What do I have to do to be able to use PB6, PB7, PC6 and PC7 as outputs?
PORTD is the only port I've been able to get all 8 LED's to turn on (programming with on the STK500.) On PORTB and PORTC, the 2 MSB's will not change state.
Thanks!
Thanks!
PB6 and PB7 are also used for the crystal. Are you using an external crystal?
PC6 is the reset pin- can't use as an output unless you change the fuse (don't do it).
PC7. There is no PC7.
You need to do special STK500 cabling to get PB6 and PB7; from the AUX header IIRC. Look at AVRStudio Help; search the Forum for "pb6 pb67 stk500 mega8".
Yes, PC7 >>would<< be a cute trick. And for PC6, then you need to re-cable for HV programming from then on.
Lee
Aha - thank you for the info. Yeah, my fault on the PC6/7 thing :).
I wasn't able to find that post, but I did find out the wiring.
PB5:0 wire as usual, of course....
PB6 = XT1, PB7 = XT2 (on the AUX header). With the supplied four 2-wire connectors, there are just enough to get it working.
Search found 19 matches AVR Freaks Forum Index Forum Topics Author Replies Views Last Post No new posts AVR forum ATMega48 - PORTB and PORTC only outputting 6 LSB's Psychlow 3 54 Oct 05, 2007 - 09:35 PM Psychlow View latest post No new posts AVR forum ATMega8 pb6 and pb7 voltage level problem [ Goto pageGoto page: 1, 2 ] bnocturnal 22 383 Sep 14, 2007 - 10:32 PM JackFoligie View latest post No new posts AVR forum No ADC on Mega8515 new2use 12 290 Aug 17, 2006 - 01:19 PM dl8dtl View latest post No new posts AVR forum STK500 LED Question pupdawg 2 147 Jun 09, 2006 - 05:54 AM pupdawg View latest post No new posts AVR forum **missing bits on portB [atmega8 & stk500] galazg 4 143 May 24, 2006 - 03:42 PM microcarl View latest post No new posts AVR studio 4 forum mega8: XTAL/TOSC - pins (PB6+7) switch*blade 2 311 Apr 21, 2006 - 02:07 AM switch*blade View latest post No new posts AVR forum ATmega8 PB6 and PB7 Output Issue (ISSUE SOLVED) sjpa 5 244 Apr 13, 2006 - 03:26 PM Bingo600 View latest post No new posts AVR forum LCD no work on Mega8 PortB underwaterreefer 6 139 Mar 14, 2006 - 05:13 PM underwaterreefer View latest post No new posts AVR forum ATMega8 ADC hookup, Help! atellis 4 128 Mar 12, 2006 - 09:07 PM theusch View latest post No new posts AVR forum Atmega8 External RC Oscillator Question eh3 9 289 Feb 20, 2006 - 06:13 AM lfmorrison View latest post No new posts AVR forum How do I use PB6 and PB7 on mega8? Sci 2 222 May 30, 2005 - 05:45 PM CountZero View latest post No new posts AVR forum mega8 PB6,7 I/O problem magno_grail 7 272 Mar 21, 2005 - 06:38 PM theusch View latest post No new posts AVR forum ATMEGA8: Cannot enable Port B6/B7 stefanwurlitzer 7 273 Jan 18, 2005 - 12:52 AM stefanwurlitzer View latest post No new posts AVR forum port problems with an mega8 krazykarl 8 394 Nov 22, 2004 - 01:32 PM mneary View latest post No new posts AVR forum Which microcontroller is the appropriate? Alexandros 12 582 Jul 16, 2004 - 09:29 AM pepsi View latest post No new posts AVR forum Can PB6 and PB7 be used as general IO on a Mega8? Lawrence 3 35 May 28, 2003 - 02:50 AM Sean View latest post No new posts AVR forum PB6 & PB7 on Mega8? StuartWhelan (Stuart Whe 4 77 May 23, 2003 - 04:26 AM StuartWhelan View latest post No new posts AVR forum HELP, mega8 & portb engg100 (Josh Wolf) 9 15 Jan 16, 2003 - 03:29 PM lee View latest post No new posts AVR forum Mega 8 STK500 ISSUE ginvent (Joseph Gottlieb 11 162 Sep 17, 2002 - 08:35 AM lee View latest post
