Common Mode Chokes for dummies
7 posts / 0 new
My electronics is a bit weak and I am trying to figure out how to pick a common mode choke as per recommendation of a PSU module.
now, for pricing purposes, I have to use this AC/DC module, looking at the typical application circuit, the EMC recommended circuit recommends:
  • for the input - green ring 15mH 2.5A T12 x 7 x 6 CMC
  • for the output - green ring T13 x 8 145uH CMC
the module operates on a 65kHz switching frequency.
I am struggling to pin point what kind of choke I should be looking at? is the max current enough information to pick the cheapest choke in Digikey?
what should I be looking at in terms of picking a common mode choke for both input and output of this circuit?
Ovi2wise
Digital electronics student... forever a student
Current rating is generally "the big one", but it is not as bad as the energy storage inductor in a switcher, because there are opposite-flowing currents that reduce the DC flux in the core.
Common-mode chokes tend to be good over a fairly wide range of frequencies. So, the precise operating frequency of the switcher should not be critical. Honestly, I don't know what "green ring" refers to; I have never seen that designation. It may signify a specific magnetic material, but I don't know how to interpret it. Those are likely "ferrite" cores. I am guessing that L2 is 12mm outer diameter. Probably 6mm thick and 7mm difference between outer radius and the inner radius (e.g. radial thickness). Or, visa versa.
Not sure that I would use "cheapest" as a selection criterion. I would simply choose one that works.
Very often, you just want this  (line filter) ...there are 1000's of models, some include a fuse holder...I have a giant scrap box of about 50 types---a few are high current versions
look here ...GREAT prices & wide variety
https://www.alltronics.com/cgi-b...
higher price
https://www.digikey.com/en/produ...
you can get some good deals on scrap ones  The big one has a fuseholder & switch & mavbe 110/220 voltage selector (not sure)
Honestly, I don't know what "green ring" refers to    --I'd never heard of it either ....kinda funny stuff, these Chinese desc
IIRC, a few years ago I helped one of my sons build a coil for physics class.
It turned into such an ordeal that I posted about it here, but I've not found the Thread with a quick search.
In any  event, IIRC, the color had to due with the magnetic permeability of the toroids, and hence their inductance.
Edit:Typo
https://electronics.stackexchang...
In summary... no, each manufacturer has their own colour code.
I wonder if "green" means environmentally friendly.
Why do you thunk they call it earth gnd?   Have you ever traveled on a ground plane?
