNCBUSY.bit.WAVE);                    // Wait for synchronization
     TCC2->PER.reg = 4799;                              // Set the period (PER) register for a PWM frequency of 10kHz (100us)
     while(TCC2->SYNCBUSY.bit.PER);                     // Wait for synchronization
     TCC2->CC[0].reg = 2400;                            // Set the counter compare 0 (CC0) register for a PWM duty-cycle of 50%
     while(TCC2->SYNCBUSY.bit.CC0);                     // Wait for synchronization
     TCC2->CTRLA.bit.ENABLE = 1;                        // Enable TCC2
     while (TCC2->SYNCBUSY.bit.ENABLE);                 // Wait for synchronization
But nothing happens at PA16?
Can you get an ASF example to work ?
If so, use that as a basis to see what you're missing ...
Hi awneil, just discovered that I forgot to switch on TCC2:
PM->APBCMASK.reg |= PM_APBCMASK_EVSYS | PM_APBCMASK_TCC2;
Now it works.
MarcelH wrote:
Now it works.
Excellent. Now please mark the solution - see Tip #5 in my signature, below, for instructions:
