Interrupt Based Seven Segment
35 posts / 0 new
So I have common anode, multiplexed seven segment display that I'm trying to make count down when a button is pushed. I had this working (except for the "flashing" issue which is mentioned below) that display part of the code was this:
    int  time_Set,value_time;
	time_Set = new_time*100;
	value_time = time_Set / 1000;
	//ten-thousandths digit
	time_Set = time_Set % 1000;
	if (value_time < 1) //If 1st digit is zero, don't display anything
		sbi(PORTC, 0);
		sbi(PORTC, 1);
		sbi(PORTC, 6);
		sbi(PORTC, 7);
		PORTD = seg_code[value_time];
			cbi(PORTC, 0);
	    	sbi(PORTC, 1);
			sbi(PORTC, 6);
			sbi(PORTC, 7);
		_delay_ms(1);
    //thousandths digit
	value_time = time_Set / 100;
	time_Set = time_Set % 100;
	sbi(PORTC, 0);
        cbi(PORTC, 1);
	sbi(PORTC, 6);
	sbi(PORTC, 7);
    _delay_ms(1);
    //hundredths digit
	value_time = time_Set / 10;
	sbi(PORTC, 0);
	sbi(PORTC, 1);
	cbi(PORTC, 6);
	sbi(PORTC, 7);
	_delay_ms(1);
    //Tenths digit
	value_time = time_Set % 10;
	sbi(PORTC, 0);
	sbi(PORTC, 1);
	sbi(PORTC, 6);
	cbi(PORTC, 7);
	_delay_ms(1);
Those 1 ms delays are additional timing issues within the code so I wanted to trim the number of delay functions in my code. So I'm attempting to make everything interrupt based.
#define F_CPU 8000000UL
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdlib.h>
//Segment Code
#define ZERO     0b11000000
#define ONE      0b11111001
#define TWO      0b10100100
#define THREE    0b10110000
#define FOUR     0b10011001
#define FIVE     0b10010010
#define SIX      0b10000010
#define SEVEN    0b11111000
#define EIGHT    0b10000000
#define NINE     0b10011000
//Define the Inputs
#define Timer_Button !(PINA & (1<<PINA1))
#define sbi(a, b) (a) |= (1 << (b))  // Set bit high
#define cbi(a, b) (a) &= ~(1 << (b)) // Set bit low
// Globals
int  timeselect, retimeselect,buzz_interval,interval_diff,new_time;
char seg_code[]={ZERO, ONE, TWO, THREE, FOUR, FIVE, SIX, SEVEN, EIGHT, NINE};
volatile uint8_t buzz_stim;
volatile uint8_t milsec;
volatile uint8_t dmilsec;
volatile uint8_t hunsec;
volatile uint8_t tensec;
void Timer_init(void)
	PCMSK0 |= (1<<PCINT1);
	PCICR  |= (1<<PCIE0);
	sei();
void millis_timer(uint8_t millis)
	TCCR0A |=  (1<<WGM01);
	TCCR0B |= (1<<CS02)|(1<<CS00);
	//=(F_CPU*2/frequency*2*N)-1
	OCR0A = millis*8 - 1;
	TIMSK0 |= (1<<OCIE0A);
	sei();
ISR(TIMER0_COMPA_vect)
	milsec++;
	dmilsec++;
	if(dmilsec > 3)
		dmilsec = 0;
	if(milsec == 10)
		tensec++;
		milsec = 0;
	if(tensec == 10)
		hunsec++;
		buzz_stim++;
		tensec =0;
	if(hunsec == 10)
		hunsec = 0;
void buzzer_short()
	millis_timer(1);
	sbi(PORTB,7);
	buzz_interval = buzz_stim;
	do
		interval_diff = buzz_stim - buzz_interval;
	while (interval_diff < 2);
	cbi(PORTB,7);
unsigned char timer_button_state()
	if (Timer_Button)
		_delay_ms(10);
		if (Timer_Button)
        buzzer_short();
		return 1;
	return 0;
ISR(PCINT0_vect)
	new_time = timeselect;
	if (timeselect <= 1)
			timeselect = retimeselect;
	if (timer_button_state())
		new_time--;
		timeselect = new_time;
void set_timer()
	millis_timer(1);
	Timer_init();
	switch (dmilsec)
		case 0://ten-thousandths digit
				sbi(PORTC, 0);
				sbi(PORTC, 1);
				sbi(PORTC, 6);
				sbi(PORTC, 7);
				cbi(PORTC, 0);
				sbi(PORTC, 1);
				sbi(PORTC, 6);
				sbi(PORTC, 7);
			break;
		case 1://thousandths digit
			sbi(PORTC, 0);
			cbi(PORTC, 1);
			sbi(PORTC, 6);
			sbi(PORTC, 7);
			break;
		case 2://hundredths digit
			sbi(PORTC, 0);
			sbi(PORTC, 1);
			cbi(PORTC, 6);
			sbi(PORTC, 7);
			break;
		case 3://Tenths digit
			sbi(PORTC, 0);
			sbi(PORTC, 1);
			sbi(PORTC, 6);
			cbi(PORTC, 7);
			break;
int main()
	DDRA = 0x00; // All of port A are inputs
	DDRB = 0xff; // Declaring all bits of Port B as outputs
	DDRC = 0xff; // Declaring all bits of Port C as outputs
	DDRD = 0xff; // Declaring all bits of port D as outputs
	timeselect = 10;
	retimeselect =11;
	      set_timer();
The following is happening:
  1. If the displayed number is supposed to be 1000, both the thousandths and hundredths digit are completely on (displaying 8.)  If that number is supposed to be 9 and below, the hundredths digit is completly illuminated.
  2. The digits seem to "flash" when button is pushing, meaning all digits turn off at once for less than a second when button is pushed
Cody W Phipps
I might hazard a guess that the interrupt priority of PCINT is greater than that of TIMER_COMP - so if you sit in PCINT with a button held down, TIMER_COMP will never fire - nor will your display.  All those modulo and division instructions will take rather a long time - consider a separate variable for each digit.  Furthermore, your PCINT_vect variables are not volatile.  Hope that helps.  S.
I'll add a couple of things.  Check your button inside the timer interrupt (after you set your segments and digits, not before).  It's free and it will avoid the timer ISR getting delayed (you've even got a _delay_ms and a buzzer delay in the button interrupt - BAD!).
Second, only turn on your digit after you have set the segments.  The sequence is LAST_DIGIT_OFF...SET_CURRENT_SEGMENTS...CURRENT_DIGIT_ON.  You'd be surprised at how much ghosting you can get in low light if you turn on a new digit with the old segments on.
You keep on calling millis_timer(1). Just set timer 0 up in CTC mode for 1ms. Set and forget.
In the isr, output one digit at a time - compute the value and seven seg lookup in the main line code.
In the isr, have a down count for your buzzer. If the down count is not zero, turn the buzzer on, if it is zero, turn the buzzer off. Your main line code just loads the down counter with the on time when you want to buzz.
In the isr, read the switch input and debounce.
Your code will then be much simpler and work better.
So put the block of code inside of the compare vector that is ticking my ms timer instead of the PCINT0 vector?
Cody W Phipps
Another thing or two:
Why are all your '_init' routines inside set_timer()?  Do you really need to re-initialize them every trip through your while{} loop?  For that matter, you should put sei() after ALL the intialization is done (again in main()).  What happens if you get an interrupt while initializing?
What counter does _delay_ms() use?   S.
Eliminate the PCINT0 interrupt and ISR entirely.  Do any time-critical work inside the timer ISR.  Do less time-critical work in your main loop.  As a rule of thumb, do the least amount of work possible in the ISR, and do everything else outside of the ISR.  Communicate between ISR and main loop with single byte flags or variables.
So I cut and pasted that block of code into three different places and now the buzzer constantly sounds once the timer button is pushed in all three spots I put it in. The buzzer goes off in the third position if the button is held down.
		new_time--;
	milsec++;
	dmilsec++;
	if(dmilsec > 3)
		dmilsec = 0;
	if(milsec == 10)
		tensec++;
		milsec = 0;
	if(tensec == 10)
		hunsec++;
		buzz_stim++;
		tensec =0;
	if(hunsec == 10)
		hunsec = 0;
int main()
	timeselect = 10;
	retimeselect =11;
		new_time--;
		set_timer();
int main()
	timeselect = 10;
	retimeselect =11;
		new_time--;
		set_timer();
Thank you for your patience on this, I am more of a design engineer who is trying to get better at coding. I have dedicated time during the week for general learning. Hoping between that and you guys, I'm striving to be proficient enough to contribute like you are doing.
Cody W Phipps
Fair enough, we were all there once. :)
Let's start with the basics.  How often does your timer interrupt run?  You generally want to refresh each multiplexed digit at least 100 times per second, so if you have 4 digits that is 400 times per second, or a 2.5 ms timer interrupt, but I don't know how many digits you have.
Now, if you want your buzzer to buzz for e.g. 1/2 second, that is 200 timer interrupts (assuming 4 digits).  You will start your buzzer, then count 200 timer interrupts and on the 200th interrupt, turn the buzzer off.
So, tell us your timing requirements and we can proceed from there.
1/2 second would be fine with me and that refresh sounds like it will work as well. I will a be using four digits when the time value is ten (it can also be fifteen). This is only about a fourth of the code (which I have the other parts working and I think the lessons learned from here will improve the other parts dramatically as well), for that time value will eventually countdown by seconds ( time value I select is in minutes).
Cody W Phipps
ISR()
    do_critical_work();
    do_less_critical_work();
For some reason, the text I put before this code block disappeared, and I cannot insert text before the block now.  So I will put the text here.
You can use the same 2.5ms timer interrupt for most or all of your timing needs, including reading and debouncing buttons, counting seconds, etc.
You also have to decide how much work to do inside the ISR vs. outside the ISR.  The two code blocks (above and below) show the basic idea.
The above code makes your ISR longer, and can make other interrupts less responsive.  The alternative is:
volatile unsigned char timer_tick = FALSE;
ISR()
    do_critical_work();
    timer_tick = TRUE;
// in main code
while (1)
    if (tier_tick)
        timer_tick = FASWE;
Most of the time you will want to use the 2nd method, but it's always a judgement call.
To me, the second method would be probably the best. So if I'm reading this correctly, I should do away with dmilsec variable ( the msec timer for the display), the milsec, tensec, and hudsec variables inside of my TIMER0_COMPA vector? I guess millis_timer(1); will turn into millis_timer(2.5); as well.
Cody W Phipps
Your timer ISR could be as simple as this
ISR()
    turn_off_all_digits();
    set_new_segments();// calculated in main loop or below in ISR
    turn_on_new_digit();
    timer_tick = TRUE;// signal main code that a tick has happened
(all the function calls above would actually be simple port writes)
This is taking the principle of a short, fast ISR to its maximum.  Only the direct timing-critical code (updating the display) is executed in the ISR.
As long as your main code cannot possibly miss a timer_tick notification (by running too long without testing timer_tick), this approach is workable.  But it is also possible to add more work inside the ISR, and if you do not have other time-critical interrupts in your system, there is no drawback to this approach.  Thus you see the basic tradeoff - doing so much work in main code that you might miss a timer_tick notification on the one hand, and doing so much work inside the ISR so that you cause excessive interrupt response delays on the other hand.  It is a juggling act that you will need to solve for each application.
Then you could work towards something like this:
Alright, I think I'm beginning to get somewhere. Seems like I got the digits displaying but I can't seem to get "timeselect" to decrement. It is staying at ten. I'll go after that _delay function in timer_button_state next.
// Globals
int  timeselect,digit,retimeselect,buzz_interval,interval_diff,new_time,thou_digit,mod_digit_tt, ten_thou_digit;
volatile unsigned char timer_tick = false;
	TCCR0A |=  (1<<WGM01); //Enable CTC
	TCCR0B |= (1<<CS02)|(1<<CS00); //1024 prescaler
	sei();
	if (Timer_Button)
		_delay_ms(10);
		if (Timer_Button)
      //  buzzer_short();
		return 1;
	return 0;
	sei();
void turn_off_all_digits()
	sbi(PORTC, 0);
	sbi(PORTC, 1);
	sbi(PORTC, 6);
	sbi(PORTC, 7);
void set_timer()
	time_Set = timeselect*100;
	ten_thou_digit = time_Set / 1000;
	mod_digit_tt = ten_thou_digit % 1000;
	thou_digit = mod_digit_tt / 100;
	digit++;
	if (digit > 4)
			digit = 0;
void turn_on_new_digit()
	if (digit == 1)
		if (ten_thou_digit < 1) //If 1st digit is zero, don't display anything
				sbi(PORTC, 0);
				sbi(PORTC, 1);
				sbi(PORTC, 6);
				sbi(PORTC, 7);
				PORTD = seg_code[ten_thou_digit];
					cbi(PORTC, 0);
					sbi(PORTC, 1);
					sbi(PORTC, 6);
					sbi(PORTC, 7);
	if (digit == 2)
		//thousandths digit
		sbi(PORTC, 0);
		cbi(PORTC, 1);
		sbi(PORTC, 6);
		sbi(PORTC, 7);
		PORTD = seg_code[thou_digit];
	if (digit == 3)
		//hundredths digit
		sbi(PORTC, 0);
		sbi(PORTC, 1);
		cbi(PORTC, 6);
		sbi(PORTC, 7);
		PORTD = seg_code[0];
	if (digit == 4)
		//Tenths digit
		sbi(PORTC, 0);
		sbi(PORTC, 1);
		sbi(PORTC, 6);
		cbi(PORTC, 7);
	set_timer();
	timer_tick = true;
int main()
	timeselect = 10;
	retimeselect = 10;
		millis_timer(2.5);
		Timer_init();
			new_time--;
		if (timer_tick)
				timer_tick = false;
Cody W Phipps
init_timer() turns on the pcints - but there's no ISR for it. That is not going to have a good outcome.
millis_timer(2.5);
The millis_timer() function accepts an integer, but you are providing a floating point value. It will be either 2 or 3. Make your choice.
As has been mentioned before, set your timer in CTC mode to give a consistent timebase. Your current method is making it difficult as you are making the problem way more complex that it needs to be.
Get rid of _delay_ms() altogether.  Count timer ticks for any delays.  _delay_ms() just wastes clock cycles, cycles that could be used to perform useful work.
instead of  PORTC, 6  don't use 6, give it a name so it's more clear than "6"
 You keep repeating the same things in the listing
A way that might be used any time,  note how much shorter this is.
myport= PORTC | (1 <<0 ) | (1 << 1) | (0 << 6) |  (0 << 7);  Get current port bits and prep final result for all digits off
if digit==1 {myport &= ~(1<< 0)    ...any other digit 1 stuff };  \\make bit low, will turn on digit 1
if digit==2 {myport &= ~(1<< 1)    ...any other digit 2 stuff };  \\make bit low, will turn on digit 2
if digit==3 {myport &= ~(1<< 6)    ...any other digit 3 stuff };  \\make bit low, will turn on digit 3
if digit==4 {myport &= ~(1<< 7)    ...any other digit 4 stuff};   \\make bit low, will turn on digit 4
PORTC=myport   ;  /sets PORTC digits as needed
How would you write that. I kept trying things and the buzzer works sometimes but other times it just stays on. Also, the timer value is not decrementing.
Cody W Phipps
There are a few different ways to do this.  Here is one example to help explain the process.
volatile uint8_t timer_tick = FALSE;
ISR()
    // do any ISR work
    timer_tick = TRUE;      // tell main code the timer has ticked
// this is in the main code loop
if (timer_tick)             // run this code every timer tick
    timer_tick = FALSE;     // don't leave flag set
    // do any timer tick work
    manage_buzzer();
// buzzer management
uint8_t buzzer_count = 0;   // or uint16_t if needed
void manage_buzzer(void)
    if (buzzer_count != 0)
        buzzer_count--;
        PORT |= BUZZER_BIT; // turn buzzer on
        PORT &= ~BUZZER_BIT; // turn buzzer off
// in main code, how to turn on buzzer for 200 ticks
    buzzer_count = 200;
An alternate approach to managing the buzzer:
        if (--buzzer_count == 0)    // end of buzzer period
    buzzer_count = 200;
    PORT != BUZZER_BIT;             // turn buzzer on here
Thank you kk6gm for your help. You definitely made some light bulbs go off and I was able to correct the rest of the mistakes, namely the decrementing issue with your last reply. Also thank you everyone else for you input and tips. I have also incorporated those. Below is what I have now and if I there isn't any more objections, I will mark it as the solution. I'm sure I will be back soon. Till next time.
#include <stdlib.h>
//Segment Code
//Define the Inputs
// Globals
int  timeselect,digit,retimeselect,buzz_interval,interval_diff,new_time,thou_digit,mod_digit_tenthou, ten_thou_digit, mod_digit_thou, hund_digit, ten_digit, sec;
uint8_t previousReading  = 1; // holds last 8 pin reads from pushbutton
uint8_t buttonWasPressed = 1; // keeps track of debounced button state
uint8_t debounce_count = 0;
uint8_t digit_on = 0;
unsigned char select_time = false;
	sei();
void buzzer(void)
		    buzzer_count--;
			sbi(PORTB,7); // turn buzzer on
	    		cbi(PORTB,7); // turn buzzer off
void timer_button_state()
	if ((Timer_Button) != previousReading)
			if(!buttonWasPressed)
					if(debounce_count < 15)
							debounce_count++;
								debounce_count = 0;
//Below are the tasks to do if timer button is pushed
								buzzer_count = 75;
								if(select_time) //Select time mode
										new_time--;
//End of timer button tasks
						buttonWasPressed = 0;
	previousReading = (Timer_Button);
	digit_on = PORTC | (1<<0) | (1<<1) | (1<<6) | (1<<7);
	digit_on &= (1<<0) | (1<<1) | (1<<6) | (1<<7);
	PORTC = digit_on;
void display()
    int time_Set;
	mod_digit_tenthou = time_Set % 1000;
	thou_digit = mod_digit_tenthou / 100;
	hund_digit = sec / 10;
	ten_digit = sec % 10;
	digit++;
	if (digit > 4)
			digit = 0;
	if (digit == 1)
					digit_on &= ~(1<<0) | (1<<1) | (1<<6) | (1<<7);
	if (digit == 2)
		//thousandths digit
		digit_on &=  (1<<0) | ~(1<<1) | (1<<6) | (1<<7);
	if (digit == 3)
		//hundredths digit
		digit_on &=  (1<<0) | (1<<1) | ~(1<<6) | (1<<7);
		if (timeselect)
				PORTD = seg_code[hund_digit];
	if (digit == 4)
		//Tenths digit
		digit_on &=  (1<<0) | (1<<1) | (1<<6) | ~(1<<7);
		//PORTD = seg_code[ten_digit];
		if (timeselect)
	PORTC = digit_on;
	display();
	timer_button_state();
	buzzer();
	timer_tick = true;
int main()
	timeselect = 10;
	retimeselect = 10;
		millis_timer(2);
		if (timer_tick)
				select_time = true;
				if (timeselect < 1)
				timer_tick = false;
Cody W Phipps
Why do you keep on calling millis_timer()? Set it once for CTC mode and leave it alone.
Move your digit to 7segment translation out of the ISR code - the translation only needs to be done when you change the digit values not every tick.
Where do I put it then? Putting it outside of the while loop causes it not to work. I have moved the buzzer() and display() into the main loop.
Cody W Phipps
Again, set the timer up for CTC mode. I gave you a link to an example. Thus, you only need to set the timer up once, and it keeps on ticking.
don't use 0,1,6,7 use names for each, so you can
a) tell what is going on
b) catch mistakes quickly
It will make a big difference in your life.
	PORTC = digit_on;
This should be one line of code--- you are just setting PORTC to some value
Do you need digit_on at all?  Where does it ever differ from portc?  It seems to be a weak shadow implementation.
buzzer does not need to be in irq...if not needed to be there, don't put it there.
I'm very familiar with your link for I studied it before I even posted. Thank you for your input though.
I prefer to keep it this way because this is the way I learn directly from Microchip/Atmel. If you notice I am using CTC mode as well, just seems the initialization methods are different. If this causes an issue in the future, I will follow your method and will come back to this post and comment on said problem.
Cody W Phipps
I followed your previous advice and now you are saying that I'm wrong. Pretty confusing.
Cody W Phipps
But ultimately, I do agree. It should be one line. Here is the updated code with above changes (sorry Kartman calling millis_timer(2); in the loop still). I do have one last question, should I be declaring all of my ints with the uint8_t instead of just int?
//Define the Inputs
#define digit_1 (PORTC, 0) //Ten-thousandth digit
#define digit_2 (PORTC, 1) //Thousandth digit
#define digit_3 (PORTC, 6) //Hundredth digit
#define digit_4 (PORTC, 7) //Tenth digit
// Globals
	sei();
void buzzer(void)
		buzzer_count--;
				debounce_count++;
						debounce_count = 0;
						buzzer_count = 75;
							new_time--;
	PORTC = (1<<digit_1) | (1<<digit_2) | (1<<digit_3) | (1<<digit_4);
void display()
    int time_Set;
	digit++;
	if (digit > 4)
		digit = 0;
	if (digit == 1)
		//Ten-thousandths digit
		if (ten_thou_digit < 1) //If 1st digit is zero, leave blank
				PORTC = ~(1<<digit_1) | (1<<digit_2) | (1<<digit_3) | (1<<digit_4);
	if (digit == 2) //Thousandths digit
		PORTC  = (1<<digit_1) | ~(1<<digit_2) | (1<<digit_3) | (1<<digit_4);
	if (digit == 3) //Hundredths digit
		PORTC = (1<<digit_1) | (1<<digit_2) | ~(1<<digit_3) | (1<<digit_4);
		if (timeselect)
	if (digit == 4) //Tenths digit
		PORTC = (1<<digit_1) | (1<<digit_2) | (1<<digit_3) | ~(1<<digit_4);
		if (timeselect)
	timer_tick = true;
int main()
	timeselect = 10;
	retimeselect = 10;
		millis_timer(2);
		if (timer_tick)
			display();
			buzzer();
			select_time = true;
			if (timeselect < 1)
			timer_tick = false;
Cody W Phipps
Purely on grounds of style, and avoidance of confusion, might I suggest that instead of this:
				debounce_count++;
						debounce_count = 0;
						buzzer_count = 75;
							new_time--;
you might consider changing your indentations and use of braces to make it clear that what is happening is what you intended to happen? (Makes it easier for other readers of your code, too!). Try:
		debounce_count++;
		debounce_count = 0;
  	    buzzer_count = 75;
		new_time--;
This makes it obvious that only the statement following the 'if' or the 'else' is to be executed, and not the whole block; and clarifies the semantics that the two legs of the if/else statement are mutually exclusive.
This is a matter of personal style, of course, and your original code is semantically equal to mine (unless I copied something incorrectly) but I do think that single line statements after control statements offer a huge risk of accidental misinterpretation, particularly if the indentation is unaligned. (MISRA insists on each { or } having a line to itself, and that they are used even for single line statements - something with which I wholeheartedly agree!)
As an aside - where logical expressions are being used, I prefer to see them expressed using booleans - true or false - rather than the equivalent 1 or 0. That way it's clear that they can only hold those two values (even though they are almost certainly implemented as ints internally. They're defined in <stdbool.h>.
Neil
As another aside (bit OT):
barnacle wrote:
As an aside - where logical expressions are being used, I prefer to see them expressed using booleans ... (even though they are almost certainly implemented as ints internally.
Neil
Oh lord I hope not.  In a memory-limited device like an AVR you're going to use two bytes for a boolean?  Really?
I guess it could encode, "True, False, File Not Found" and about 65,533 other possible "boolean" values... cheeky
I'm thinking about some systems I built in assembler using a dozen or more bits in GPIORs as flag collections (they're handy for that) and I'm now wondering what 'C' code would do if each flag bit had to be loaded as an int16_t into the 32 general purpose registers to be useful...  The pushing and the popping and the smashing of the stack would be quite impressive - for a kaboom.
Can we at least have at most a char or uint8_t?  Oh dear me.  S.
//Define the Inputs
#define Timer_Button !(PINA & (1 << PINA1))
#define DIGIT_1 (PC0) //Ten-thousandth digit
#define DIGIT_2 (PC1) //Thousandth digit
#define DIGIT_3 (PC6) //Hundredth digit
#define DIGIT_4 (PC7) //Tenth digit
#define NUM_DIGITS (4)
// Globals
int timeselect, retimeselect, buzz_interval, interval_diff, new_time, thou_digit, mod_digit_tenthou, ten_thou_digit, mod_digit_thou, hund_digit, ten_digit, sec;
const uint8_t seg_code[] = {ZERO, ONE, TWO, THREE, FOUR, FIVE, SIX, SEVEN, EIGHT, NINE};
volatile uint8_t timer_tick = false;
volatile uint8_t digits[NUM_DIGITS];
volatile uint8_t debounceCount = 30; //if this value is 0, button is pressed and debounced.
	TCCR0A = (1 << WGM01);	//Enable CTC
	OCR0A = millis * 8 - 1; //=(F_CPU*2/frequency*2*N)-1
	TIMSK0 |= (1 << OCIE0A);
	TCCR0B = (1 << CS02) | (1 << CS00); //1024 prescaler
	sei();
void buzzer(void)
		buzzer_count--;
		sbi(PORTB, 7); // turn buzzer on
		cbi(PORTB, 7); // turn buzzer off
		if (!buttonWasPressed)
			if (debounce_count < 15)
				debounce_count++;
				debounce_count = 0;
			buzzer_count = 75;
			if (select_time) //Select time mode
				new_time--;
void display()
	int time_Set;
	time_Set = timeselect * 100;
	digits[0] = seg_code[time_Set / 1000];
	digits[1] = seg_code[mod_digit_tenthou / 100];
	digits[2] = seg_code [sec / 10];
	digits[3]  = seg_code[sec % 10];
	static uint8_t digitNum = 0;
	switch (digitNum)
	case 0:
				PORTC &= ~(1 << DIGIT_4);
				PORTD = digits[digitNum];
				PORTC |= ( 1 << DIGIT_1);
				break;
			case 1:
				PORTC &= ~(1 << DIGIT_1);
				PORTC |= ( 1 << DIGIT_2);
			break;
			case 2:
				PORTC &= ~(1 << DIGIT_2);
				PORTC |= ( 1 << DIGIT_3);
			break;
			case 3:
				PORTC &= ~(1 << DIGIT_3);
				PORTC |= ( 1 << DIGIT_4);
			break;
	digitNum++;
	digitNum &= 3;
	if (Timer_Button)
		if (debounceCount)
			debounceCount--;
		debounceCount = 15; //allow 30ms of debounce
	timer_tick = true;
int main()
	timeselect = 10;
	retimeselect = 10;
	//something to display on startup
	digits[0] = seg_code[1];
	digits[1] = seg_code[2];
	digits[2] = seg_code[3];
	digits[3] = seg_code[4];
	millis_timer(2); //setup timer once
	while (1)
		if (timer_tick)
			display();		//how often do you need to update the display??
			buzzer();
			select_time = true;
			if (timeselect < 1)
			timer_tick = false;
I hacked the code around a bit to simplify it. No guarantees it will work though. Hopefully it should give a few hints - much less pissing about with the display and a simple debounce.
Note: The website munged the formatting!
re: bytes or bools
If you use a construct of the type
if (xxx)
isn't xxx going to be promoted to a bool before the comparison anyway? Which is the size of an int? Though the size of the int is of course implementation dependent...
Or does the standard say not true/false but non-zero/zero?
My point was not to do with the storage of the bit pattern in an AVR particularly (for example, one could use individual bits at the cost of increased processing to extract a bit before the test) but for clarity in the code. If you want to detect on a logical value, use true/false; if you want to use non-zero/zero then make it explicit with a comparison (which a compiler ought to optimise away anyway.)
Neil
How are you confused?...don't use numbers, use names so you can tell what is being done.  Are you mixing together  two different responses?
The idea behind the digits is you only turn on the digit you need (pref with turning all off) & simplify things so there will be no else. ...your simplification  ended up not being simplified.
Thanks for the help.
Cody W Phipps
