libarm_cortexM4lf_math.a uses VFP register arguments, project.elf does not Atmel Studio 7
8 posts / 0 new
Hey Atmel Forum,
I'm currently using the ATSAMD51J20 and try to get some math to work on it. I've included the "libarm_cortexM4lf_math.a" cmsis library and after compiling I receive the errors:
"libarm_cortexM4lf_math.a uses VFP register arguments, project.elf does not Atmel Studio 7"
and
"failed to merge target sdpecifc data of file ...\CMSIS\Lib\GCC\libarm_cortexM4lf_math.a".
I've tried out several things, like adding the libraries in the ARM/GNU Linker or changing " -std=gnu99 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 " to "-std=gnu99 -mfloat-abi=hard -mfpu=fpv4-sp-d16 ", which didn't resolve the issue.
Anyone some advice?
Thank you in advances and regards
crackl1ng
I would suggest that you put "libarm_cortexM4lf_math.a uses VFP register arguments, project.elf does not" into your favourite internet search engine - it seems to be quite common...
That's what I did, but nothing helped.
The consensus seems to be that you're using a library with hard FP while (some of) the rest of your project uses soft FP - so have you checked that out ?
Have you checked the Atmel Studio Project settings ?
Note that if you use the usual “double” functions (and constants), you won’t be using hardware float (which does single precision only)
I tried to, but I kind of did not know which library uses soft FP or hard FP. Is there a way to check it out? The project is kinda big since a lot of people work with it.
The Adafruit SAMD51 Arduino build link command ends up using:
-larm_cortexM4lf_math -mfloat-abi=hard -mfpu=fpv4-sp-d16 -L...variants/metro_m4 -lm
So where did you start with this project ?
